Old 11-02-2011, 11:36 PM   #3271
Infinite 12th's Avatar
@RedBullFiXX
4 Race Nor/So Cal Onroad Championship Series
Race #1 ?
Race #2 ?
Race #3 ?
Race #1 ?
3 count with 1 throw out to accommodate people who can't make all four races
Classes
WGT 13.5/Blinky
12th mod/17.5 Blinky
TC mod/17.5 Blinky
Originally Posted by odpurple View Post
West Coast RC Raceway, La Mirada CA
Are you going to regionals O.D?
Who else is going
Talk to you later
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-03-2011, 08:36 AM   #3272
racing_jason's Avatar
Originally Posted by Rick Hohwart View Post
Mike Blackstock's TQ and 1st Place Modified set has been posted here.
Rick,
On this set up does mike use the center brace on the front end? its the first one to not have it removed that ive seen.
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is online now   Reply With Quote
Old 11-03-2011, 09:07 AM   #3273
Rick Hohwart's Avatar
Originally Posted by MattW View Post
Rick, those axle spacings you mention - what wheel is that with?? I'm just wondering if it's possible to use the longer (R5/L4) diff hub with a parma wheel and 5.1 pod.
This is with the CRC wheel. The longer hub and Parma wheel may be too wide.
Originally Posted by RedBullFiXX View Post
Of course I'm down.
Have talked to the Norcal guys and have raced at Norcal a few times already.
Killer crew up there.
But if you want Rick to show up you better include WCRC, he and the Blue team pretty much live there, and rarely show up at TQ to run on the rug.
Just a reminder...
The ROAR Region 12 indoor regional race is at TQ on Jan15 2012.
I'll be racing the Regionals. Any secret to keeping traction for a full 8 minutes?
Rumor is that the Nats will be at WCRC so will be doing some 1/12 there as well.
Originally Posted by jrp View Post
So if you remove the two shims on the diff side, will the rear end be narrow enough to be legal with CRC wheels, and if so, it would now be offset, right ?
Originally Posted by Kave View Post
I have been under the impression that you cannot make it down to 172 with the CRC tires but I could be incorrect as I do not have a car with me right now to check.
It is barely too wide by .5mm per side or so. If you are racing where this is teched you will have to file the wheel down slightly which is pretty easy to do while you are truing tires.
I find that this spacing centers the axle even with an unequal number of shims on each side. I never change the axle so it is possible that each axle is slightly different and requires different shimming.
Originally Posted by racing_jason View Post
Rick,
Thanks Jason
As far as I know Mike runs the brace.
Rick Hohwart is offline   Reply With Quote
Old 11-03-2011, 09:45 AM   #3274
thank you for the quick reply
Jason
Old 11-03-2011, 10:02 AM   #3275
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Having the OnRoad Nats back on the West Coast is cool !
Would prefer to race at Nor-Cal, but at least WCRC is closer than Jersey
As for maintaining grip for 8 mins @TQ
Magentas which worked perfectly last week.
Or Black Yellow, sometimes when the track gets sticky.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-03-2011, 10:05 AM   #3276
I would probably prefer TQ or NC
Hope that asphalt is smooth with no drop offs
What's the tire wear there?
Is this the same indoor asphalt track that was in socal 7 years ago?
Old 11-03-2011, 10:48 AM   #3277
Rick,
Thanks Jason
Yes i run the center brace....
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-03-2011, 12:20 PM   #3278
Trader Rating: 51 (100%+)
What's the benefit of making the rear axle wider?
SC5M, T5M, 22 3.0, TRINITY motors and batteries, hobbywing esc
guppy is offline   Reply With Quote
Old 11-03-2011, 04:51 PM   #3279
Trader Rating: 3 (80%+)
I'd be into it.
Tire size can vary greatly but the idea is to choose the tire size then shim the front suspension and adjust the rear axle to achieve the proper ride height.
Using tape plus the three screws is the way to install and remove it. But you can remove the taps that keep the battery from sliding out so that you can remove it this way. The tape alone will keep the batter in place.
Keep in mind that the CRC tires are a different offset than Jaco or Parma. This means the rear axle should be set up with no shims. However I use two shims on the diff side (zero on the hub side) to center the axle.
hello Rick,when you say you use 2 shims on diff side to keep centered,do you mean to keep the spur gear centered with pinion or the actual drive shaft in the center of the rear pod/car? thanks for your help.
traitor is offline   Reply With Quote
Old 11-03-2011, 06:47 PM   #3280
Maybell's Avatar
The shimming is for centering the rear tires in relation to the chassis. My axle needed .4mm more shims on the diff side for my tires to be centered.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-03-2011, 06:54 PM   #3281
Maybell's Avatar
Default front end tip
Thought I would throw a important build tip into the mix. Front kingpin shims are never all exactly the same thickness....so measure them and make sure you have the same total thickness on each kingpin. If you dont, your front droop will be off and setting your cars tweak could be interesting...
Old 11-03-2011, 07:55 PM   #3282
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Also to go with seans front end build tip with shims... measure the springs as there almost never exactly the same. Also seems that they changed brands.. als last year the springs used to be a silver spring now ther a greenish...Also i notice the newer springs last alot longer as they dont crush within 2 runs.. Another thing to measure if ur notice alot of front droop measure the size of the spring. Dont hold me to it as i dont have the notes infront of menew springs come in a round 24.8- 25.0 after they get under 24.0 to 23.8 trash them..
Originally Posted by Maybell View Post
Thought I would throw a important build tip into the mix. Front kingpin shims are never all exactly the same thickness....so measure them and make sure you have the same total thickness on each kingpin. If you dont, your front droop will be off and setting your cars tweek could be interesting...
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 11-06-2011, 05:23 AM   #3283
Radio Active's Avatar
In what units are those numbers?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 11-06-2011, 11:55 AM   #3284
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
had an interesting night last night. only thing i changed was 30wt in the side shock. car seemed to change direction a lot faster so with some practice got it around the track pretty well.
though, first heat of the night, i tapped and was out with a busted upper link turnbuckle. I got all the plastic bits for the front end but never thought id break a titanium turn buckle..
no one had a associated one, but i managed to make a larger diameter one work by reaming out the eyelet and a new arm.
was weird though. turnbuckle broke off cleanly at the arm side..
won the next qualifier without major event. a few taps but nothing major.
went on to place second in my main, bumped to the next one and coming around the sweeper, went wide, hit the wall and wheel went flying lol.
broke the axel.
never thought id break the metal parts so easily.
aside from the turnbuckle end broken in the arm, the arm was intact, and the steering knuckle is intact.
oh well, the night ended nice at least. we do raffles at the end of the night with prizes. won a new crc audi body. my speed12b was getting pretty mangled so this is good stuff.
only my second night of 12th racing, so not bad results aside from busting stuff i thought unbustable.
valk is online now   Reply With Quote
Old 11-08-2011, 12:15 AM   #3285
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Did well with my first carpet race this past weekend. I am happy with the way my 12r5 handled. I ran the 17.5 non ramped class with about six or seven other guys. I got the fastest lap and then they decided it was bogus because the next lap was the same and I accidentally cut a corner. ha Oh well I had a blast. The groove came in and magenta/magenta worked out well. Learning to take my time with making sure everything is set up right and working smoothly. I had forgot how important it is to be so technical when setting up these cars.
Josh-n-ya is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
