Old 10-13-2011, 09:41 PM   #3151
Trader Rating: 51 (100%+)
Is it better to run a novak smart boost or a receiver pack? If a receiver pack what brand and part number. i run a tekin rs if that helps
SC5M, T5M, 22 3.0, TRINITY motors and batteries, hobbywing esc
guppy is offline   Reply With Quote
Old 10-14-2011, 07:39 AM   #3152
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Unless you're running a low turn mod motor on a high traction surface, boosters are fine, and obviously don't need any maintenance once installed.
http://www.tqcells.com/
Novak has a new 1s booster that also looks interesting.
http://www.shopatron.com/products/pr...5477/135.0.1.1
12th Scale Racing is Alive and Well in So Cal
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-14-2011, 07:44 AM   #3153
Originally Posted by Radio Active View Post
.5 drop off at 8 min huh? I somehow keep managing to pull my fastest lap on the last lap of the race. I can't work out if my problem is that I'm too conservative on motor set-up, whether I find the car easier to drive fast when the edge is taken off or if the issue is psychological.
It's not uncommon to run good laps at the end of a run on a low traction surface, or with an ill handling chassis.
But if that's happening where everything is working fine, you will need to be less conservative on your motor setup.
Old 10-14-2011, 08:13 AM   #3154
Buckaroo's Avatar
Originally Posted by Madulla View Post
New to 1S racing. What motor temps should I be looking at? I know in TC I want to be around 160F, is it the same for 1S. Running 17.5 Boosted with a roll out around 80mm. I am playing around with the boost settings and wondering how hot (more boost) I can get without slowing the motor down.
Originally Posted by RedBullFiXX View Post
Yes, it's about the same on temp.
You want the fastest lap you can get, with no more than .5s drop at 8 mins.
That's a good setup, and it's more important than temp.
I'd say it more depends on the motor. X12s like it hot. All other motors will show a significant drop off in performance above 140ish. 1S doesn't have the balls to let the motors push hard once they get near max temp.
If you can get a set up that gives no more than a .5 drop off at 8 minutes, you're not only a bad ass tuner, you're a bad ass driver!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-14-2011, 08:20 AM   #3155
Old 10-15-2011, 10:18 AM   #3156
Infinite 12th's Avatar
I'm learning to read the setup sheets and can't understand what Heberts notes in his IIC setup it says 2mm on top arm
http://www.teamassociated.com/pdf/ca...t_iic_2011.pdf
Thank you
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-15-2011, 10:26 AM   #3157
Maybell's Avatar
Thank you
I think he is talkn about making the upper arm longer by placing 2mm spacers between the upper arm mount and the bulkhead.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 10-15-2011, 10:38 AM   #3158
Which would mellow the steering correct?
Old 10-15-2011, 11:17 AM   #3159
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
Can someone post the correct rear bulkhead part numbers that will fit on the conversion kit?
Dorian Tisdale - Professional RC Driver Wannabe
RC America \ DeSoto Racing \ XRay \ Novarossi
www.tsrcar.com \ Red Mosquito raceway \ www.racersoftoledo.com \ www.midwestseries.com
ToysRUsKid is offline   Reply With Quote
Old 10-15-2011, 11:21 AM   #3160
Use the same part numbers that the 12R5.1 kit uses not the 12R5 or 10R5.
AreCee is offline   Reply With Quote
Old 10-15-2011, 11:58 AM   #3161
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
first night out with the car went pretty well. just have to get used to how much steering these things have. lots of my incidents were just turning in too early and smacking the apex.
didn't change anything on the car except fixing the tweak which was wayyy out causing the car to pull on the straight.
will have to fab up some kind of battery strap though. dealing with tape to change the battery between races is no fun.
valk is offline   Reply With Quote
Old 10-15-2011, 12:13 PM   #3162
Maybell's Avatar
Yes, less camber gain should be smoother.
Old 10-15-2011, 12:17 PM   #3163
Maybell's Avatar
8536 and 8537. Dont forget you need the 4687 post as well.
Old 10-15-2011, 12:22 PM   #3164
The only video that I've seen of him in the main barely gave a chance to see it roll but in what I saw it seemed to take slightly longer in transitions from left to right which kinda translated to me it was very smooth
Naoto's car seemed to transition quicker but seemed to have less inertia through the corners hence Naoto's car seemed more aggressive and Keven's seemed more in control kinda or stuck in whatever position it was in but I didn't see it definitely having more steering just more stable in whatever corner angle
I mean I'm not even got my car on track yet but I could tell the difference in the way the inline car looked in contrast to non-inline
It's amazing how sensitive 12th cars are to configuration's let alone settings...lol
I'm not sure I'd bet on the inline for being faster than non-inline but perhaps a different style of driving for 12th scale drivers although I'm sure the next set of kits will probably be inline?
The inline also reminds me of a car you could put massive motor in cause it's so stable or stuck in the rear
So maybe people will figure out inline works better some places and non-inline others...lol
Old 10-16-2011, 08:13 AM   #3165
ToysRUsKid's Avatar
Hmmm...I added up all the parts, looks like it's cheaper to buy the 12R5.1 kit and the lipo conversion compaired to building the kit from parts.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
