Old 09-10-2011, 09:31 PM   #2971
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by CypressMidWest View Post
He's also due for another Thanksgiving week trip to Cleveland
Thanks guys
Since coming back to RC 2 years ago, I'm having more fun than ever.
The local track here, TQRC is epic.
12th scale is the only racing that could have brought me back.
So stoked it's gaining more & more momentum again.
Cleveland Turkey race... Don't tempt me Cypress.
That race used to be awesome, how's the turnout been the last few years ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-11-2011, 02:32 AM   #2972
Infinite 12th's Avatar
Originally Posted by RedBullFiXX View Post
Thanks guys
http://www.youtube.com/watch?v=ANcBn...eature=related
What was the name of that track in riverside that was carpet in basketball court
First time I met you and Barry was it called Bob and Jim's
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 09-11-2011, 08:45 AM   #2973
If drive in high traction carpet, what shore tyre should I use?
ioxqq is offline   Reply With Quote
Old 09-11-2011, 09:17 PM   #2974
Magenta are the most popular compound for that application.
Old 09-12-2011, 06:17 AM   #2975
And purples when the traction really gets high.
AreCee is offline   Reply With Quote
Old 09-12-2011, 07:41 AM   #2976
Default RC12R5.2 Side Lipo
Setup update for running Lipo sideways (Not Inline).
After another day of testing at TQRC
For those looking for an "optional" setup.
The new longer - wider front end, chassis seems better (imho) with more weight on rear than 5.1, this increased steering, with improved balance for 8 mins.
Old 09-12-2011, 08:56 AM   #2977
So your using the inline chassis but with non-inline placement?
Lap times?
Can you explain droop for front and back? Drawing?
I never remembered messing with droop with 12th at least not on purpose...lol
What does Ride height adjuster mean? 1.75?
What's the turnout for TQRC on fridays, sun?
Earlier in a post I asked what that track in riverside was called? Can you remember
Did you give up on the inline
Old 09-12-2011, 11:41 AM   #2978
Lap times?
Same
Spring not fully pre-loaded
Axle ride height adjust block
Depends on the weekend, Fridays are cool due to the longer hours Sean keeps the track open, but hard to get to when you live 1+ hrs away without traffic
Bob & Jims Rc World
No, my only experience with the new car has been inline, wanted to see how it reacted to the old sideways lipo. With so many changes, it's difficult to pinpoint what the inline lipo configuration affects, and what it does not.
This way I learned a lot about the rest of the refinements on the 5.2 chassis.
Old 09-12-2011, 11:23 PM   #2979
BoneCrusher's Avatar
Default setup help please
Just getting back into the indoor carpet season soon. Can anyone suggest what tires to use for Med-High Ozite Carpet track for 17.5 boosted and for 10.5 boosted Classes? I run Jacos but giving me shore ratings would be great too!
What I remembered was I tried yellow rears and black/purple fronts for 17.5 Boosted ran pretty good.
Thanks.
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-13-2011, 11:35 AM   #2980
Robert_K's Avatar
Guy's
After many years of 12th scale racing and 2 years racing with the 5.1 I'm doubting.
I've got two R5.1's and I want to have an inline update on my R5.1's
I think the Assocaited Alluminium is pretty weak, and the pod or the motormount will bend with (hard) crashes.... I really don't like that. I can work with the pod bending, but I dislike the motormount bending. I think it's to weak.
But I really like the rest ofthe complete car, the front end, the dampers, all of it!
Now Markus Mobers has it's update from On Point, and I really really dislike the collor, and dislike the damper tubes. I never had a problem with the Associated side damper. But I can understand that this pod will deffently tweak less easy, and I hope the Aluminium is stronger.
But the Assocaited update still has the weak aluminium pod. But then again it's nice and blue (I know it's not a good point, but I just love the blue) and has the nice side damper. And mabe I could by a Team Tamale Motormount....
What would you choose or advise me.
Regards
Robert Krens
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 09-13-2011, 11:50 AM   #2981
I've been using the 5.1 and WGT for two years at a track that mixes all levels of driver in the same heat. We have had some spectacular crashes and somehow the AE motor pods seem to remain straight. They must not know how weak they are. Maybe some of the CRC gang could show them how easy it is to bend and they do that quite well.
I suppose if you try hard enough you could bend anything but my guys are going into their third year as straight as an arrow.
Old 09-13-2011, 12:31 PM   #2982
Robert_K's Avatar
Well I drive on a lot of tracks thru all of Europe. But my home track has wooden track barriers which are screwd down. So when I make a mistake even small, the punnishment is hard
And I'm for sure not the only one with a tweaked pod sometime
Robert
Old 09-13-2011, 12:42 PM   #2983
Robert
Only wood, we should have it so easy. Try support columns of concrete and steel mix in a few plumbing risers, an 18" high wooden barrier and downspout tubing screwed down as lane markers along with beginners in the same heat with seasoned drvers and you can imagine the mayhem.
Our track is a bit short at 65' so the top speeds are not as high as longer tracks.
Admittedly I have broken the rear bearing supports and smashed rear bearings but the plate isn't bent and is still as straight as new, I rebuilt the car earlier this month and checked the side plate for square.
Nice thing about the link chassis is that chssis tweak is almost gone.
Now watch, I'll end up bending it this year.
Old 09-13-2011, 07:31 PM   #2984
Thanks.
Ivan
Black / Yellow is still a very good combo.
Magenta tires can drop lap times if the conditions are right.
Old 09-13-2011, 10:03 PM   #2985
CypressMidWest's Avatar
Thanks guys
Turnout's been pretty decent. 12th scale is still big at The Champs. 17.5, 13.5, Masters (over 35), and Mod all boosted (at least for this year). Hebert, Cyrul, Blackstock, Lemieux etc in Mod, always fun to watch. Stock was pretty strong last year, and 13.5 was big as well. Hopefully in spite of all the current issues, the race will be good this year as well.
Team CRC, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
