Old 03-26-2012, 10:46 AM   #3646
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
What advantage does a damper tube setup have over the mono shock. Seems to work fine for me.
I only fiddle with it like once/week to make sure there is no air in it.
valk is offline   Reply With Quote
Old 03-26-2012, 10:59 AM   #3647
Rick Hohwart's Avatar
I like the side shock too.
Damper tubes can be easier to work with for many people which is its main advantage. I don't feel there is any performance advantage.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 03-26-2012, 01:42 PM   #3648
valk's Avatar
Some people tell me they are more consistant but i dont see how. Seems more fiddly to fill the damper tubes right, getting just the right amount in each groove vs fill mono shock to top and otherwise build like a nomral shock.
In other news, anyone have suggestion for 12r5 settings for outdoor soda spray track?
Pretty much happy with the car indoors. Kit settings with a few minor adjustments for the most part but never raced pancars outdoors. Club wants to run open 12th scale.
Since i cant afford wgt just yet maybe ill try this and buy the 5.2 conversion next indoor season.
Track is ashphalt parking lot. Semi
Smooth but has bumps from parking lines and general weathering.
Old 03-26-2012, 01:47 PM   #3649
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Track is asphalt parking lot. Semi
Tires, and droop are all that change outdoors, everything else is fine tuning
More pod droop/sag, ride height for bumpy tracks
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-26-2012, 01:49 PM   #3650
valk's Avatar
Take the spacer out of the main shock? We run crc greylow rear and black front. Soft for outdoors but would they overheat? Thinking of running 6.5-8.5 or even just 10.5 cause im kinda new still.
Still cant handle my nitro sedan well yet ha.
Old 03-26-2012, 01:51 PM   #3651
Leave spacer in, adjust shock length with shock ball end, you wont need more than a few turns to do the job
Old 03-26-2012, 01:53 PM   #3652
valk's Avatar
That doesnt increase shock travel though right? Wouldnt i want a little more?
Old 03-26-2012, 03:15 PM   #3653
I suppose there is more than one way to go about it
Get back to us with your results
Old 03-26-2012, 04:49 PM   #3654
Infinite 12th's Avatar
The side shock rules
Never liked the tubes
Side shock looks way cooler too
Hope you guys stick with the side shock
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 03-26-2012, 05:05 PM   #3655
valk's Avatar
hey, im no expert lol. first year of touching a real rc car EVER and im 30.
just seems like you would want to either take the spacer out or put a smaller one in. more droop yes, makes sense, but is it really more when the shock still has the same limited travel cause of the spacer?
im sure when i thread it as told ill feel like an idiot though lol.
not 100% sure about doing this outdoor mod 12th thing. i still tap every few laps indoor 17.5.
Old 03-26-2012, 06:41 PM   #3656
Radio Active's Avatar
Apparently same setup for both classes.
I was interested in the rollout, and motor timing. Would you be able to find out for me please?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 04-02-2012, 09:28 AM   #3657
Default New kit?
I cannot longer find the 12r5.1 kit on rc10.com. Anyone know if a new release is just around? One lad at the club is in for a new car
oddski is offline   Reply With Quote
Old 04-02-2012, 10:41 AM   #3658
Looks like there is something in the works, as the 12R5.1 is discontinued at area51
http://www.teamassociated.com/cars_a.../Factory_Team/
Tower has the kit with lipo chassis upgrade in stock still
http://www3.towerhobbies.com/cgi-bin...4&I=LXCBLM&P=K
Old 04-02-2012, 11:48 AM   #3659
Based on what I saw @ the Carpet Nats, Id assume there is a new kit coming out for when the indoor season starts up again this fall. Just speculation of course...
JamesL_71 is offline   Reply With Quote
Old 04-02-2012, 11:57 AM   #3660
[QUOTE=RedBullFiXX;10548829]Looks like there is something in the works, as the 12R5.1 is discontinued at area51
Probably something new coming then Anyway, buggy-season starts in one month, so no rush I guess.
What will be in the new kit?. Damper-tubes, better weight alignment(or battery positions), linear side-springs, or just inline-config in kit... Hope there will be some backward compatibility...
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
