Old 06-04-2008, 07:55 PM   #316
ok is there any way to make a gtb that is not a 4-cell fit in the car ?????
eflite300 is offline   Reply With Quote
Old 06-04-2008, 08:12 PM   #317
Zdiddy's Avatar
Sean, if you are able to test on the asphalt this weekend, please post your findings. I am signed up for the ashpalt nats with this car and the first time I get to run it will be at the event. Kinda scary!!!
Zdiddy is offline   Reply With Quote
Old 06-04-2008, 08:27 PM   #318
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I have read that there are size and also weight issues with trying to use a regular GTB in a 1/12th. Have you considered the Tekin? Its tiny!
mrrcguy is offline   Reply With Quote
Old 06-04-2008, 11:01 PM   #319
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
Send a message via ICQ to Wicked-Wayz Send a message via AIM to Wicked-Wayz Send a message via MSN to Wicked-Wayz Send a message via Yahoo to Wicked-Wayz
Yes, but you have to make it look like the 4cell version.
Peace Aaron(W-W)
Schacht Design Works Trackside Hobbies Dirtheaven CRC Hobbies MidWest Tri-Clone RC Scoring Pro LiveRc.com 92 Zero Designs
Wicked-Wayz is offline   Reply With Quote
Old 06-05-2008, 11:00 AM   #320
odpurple's Avatar
The only difference size-wise is the heat sink and fan. Take them off and replace the heat sink with an aluminum plate. The plate on a GTB 4 cell is ~.063"; I've used .032" with no problems. As a bonus you can plug your PT into the fan position on the esc
This pic shows the PT and a cut-down heat sink. The cut-down heat sink is more work and weight that you don't need.
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 06-05-2008, 03:44 PM   #321
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
thats a really smart thing to do with the PT.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 06-07-2008, 10:10 PM   #322
any idea what gear to run with a 17.5 or 13.5 on a track with a 140 foot straight on it I have never run this car so I have no clue what to use
Old 06-17-2008, 04:21 PM   #323
AE-Reedy
Sorry about the late reply, we've been pretty busy the last week or so.
I ran my car on our local asphalt track and it was pretty good with a mostly kit set up. The only thing I changed was the center shock spring, ran a red instead of gold.
The most important part of most any 1/12th car is getting the tires and tire sauce right. I ran Jaco lilac fronts and pink rears. I never found the best tire sauce for our track so I just ran the tires dry. It wasn't the best the first couple of laps but once the tires "warmed up" it drove pretty good. All of the sauces I tried just made the car real greasy and it wanted to spin out until the rear tires dried up. Without sauce the car was a little low on grip but it was an even loss of front and rear grip. I know once I find the best sauce set up the car will be very good.
Sean Cochran is offline   Reply With Quote
Old 06-17-2008, 04:33 PM   #324
AE-Reedy
We haven't had much experience yet with these motors in 1/12th, I do know that the gears are big. I think 13.5 will roll out around 60 mm and 17.5 might be 70mm or higher.
Old 06-17-2008, 04:37 PM   #325
AE-Reedy
Originally Posted by InspGadgt View Post
When you change from an angled servo to a flat servo typically you lose steering due to the change in ackerman. To compensate for the loss of steering most setups I have seen go to a stiffer rear spring and raise the front of the shock. So I am trying to figure out why many of the flat servo setups I have seen run the front of the shock higher. Based off of what your saying my guess would be that just changing the spring/oil combination to a stiffer setup over compensates for the loss of steering so I'm thinking in those setups they raise the shock to lessen the effect of the spring change just a bit. Does that sound plausible?
I guess the way you stated it makes sense. I normally try to make sure when I change from an angled servo to a flat servo to keep the angles on the tie rods close to the same. I have run my car again and can confirm that raising the shock on the chassis mount will take away some steering.
Old 06-23-2008, 02:49 AM   #326
Robert_K's Avatar
A few day's ago, I've also driven the Associated RC12R5..
And it's just great!. Last year I've driven the L4 Modified, but this R5 is just wonderfull. Stable, but a lot of agression on the front tires.
I was a bit bumpy track, but the car had no problems with that.
Only thing i noticed, that the side shock upper cap is a bit weak. There is not much Tread in the plastic thing. And that will make it hard to place it straight on the tube...
Hope it will get some good result's this year!
Greetings Robert Krens
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 06-23-2008, 03:11 AM   #327
RC MARKET's Avatar
use which sping best ?
RC MARKET is offline   Reply With Quote
Old 06-23-2008, 04:29 AM   #328
Robert_K's Avatar
Which spring do you mean?
I've used .22's on the front, the kit side spring's and a blue center spring (pretty hard)
Old 06-23-2008, 06:12 AM   #329
RC MARKET's Avatar
I've used .22's on the front, the kit side spring's and a blue center spring (pretty soft)
center have how many type spring ?
because HK not have , STD spring not have good feel
Old 06-23-2008, 07:39 AM   #330
Robert_K's Avatar
The Blue Asso spring is a 10.0 spring
Order Nr: 8452
See the old L4 set-up sheet for the springs with their order numbers.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
