Old 09-21-2011, 05:10 PM   #3046
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
jeez by the time you get that and a lipo kit you have a WHOLE Gen XL.
whats the advantage of those damper tubes?
valk is offline   Reply With Quote
Old 09-21-2011, 05:43 PM   #3047
VAzRACER's Avatar
Trader Rating: 17 (100%+)
Originally Posted by KHoff7 View Post
Looks dialed
Looks even more dialed in person!
Reflex Racing / Psycho Cells
VAzRACER is offline   Reply With Quote
Old 09-21-2011, 06:20 PM   #3048
We covered it on one of the last few pages of the 1/12 forum thread.
JamesL_71 is offline   Reply With Quote
Old 09-24-2011, 03:35 PM   #3049
Hallgm's Avatar
Parts are coming can't wait to put some of this info to work
Hallgm is offline   Reply With Quote
Old 09-25-2011, 09:15 PM   #3050
Johnn27's Avatar
Trader Rating: 67 (100%+)
Default damper tubes
Has anybody had problems with those damper tubes breaking easily if the car takes a shot?
Johnn27 is offline   Reply With Quote
Old 09-26-2011, 08:24 AM   #3051
I've been running these damper tubes for years and have never broke one. You take a big hit the ball cup will simply pop off. And still that take A LOT to do.
JoelV is offline   Reply With Quote
Old 09-26-2011, 08:26 AM   #3052
Infinite 12th's Avatar
Just stay out of the wrong neighborhood and your car should not get shot ...lol
Infinite 12th is offline   Reply With Quote
Old 09-26-2011, 02:43 PM   #3053
Trader Rating: 20 (100%+)
Before I buy some ceramic diff balls for the 12R diff. I recently switched to gear diffs for my touring car and have a couple set of 3mm ceramic balls that im not using.
Will 3mm ceramic diff balls fit the 12R?
goots is offline   Reply With Quote
Old 09-26-2011, 02:51 PM   #3054
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I don't think so... .125 dia is standard diff ball and 3mm is smaller,,you may have to change to metric spur gear...
OVA is offline   Reply With Quote
Old 09-27-2011, 01:34 PM   #3055
valk's Avatar
I know this information is somewhere in this thread but a search disnt give me the reaults i wanted so....
My 5.1 came with a 96 spur what size pinion range should i pick up for 17.5 boosted? Or if i need new spurs, is there a type to get? New to pancars. Only just started to figure out the touring car before season ended.
Old 09-27-2011, 02:24 PM   #3056
We gear to a 75 to 80mm rollout for a smallish 60'x35' track.
AreCee is offline   Reply With Quote
Old 09-27-2011, 02:56 PM   #3057
tobamiester's Avatar
Trader Rating: 268 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
96 is usually kind huge for what most people need in 1/12. The gent above who's 75-80mm rollout is about exactly what I ran on a couple of smallish tracks a year ago.
Use a rollout calculator like gearchart.com. But for example, with a 44mm Rear Wheel, a 76T Spur, and 44T Pinion will get you on the upper end of that rollout range.
tobamiester is offline   Reply With Quote
Old 09-27-2011, 05:04 PM   #3058
What's the proper way to read ride height for the rear of the car and how much preload should be used on the center shock spring.
Old 09-27-2011, 05:12 PM   #3059
You slip a ride height gauge under the rear of the car while it sits on a flat surface and read the number nearest the lower pod.
Adjust the preload so the middle of the chassis is the same height or very near to that of the front and rear.
Old 09-27-2011, 05:15 PM   #3060
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Tons of info HERE for setting up and tuning your 12th scale car
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
