Old 11-01-2011, 11:51 PM   #3256
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
My question is what would someone recomend (what color of compound tires) should I start with on a carpet track. The track hasn't been run on in about 6 months so pobably no traction for now. Looking at previous setups it looks like double pink up front and yellow or magenta rear. Is this correct? I will be using CRC brand because thats what they have at the track for now. LMK thanks
Josh-n-ya is offline   Reply With Quote
Old 11-02-2011, 02:39 AM   #3257
303slowdown's Avatar
Trader Rating: 24 (100%+)
That sounds like good combo to start with, since the track hasn't been ran on traction will be very low so gray front yellow rear is also a good combo for low traction ,if that gives you to much steering black fronts will calm the front end down.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-02-2011, 05:59 AM   #3258
Originally Posted by ToysRUsKid View Post
Is there an easy way to get the battery in and out of the inline chassis? Or at least which 3 screws will make it easy?
You answered your own question, removing the top plate facilitates battery removal.
AreCee is offline   Reply With Quote
Old 11-02-2011, 11:19 AM   #3259
Rick Hohwart's Avatar
Originally Posted by Infinite 12th View Post
You went without me OMG ...lol
I have an idea for this next year so brace yourself here it goes
We can call it the Death Star Series *Star Wars Theme*
A Nor-cal/So-cal series like the olden days (4 races)
It used to be C.A.R. (California Auto Racing) vs. S.C.A.R. (Southern California Auto Racing)
Hohwart, Neisenger, Garnue, the associated guys, checkpoint guys and everybody would go to these 4 races. Two in so-cal and two in nor-cal
Would be great for 12th scale and to connect So and Nor-cal guys
Only 5 hrs drive and some fast food drive through (Del Taco) on the way separates us ...lol
Are you in?
I can organize the stuff up here and we got to race asphalt also
I love my asphalt...
I'd be into it.
Are the designers also considering the double wishbone ft end also
For this "new" car
Originally Posted by daveb View Post
It's been awhile since I've ran 1/12th scale and I just built an 12R5.1. I've got brand new tires but I've noticed with the supplied front bulk head shims I'm going to get a really high ride height. I've got one of the thick spacers under the bulkhead and my height in the front is like 7.72. My question is my tires are at 48, what should I true them down to for a good starting point? Or do you just buy a bunch of shims for the underside of the bulk head?
Tire size can vary greatly but the idea is to choose the tire size then shim the front suspension and adjust the rear axle to achieve the proper ride height.
Using tape plus the three screws is the way to install and remove it. But you can remove the taps that keep the battery from sliding out so that you can remove it this way. The tape alone will keep the batter in place.
Keep in mind that the CRC tires are a different offset than Jaco or Parma. This means the rear axle should be set up with no shims. However I use two shims on the diff side (zero on the hub side) to center the axle.
Rick Hohwart is offline   Reply With Quote
Old 11-02-2011, 11:47 AM   #3260
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
So if you remove the two shims on the diff side, will the rear end be narrow enough to be legal with CRC wheels, and if so, it would now be offset, right ?
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 11-02-2011, 12:24 PM   #3261
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
I have been under the impression that you cannot make it down to 172 with the CRC tires but I could be incorrect as I do not have a car with me right now to check.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 11-02-2011, 12:30 PM   #3262
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Thanks guys, I'm assuming the top deck is the front top deck the shock is attached to!? Fairly new to 12th scale.
Also, that center shock, is there a specific length that works? mine seemed too long and was pushing the rear pod back.
I'd be into it.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 11-02-2011, 01:09 PM   #3263
Yes, that is the top deck.
Check to see if you have the rod end screwed on all the way and that the shaft is fully seated in the rod end before tightening the set screw. There is only one length of shock shaft so just be certain you have the rod end listed in the lipo conversion sheet.
Old 11-02-2011, 02:53 PM   #3264
Mike Blackstock's TQ and 1st Place Modified set has been posted here.
This is the setup i ran this past weekend at the halloween race. Track was high bite and this was the best setup to date i have had for the new lipo conversion...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-02-2011, 03:34 PM   #3265
Send a message via ICQ to MattW
Rick, those axle spacings you mention - what wheel is that with?? I'm just wondering if it's possible to use the longer (R5/L4) diff hub with a parma wheel and 5.1 pod.
MattW is offline   Reply With Quote
Old 11-02-2011, 03:40 PM   #3266
Infinite 12th's Avatar
It would be a neat build to have the battery be inserted from underneath the car all stealth like. Then two screws could be used to remove a lipo sized plate
Just a thought
@Rick Hohwart
I personally would think it would be radical if you attended this 4 race series between Nor & So cal
If you raced 12th it would be totally radical ...lol
Let's call it the "The Totally Awesome Cali On-road Series"
I will start a dialogue with Kevin and Eric
If David is into it maybe he can coordinate the TQ part of it
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-02-2011, 05:11 PM   #3267
Just a thought
There have been some tweak issues with that design in the past. Perhaps they could perfect it?
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-02-2011, 08:20 PM   #3268
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
@Rick Hohwart
Of course I'm down.
Have talked to the Norcal guys and have raced at Norcal a few times already.
Killer crew up there.
But if you want Rick to show up you better include WCRC, he and the Blue team pretty much live there, and rarely show up at TQ to run on the rug.
Just a reminder...
The ROAR Region 12 indoor regional race is at TQ on Jan15 2012.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-02-2011, 08:35 PM   #3269
Originally Posted by RedBullFiXX View Post
Of course I'm down.
Just a reminder...
Yea it's awesome here but what is WCRC?
Old 11-02-2011, 08:45 PM   #3270
odpurple's Avatar
West Coast RC Raceway, La Mirada CA
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
