Old 02-29-2012, 03:17 PM   #3616
Maybell's Avatar
I usually use ASC4617 for the front height. I use Xray303131, 303132 and 303133 for fine tuning...
For the rear I use ASC4351 mostly, I also use CRC3383.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-29-2012, 04:15 PM   #3617
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I use smrtt7005.
That works in most conditions.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-29-2012, 04:34 PM   #3618
Infinite 12th's Avatar
Originally Posted by Josh-n-ya View Post
Kelly, Norcal has all the ride height pills and spacers on the wall!!!! You kind of have to try them out according to your tire mm!
I've used them before Josh...lol...
This is why I was asking for the AE full set part # but apparently they just make the individual one's now. Just trying to avoid going around and asking racers if they have spares...lol
Thanks for telling me they have the seperate one's though
Thank you for everyone's answers
Infinite 12th is offline   Reply With Quote
Old 02-29-2012, 04:59 PM   #3619
Maybell's Avatar
Originally Posted by Infinite 12th View Post
I've used them before Josh...lol...and I looked last saturday and they wern't there
Yep, I checked for you...AE doesnt sell the full set anymore.
Old 02-29-2012, 05:02 PM   #3620
Thanks again, I appreaciate your help
Old 03-06-2012, 06:08 PM   #3621
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
quick question.. was looking at my 5.1 and thought the rear axel wasnt centered right. quick measurement says the outside of the wheel is .5mm off from center.
the manual isnt that clear, but are you supposed to put 4 shims on both sides of the rear axle?
valk is offline   Reply With Quote
Old 03-06-2012, 07:15 PM   #3622
You cannot go by the manual or shims. Measure the total width of the rear, which should be 172mm. We almost never change this width on the rear of the car. Use whatever shims needed to achieve 172mm.
Steve Dunn
Indianapolis, IN
sdunnmcp is offline   Reply With Quote
Old 03-06-2012, 08:38 PM   #3623
valk's Avatar
so figure out how many shims i need to have 86 on each side? or should it be equal?
Old 03-07-2012, 08:19 AM   #3624
They will probably not be equal. You can measure from the center hole on the bottom plate to the inside of each wheel to make sure you are centered.
Steve Dunn
Indianapolis, IN
Old 03-07-2012, 12:17 PM   #3625
Maybell's Avatar
There are more accurate ways to measure it, but I just use my Hudy setup board decal to help center it.
Old 03-10-2012, 07:30 PM   #3626
Looking at the setup sheets I noticed none of the drivers mark what castor they are using does that mean everybody uses the standard castor which I believe is the 10.5 on the bulk heads.
Also on the setup sheet it says t plate used, but in the manual I cannot find anywhere where a t plate is used.
Bubonic-X is offline   Reply With Quote
Old 03-13-2012, 11:34 AM   #3627
Are you looking at the sheets for 12r5.(/1/2)?
Upper left box named front suspension. Upper arm mounts(reactive caster) 10-5-0 degrees and the drawing below is caster: 1.80-3.25-6.15.
Cars now use side links instead of t-bars. Im not alloved to post links here, but if you back go to page 234 in this thread, there is a link posted by Rich Howart on a current set-up. Here he use 10 deg upper arm mount(reactive caster) and caster 3.25 deg, the std settings. On page 236 setting attachment by masterhit: 5 deg UAM & caster 6.15.
HTH
oddski is offline   Reply With Quote
Old 03-13-2012, 01:18 PM   #3628
valk's Avatar
Think i was rolling 180 almost. Oh well another lesson in rebuilding your car when you buy it used ha.
Little tricky to measure with calipers. I just took a ruler, sharp pencil and paper to make a grid.
Old 03-13-2012, 03:14 PM   #3629
Default Who wants some?
@RBF
Ready when you are for some fun mod 12th scale action
http://oi41.tinypic.com/2v81ljt.jpg
http://oi40.tinypic.com/35a6m2a.jpg
Later
12th scale - The Jedi class...
Old 03-18-2012, 10:07 AM   #3630
Default Keven Hebert AE 12R5 2012 National Champions
Nice run Kev !
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
