Old 02-09-2012, 02:33 PM   #3541
Mike has been running the battery inline for several weeks, at least.
Denney
Denney is offline   Reply With Quote
Old 02-09-2012, 06:25 PM   #3542
RacinJ's Avatar
Originally Posted by gguertin145 View Post
Does anyone have a blinky 17.5 setup? Maybe from the birds last week...
Since switching to the inline battery I have struggled... Curious if people are changing their setups at all.
Thanks!
I've found that when running "Blinky", 17.5 or 13.5, that my car runs better stiff.
- .020 Front springs
- Blue side springs, 20WT
- Blue center spring, 30WT
When running 13.5 Boosted, the car is better soft.
- .018 Front springs
- Black side springs, 30WT
- Silver or Blue center spring, 30WT
Is anyone else seeing this?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 02-10-2012, 04:32 AM   #3543
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Thanks!
just come to your local track. We can show you the setup we used at the birds that has been working great all year.
Also what are you struggling with? grip? side bite? accel?
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 02-10-2012, 06:57 AM   #3544
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Well, just looking here the last few days backs up what I've always thought about the springs and oil on these cars.
It's all about feel, and making the car consistent over 8 mins.
I tune for track and tires, more-so than motor.
Not everyone likes the same setup, heck, I've never even thought about running drag brake in blinky , whatever works for you is the right setup.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-10-2012, 07:14 AM   #3545
Originally Posted by xtrememadness View Post
i think its more of a convenience thing. always having to replace the o rings in the stock shocks is a pain. especially when you want to tune at the track. also the stiction if you dont! im thinking of trying speed merchants damper tube conversion along with hb shock!
That is exactly how I have my 12R5.2 set up right now.
I just got a chance to test out the damper tube conversion last weekend for the first time... Jury is still out.
JamesL_71 is offline   Reply With Quote
Old 02-10-2012, 07:29 AM   #3546
masterhit's Avatar
Trader Rating: 15 (100%+)
Agreed. Proven set-ups give good ideas and give a reference if your out in left field. But ultimately it's about what works for each individual.
It doesn't help that "stock" specific set-ups are very rare for most cars.
The drag brake thing came from Terry Rott (while him and Andrew Knapp proceeded to have a screaming match about DB vs. push control). It works really well for certain sections, but takes a different driving style. You need to learn to keep the car slightly on throttle for some turns instead of the usual on/off style that is prevalent in blinky.
But the work is worth it for the look on the competitions face when you go mega-deep into a turn at the end of the sweeper!
Mike Slaughter
masterhit is offline   Reply With Quote
Old 02-10-2012, 07:55 AM   #3547
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Im running 20 to 30 weight in the tubes with blue side springs and 30 weight in center w/blue spring. Car is pretty stable! Oh and 020 front springs w/added shim to tighten up a bit.
Josh-n-ya is offline   Reply With Quote
Old 02-10-2012, 08:49 AM   #3548
Mike Slaughter
So the guys you race with actually let off the throttle in blinky
Old 02-10-2012, 09:06 AM   #3549
Just looking for new ideas
gguertin145 is offline   Reply With Quote
Old 02-10-2012, 09:09 AM   #3550
"I just got a chance to test out the damper tube conversion last weekend for the first time... Jury is still out. "
Where can I find this conversion? I would like to try this next weekend at the prairie knights race.
Thanks!
Old 02-10-2012, 10:29 AM   #3551
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Thanks!
Speed merchant makes it! Also i believe onpoint racing does also!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-10-2012, 06:50 PM   #3552
Blue Screw's Avatar
Send a message via AIM to Blue Screw
question why did u use losi oil and ae oil.. its2.5 wt diff.. so if u used 27.5 losi it would of been25 ae? or do u feel something different?
Thanks Paul, you're too kind.
Here is my standard set-up, which is just a variation of the common AE set-up. Don't be afraid to run big tires for club racing. I regularly start at 44.5mm for rears with a 2mm split.
The only thing that I do that is a bit abnormal (on the car) is run heavier side oils than most and use drag brake.
Important thing I forgot; I run the side springs with just a slight bit of pre-load at ride height. About a turn down from touching. To be honest my car hardly ever sees a tweak station.
For tuning I always start with front camber, and then tire treatment. Otherwise, not much needs to be changed for most conditions.
If things start getting "weird" I head right to the basics and freshen them up; front springs, side dampener, front kingpin dampening, and diff.
Thanks,
Mike Slaughter
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 02-10-2012, 07:11 PM   #3553
masterhit's Avatar
It just happened to be what I had on hand at the time. As you mentioned every brand is not created equal so I was just being thorough!
Mike Slaughter
Old 02-13-2012, 11:51 AM   #3554
Rick Hohwart's Avatar
Default New setup posted
Keven Hebert - Snowbirds - Modified 1/12
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 02-13-2012, 01:40 PM   #3555
Trader Rating: 18 (100%+)
any reviews/opinions for the speed merchant damper tube conversion? is there an alternative? looks like the on point method would be pretty extensive.
johnny lee is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
