Old 09-19-2011, 05:05 PM   #3001
Originally Posted by Infinite 12th View Post
What servo fit's perfectly in RC125.1?
Futaba? Hope so
Futaba 9650, perfect fit.
AreCee is offline   Reply With Quote
Old 09-19-2011, 05:07 PM   #3002
Infinite 12th's Avatar
Thanks this is such a great site
Edit:
Says it used with helicopter and airplanes...lol
http://www.amainhobbies.com/product_...rce=google_ext
Infinite 12th is offline   Reply With Quote
Old 09-19-2011, 05:29 PM   #3003
KHoff7's Avatar
Originally Posted by JoelV View Post
Damper tubes?
Yes please
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-19-2011, 05:51 PM   #3004
rc_square24's Avatar
Clean R5.1, tire truer, 1S batteries etc for sale
M11x / LRP Touch / Photon / 12R5.1 / Batteries / Tire Truer / x12 13.5 / ESC + MORE!!
rc_square24 is offline   Reply With Quote
Old 09-19-2011, 06:52 PM   #3005
Picking up an R5.1 this weekend, not doing the Li-Po conversion as I will only be racing stock...any build tips? I know there's usually something you won't know about the first time you build a kit...thanks in advance for the help...
anthonyscardina is offline   Reply With Quote
Old 09-19-2011, 07:03 PM   #3006
Who know's the inline might be faster for stock...lol
But when building a 12th I get some very light sandpaper and slightly sand the edges of the graphite so it's little smother besides that just make sure everything is functioning smoothly
I'm sure you'll do fine
And install stuff so the pod does not hang up on any wires besides that 12th are the simplest in compare to TC
Good luck
Old 09-19-2011, 07:15 PM   #3007
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Gratz on the new R5.
Lots of build tips HERE
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-19-2011, 07:34 PM   #3008
Take your time building the shocks, follow the instructions and don't cross thread the caps.[GVIDEO][/GVIDEO]
Old 09-19-2011, 07:39 PM   #3009
AreCee, didn't you race at UG and Harbor?
yeah I've heard the shocks cross thread easy...I know about polishing the kingpins and reaming the arms where the balls go in (although not too sure how to ream them properly) and I do own a "ball popper" and to set the pod free, set the servo flat for less "twitchy" handling...
Old 09-19-2011, 07:53 PM   #3010
Default Cheap tweaking
Hey I have a 12r5 and 10r5 and I was wondering if there is a way to do all the tweaking stuff without a tweakboard(camber/caster stuff and all) dont really have the money to spend on it so i was just wondering if there was a cheap way of doing it
Thanks for advice in advance
Dahtmaxx is offline   Reply With Quote
Old 09-19-2011, 08:01 PM   #3011
I got my setup board for less than 20 bucks...it's a roll cart topper from the container store.
http://www.containerstore.com/shop/e...000928&N=80348
Then just get a decent camber gauge, usually about 20 bucks...
for rear tweak, squish the suspension a couple of times and let return to neutral on its own. Then, put a quarter flat on top of each front wheel and pick up the very center of the front with the tip of an exact-o knife and see which quarter falls off first, and that will tell you which side spring to adjust...
Old 09-19-2011, 08:03 PM   #3012
Any flat surface will do.
I've seen some of the worlds best drivers set everything up with nothing more than a straight edge for vertical & camber check, and callpers for toe and track measurements.
Caster settings on the R5 are simple, no special tools required.
Old 09-19-2011, 08:05 PM   #3013
You can check tweek with an Xacto knife and two quarters. Set the car on a flat board put a quarter on top of each front wheel, place the blade in the little hole at the front of the chassis and lift. If both quarters fall at the same time there is no or very little tweek. If one quarter fall first adjust the side spring screw opposite the side the quarter fell off until they both fall off at the same time.
Old 09-19-2011, 08:10 PM   #3014
Yep, that was a couple years ago. I race mostly in Danville at Jtec Loft. Great bunch of racers and much better ambiance than UG.
BTW: flat is the only way to install the servo in a RC12R5.x.
Old 09-20-2011, 12:35 PM   #3015
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
This will be my first season running 12th. Ill also be the only associated running. What spares should i get for my box?
valk is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
