Old 08-14-2011, 02:32 PM   #2911
What side springs are you using? I ended up using silvers with a gold center on the 5.1. 30wt center 20wt side.
I'm thinking of using the blue center like you have. Front springs are up for grabs now. I plan to start with the .020 and see how it works.
I should have it done in a few weeks but the track isn't set for road course just oval for the summer.
AreCee is offline   Reply With Quote
Old 08-14-2011, 02:52 PM   #2912
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
After putting it on the digital scales found some interesting info
Overall weight & balance same as 5.1
672gr ready to race without body, TRC Magenta tires trued to 42Fr, 44Rr
This is with the heavy side of the lipo forward, same as forward position on 5.1
Fr44%-Rr 56%
I use blue side 40wt, blue center 25wt on the 5.1, .020 front springs with 30k lube.
Will start with the same settings on the 5.2
btw.
It balances left to right perfectly with the electronics I have been using.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-14-2011, 03:07 PM   #2913
GWH74's Avatar
What was the Front/Rear weight bias with the standard chassis?
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 08-14-2011, 03:13 PM   #2914
Same.
Old 08-14-2011, 03:43 PM   #2915
Thanks RedBull.
I won't have any balance issues side to side with my electronics; Tekin RS, Spektrum 3500 and 2S LiFe pack.
I will step up the sides to blue and see how that works.
The track I race at is a bit bumpy and has several tight turns which is why I use the shock oils I have.
Old 08-14-2011, 06:15 PM   #2916
Thanks RedBull.
I run silver side springs for outdoors, blue on carpet.
Our indoor track is very smooth, with high grip.
Old 08-15-2011, 03:47 AM   #2917
Robert_K's Avatar
Redbull
Do Bodies still fit from the 5.1 on to the "5.2"?
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 08-15-2011, 06:36 AM   #2918
Originally Posted by Robert_K View Post
Redbull
Regards Robert
Unfortunately not, the 2mm wheelbase extension is also added to the body post distance.
It's not much of a difference, but just enough.
The rollover post is a lot further forward too.
I guess you could make it work if you had to, but it would not be quite right.
Old 08-15-2011, 07:27 PM   #2919
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Are the wheel hubs different from the original r5 to the r5.1?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 08-15-2011, 07:44 PM   #2920
Look back in this thread HERE
Old 08-15-2011, 07:49 PM   #2921
i have a question about the center shock..it is driving me nuts.What other shocks can be used with this car if anyone knows?
www.indoorchamps.net
www.teamcrc.com
www.spektrumrc.com
www.liverc.com
bill941 is offline   Reply With Quote
Old 08-15-2011, 07:54 PM   #2922
RAL
RAL's Avatar
Thanks Dave,
I poked around a bit and looked at the exploded views online.
Looks like that shock standoff is actually part #4688.
And diff hub part#4608 and cone spacer #4609 are different as well. I'm trying to bring a 12r5 up to "current" status. LOL. Quite a list of parts!!!
Exploded views:
12R5.1
http://www.petitrc.com/reglages/asso....1_Drawing.pdf
12R5
http://www.petitrc.com/reglages/asso...R5_Drawing.pdf
Old 08-15-2011, 08:34 PM   #2923
RacinJ's Avatar
I love these shocks. Very simple and last. What is driving you nuts?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 08-15-2011, 09:13 PM   #2924
can't seem to get the top thread on correctly it also seems to have very little movement to it has well.I have a rebuild on order should be here in few days...I going to rebuild it but I was wondering what else I may use just in case.
www.teamcrc.com
www.spektrumrc.com
www.liverc.com
Old 08-15-2011, 09:39 PM   #2925
PutAwayWet's Avatar
Ah...yes. The 12R5 shock cap.
My best technique is to fill the shock with oil to just above the lip where the inside plastic ring seats. Pump the piston to make sure the reservoir is full and not trapping any air. Make sure the oil is bubbled out. Gently seat the plastic ring on the inside lip with the tip of a 1.5mm hex driver. A little oil should force itself around the ring. Lightly dab it out with the tip of a shop towel. Slip the o-ring over the piston shaft (I've long since caved in and just use new o-rings when I rebuild the shocks. It's so much easier, as they do swell after being in the shock for even a little while. Green Slime them. O-rings are a cheap consumable.)
The end cap: Hold it lightly so you can feel the threading. Lightly press it down on the threads and twist it backward. You should be able to feel a subtle click--maybe not even a click--more like a snick--when the start of the threads pass over each other. From right there, gently thread the shock cap on. If it's easy and goes right on, you should be good. If there's any resistance at all, don't force it! Just back it off until you feel the thread snick on your finger tips and start it again.
A properly built 12R5 shock lasts a long time. I like them a lot. I think the main frustrations are experienced when guys rush the initial build and cross-thread the end caps, or if they try to reuse swollen o-rings and, again, can't get the caps to seat properly.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
