Old 07-09-2011, 04:57 PM   #2881
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Radio Active View Post
I think there is a reason this is a conversion kit, rather than a new kit. I mean, there's a T-bar conversion kit too, but the car doesn't come that way. Usually the conversion kit comes out after an upgraded kit, the fact that we are seeing a conversion kit first tells me this isn't the optimum layout for most conditions.
If you read through the features, extended wheelbase for added stability is listed. Which probably means (a) that the liPo woldn't fit properly if the chassis weren't longer, (b) that the changed weight distribution makes the car less stable.
I reckon Associated have seen that OnPoint and others are selling these conversion kits, and thought that they might as well make one too and be the ones selling them.
Also, I would have thought that with this layout we could get rid of the battery tape, but apparently not.
You make a lot of assumptions there...
The Team Drivers have been running that setup since the Birds.
I'm not saying it's better until I try it, but the guy that designs this stuff is pretty sharp.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-09-2011, 05:44 PM   #2882
Buckaroo's Avatar
Agreed. Color me "cautiously optimistic".
Not every change is progress, not all progress is forward, and some paths are simply blind alleys that need explored to eleminate them from long term consideration.
Once this chassis configuration podiums regularly in large events, I'll think about leaving what I know works, and works well.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-09-2011, 10:32 PM   #2883
CraigM's Avatar
+1
It certainly looks cool, isn't it funny how odd a 12th scale looks with the battery off to one side when we're so used to seeing that configuration with tourers
I think given how light 1s lipo packs are, the new layout will more likely be an incremental improvement rather than a huge leap forward, but it will be interesting to see the feedback when some people start running it.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-10-2011, 10:03 AM   #2884
spring71's Avatar
Smile
CRC Front right height shims for 12R5 are available at TQ.
For more information, please visit www.tqrcracing.com
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 07-10-2011, 01:31 PM   #2885
http://www.amainhobbies.com/product_...it-10R5-12R5No No offense but you have to remove the screws in order to use the CRC shims.
I prefer the ManuTech shims, just loosen the screws and add or remove shims, much easier (and less expensive too).
AreCee is offline   Reply With Quote
Old 07-10-2011, 02:46 PM   #2886
Chaz955i's Avatar
+1 ManuTech. Almost too easy to change.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 07-12-2011, 07:36 PM   #2887
Samwise's Avatar
Hi,
I just got a used 12R5.1 and have not raced 12th scale in about 6 years or so. I'm also new to brushless technology, so please excuse my ignorance
Just a few questions:
1) I'll be running a 13.5 Trinity D3 motor. Is there an ESC you guys recommend over others? Right now I'm debating between the Novak GTB 2 and the Tekin RS. I'm wondering if the Tekin is worth the extra $60?
2) What tires (front and rear) do you recommend for low to medium traction carpet racing? The car I purchased here on R/C Tech came with loads of tires. I seem to remember running purple fronts and grey rears on my RC12L3 (again, many moons ago hehe!) in the stock 12th scale class.
3) On the subject of traction, is there a traction compound you guys like? I used to use TQ Blue.
Thanks a bunch!
- Sam
Samwise is offline   Reply With Quote
Old 07-12-2011, 08:15 PM   #2888
Originally Posted by Samwise View Post
Hi,
Thanks a bunch!
- Sam
Gratz on the R5.1
Great car to get back into 12th scale with.
I think most of your questions could be answered with a visit to your local track.
There must be a baseline tire combo that most of the guys there use.
As well as a recommended tire sauce.
Black Front, Yellow Rear is a baseline setup that will get you started most anywhere.
Yes the Tekin RS or LRPSXX v2(Mod Blinky) LRPSXXSS(Blinky, Boosted) are worth the extra $, if you like a well balanced car with smaller electronics.
Especially if your track runs 13.5 with boost ?
Nothing wrong with a GTB2 except ( I think) that like the Tekin, it requires a booster for 1s. The LRP is made for 1s.
Old 07-12-2011, 09:25 PM   #2889
Radio Active's Avatar
The Hobbywing 120A 1S is also a good ESC, and it's cheaper than the others, though you will also want the $20 program box.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 07-14-2011, 07:10 AM   #2890
avs
avs's Avatar
the CRC shims are 3 different thicknesses, .25 .50 and .75 mm.
you don't have to remove any screws, just take a scissors and make a slot. its nice to have the finer adjustment as well as the manutech aluminum bits for larger adjustment.
Tony Shimko
avs is offline   Reply With Quote
Old 07-16-2011, 04:48 AM   #2891
Hi guys, could I use the R5.1 lipo conversion on the R5 and if I could would it then be a R5.1 lipo chassis or would I have to change other things. Thanks.
charl mac is offline   Reply With Quote
Old 07-16-2011, 06:25 AM   #2892
You'll need new pod plates (aluminum), the standoff that connects them in the rear, and a right side diff hub. That's all I can think of off the top of my head.
Serzoni is offline   Reply With Quote
Old 07-16-2011, 07:29 AM   #2893
The chassis of the R5.1 is identical to the R5, the difference is in the rear pod as said above. The R5.1 rear is more Brushless friendly than the R5 and centers the BL motor better for better weight distribution. The cost of converting a R5 to R5.1 is about $50 if you buy new parts, less if you buy used.
So for about $170 or so (approximate since I haven't seen the street price of the chassis conversion) you can convert a R5 into a R5.1 Lipo.
Personally I would wait for the kit and get a whole new car for $220 or so.
Old 07-16-2011, 11:34 PM   #2894
Thanks for the info. The R5 has only done one event on carpet so it looksd like a new kit and I can get it for 72$ with spares so it will cost about the same as a new kit but then I don't have to wait till thy release the R5.1 lipo. Has anyone maybe got the part no. For the needed parts.
Thanks.
Old 07-17-2011, 07:50 AM   #2895
Thanks.
Probably best to run the car as is, till the new conversion kit is available.
Some of the parts to upgrade to 5.1, are different with the new conv kit.
5.0 to 5.1 post from this thread in 2009
Associated RC12R5
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
