Old 10-11-2011, 08:13 PM   #3106
Originally Posted by RedBullFiXX View Post
I'm with infinite on this one.
The side shock end should be threaded all the way in, otherwise it will limit roll to one side.
When you installed the center footbal pivot, did you make sure the pod was absolutely free of bind ?
Also, if you have decent grip carpet, 44mm front is quite large, what compound tires to you have on there ?
For comparison.
Was just looking at your wiring in this pic... are you running a booster with this setup? Or are you just using the LRP's internal booster?
Btw, wiring looks incredible!
JamesL_71 is offline   Reply With Quote
Old 10-11-2011, 08:14 PM   #3107
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks, using the internal booster from LRP.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-11-2011, 08:30 PM   #3108
Johnn27's Avatar
Trader Rating: 66 (100%+)
Default re:set up
Thanks, I will make the changes and report back and oh yes the track seemed bumpy!
Johnn27 is offline   Reply With Quote
Old 10-12-2011, 07:21 AM   #3109
Originally Posted by traitor View Post
good eye didnt notice that.as i am a newb to this I really appreciate the help,I will fix and test on wednesday
traitor, make sure the motor wires have plenty of clearance on the pod.
They look fairly tight in this pic ?
Old 10-12-2011, 08:30 AM   #3110
Trader Rating: 3 (80%+)
Thanks redbull ,i will double check and do the changes you and everyone suggested today. I also wanted to ask you redbull ,what body do you use? Thanks again.
traitor is offline   Reply With Quote
Old 10-12-2011, 08:32 AM   #3111
The inline conversion instructions seem to call for 2x 2mm spacers under the center shock ballstud and only 1x 2mm spacer under the set-screw mounted pivot ball for the side shock.
I see in the above pic there is only 1x 2mm spacer under the center shock ballstud.
Is this what most people are running? What about the side shock? How many spacer in general are you guys using?
Old 10-12-2011, 08:36 AM   #3112
Infinite 12th's Avatar
Curious, did Hebert run the inline or associated guys in general
Also was Naoto's car any different than from the worlds
Pictures?
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-12-2011, 08:43 AM   #3113
I just noticed that in the instructions aswell for center shock it looks like they suggest 2 2mm washers? looking at my car (picture) with 2 shims under side shock it makes the shock level,which i would have to assume is what you would want?
Old 10-12-2011, 09:03 AM   #3114
(1) 2mm spacer for side shock, so it will have full clearance of the upper pod deck.
Pictures?
Yokomo never seem to run the same car twice, so many little changes ?
All the Team AE drivers, and anyone that had access to the inline car at vegas, would have been running it.
It was a night and day difference from the 5.1 on the extreme high grip surface, no inside lift whatsoever.
No tuning around an issue that wasn't there.
So fun to drive.
The Rev7, and New On-Point cars were silky smooth as well.
Build to the directions, and you can't go wrong.
Old 10-12-2011, 06:23 PM   #3115
I really like the BlackArt Audi R8c LMP
It's balanced perfectly, and looks more like a race car then the more popular AMR12.
The R10 is also a great low downforce open cockpit body for Blinky.
Old 10-12-2011, 06:32 PM   #3116
=FLIP='s Avatar
Trader Rating: 24 (100%+)
the inline lipo conversion on high grip is a must swaped to this chassis mid event at iic and was a dream to drive (once redbull helped out)
thanx for ya help at iic was awesome to get good setup advice.
will be trying the inline chassis next week on the pavement intrested to see how it goes on low grip.
--------------------------HOBBYWING----------PROAMP LIPOS----------------------------
-EAD- Racing NEED SPEED GET SOME EAD-
=FLIP= is offline   Reply With Quote
Old 10-12-2011, 06:52 PM   #3117
If anyone saw what Naoto (Inline/Not inline) was running or has pic let me know
Old 10-12-2011, 07:22 PM   #3118
Matsukura R12
http://www.rccaraction.com/blog/2011...-winning-cars/
and
Lemieux Xray12 Prototype
Old 10-12-2011, 07:52 PM   #3119
I love that rear axle with deep wheel offset
And it looks like he's running dive in ft
4T motor with super stock lrp...lol
no receiver pack just 3 caps
They look like the soft black side springs and soft top shock springs
Curious what tire combo he had
And where is ft end reactive castor holes for the top arm...lol
rear shock reversed from rc125.1/2 setup
Totally stock R12
Lemieux also using super stock but with receiver pack
Thanks RBF
Old 10-12-2011, 09:39 PM   #3120
What are the most popular 17.5 blinky bodies for 12th?
Still the AMR12?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
