Old 08-23-2011, 04:06 AM   #2941
Buckaroo's Avatar
This may sound stupid, but how wide is the tape slot? (I got an Exotek touring car chassis recently, and it's slots needed to be lengthened drastically (12mm, with standard battery tape 16mm), so I'm sorta sensitive to that right now )
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 08-23-2011, 07:24 AM   #2942
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
23 mm
Something else cool with the chassis is the slotted servo mounts.
Any servo will easily fit this car.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-23-2011, 07:42 AM   #2943
Buckaroo's Avatar
Originally Posted by RedBullFiXX View Post
23 mm
Good deal, thanks!
Tom Keith
Old 08-23-2011, 07:52 AM   #2944
I just picked up a couple Pro-Tek 1S packs and the 4mm bullet clears the shock, however, it is still a PITA to remove the battery. I did find it easier to do if you remove the top plate or pivot it out of the way.
The bullet tubes in the Reedy pack are further inboard than the Pro-Tek packs making it more difficult to plug in.
AreCee is offline   Reply With Quote
Old 08-23-2011, 01:31 PM   #2945
piper48
Guest
Posts: n/a
Default rollout
Hello all. New to 1/12 scale and was wanting to know what the formula is for Rollout. Also what's a standard diameter size for front and rear tires? One more question...our track is roughly 100'x60' technical layout, 13.5 Ballistic, blinky mode. Any gearing suggestions is appreciated. Thanks
Old 08-23-2011, 05:04 PM   #2946
Welcome to 12th scale, the most awesome class of all
I use gearchart.com for rollout, they have all the info and charts you need.
Tires size will vary depending on grip level, but 42mm front, 44mm rear is common.
I'll take a guess at around 75 to 80mm roll to start with that setup.
Check with the fast guys at your track to get the best info though.
There may be some ideal gearing/timing setup that will rock.
If you want to study up on setups and stuff, there is a large list of links and info HERE
Have fun.
Old 08-23-2011, 11:14 PM   #2947
piper48
Guest
Posts: n/a
Have fun.
Thanks for the input and info. Our indoor carpet season hasn't started yet so I'm trying to get a head start on setup before I start bugging the fast guys. Thanks again.
Old 08-24-2011, 06:52 AM   #2948
It's going to be a good indoor season.
Lots of new products coming out.
12th scale is Alive and Well indeed
Old 08-27-2011, 04:16 PM   #2949
transplantlife's Avatar
Trader Rating: 43 (98%+)
Well guys picked up my first 1/12 r5.1 with lipo chassis. Guys wanted to ask if any of you would be kind enough to post a base line carpet set-up. Thanks for the help.
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 08-28-2011, 07:55 PM   #2950
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
RedBullFixx posted some setup help a few posts back.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 08-28-2011, 08:10 PM   #2951
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
question..
i picked up a used 5.1 with onpoint chassis. just got my savox 1250mg servo to put in, and the servo spline isnt centered in the car. is this going to cause a problem if i make one arm longer to compensate, or is there an adjustment i need to do? seems like the second set of servo mounting holes would be too small.
valk is offline   Reply With Quote
Old 08-28-2011, 09:09 PM   #2952
Infinite 12th's Avatar
Default Dude
Dude that inline associated conversion looks amazing.
How is it working in comparison to normal? Indoor/Outdoor
What was the first things people noticed. Did tires change?
Is it the norm now?
Infinite 12th is offline   Reply With Quote
Old 08-30-2011, 07:26 AM   #2953
RC MARKET's Avatar
Associated released LiPo Conv. Kit & Parts
RC MARKET is offline   Reply With Quote
Old 08-30-2011, 07:44 AM   #2954
Chaz955i's Avatar
Originally Posted by valk View Post
question..
This is what I do and may help. Make sure all your electronics are wired and ready to go. Turn on transmitter and make sure all steering trim is set to 0. turn on car so steering servo is powered up. If it wasn't centered it will auto center at this point. while leaving all the electronics switched on I will then install the servo saver. It should be pretty close to centered. if not I will center with the steering trim adjustments on the radio. Unless something is seriously out of whack you shouldn't need to add very much trim to get things centered. The tie rods should be equal. I'm sure someone will post an even better way of doing it but so far this has worked for me. Good luck.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 08-30-2011, 07:10 PM   #2955
Is it the norm now?
Pics and some info from first track day HERE
I wouldn't say it's the norm now, the inline lipo chassis design has only just been released onto the market.
We shall see perhaps in 6 months to a year if it catches on ?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
