Old 03-21-2011, 12:14 PM   #2806
Alex C's Avatar
Trader Rating: 50 (100%+)
Robert,
You beat me to the punch ......................... I did my modifications this past weekend, please see the attached for your viewing pleasure!!!
Best Regards!!!!
Alex
Associated RC12R5-img00694-20110320-1853.jpg   Associated RC12R5-img00697-20110320-1854.jpg
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 03-21-2011, 06:03 PM   #2807
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Alex C View Post
Robert,
Best Regards!!!!
Alex
Looks good, let us know how it goes on track compared to the std setup
On another note, has anyone used the On point racing chassis? im sick of looking at cell slots so was wondering is it worth getting?
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-21-2011, 06:46 PM   #2808
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm still really liking mine. Definitely a keeper.
Old 03-21-2011, 11:59 PM   #2809
Robert,
Best Regards!!!!
Alex
Nice where's mine
Lizardboy76 is offline   Reply With Quote
Old 03-22-2011, 01:30 AM   #2810
Hugh Jazz's Avatar
I thought i read some where that AE was releasing a lipo chassis
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 04-20-2011, 06:00 PM   #2811
Radio Active's Avatar
Does anyone have any tips on how to decrease the rear wheel track of the R5.1 (yes, I've already taken out all the shims), so that all the commonly available rims fit inside the 172 mm easily? I have better things to do on race days than cut the outside mm off each of my rims.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 04-20-2011, 06:07 PM   #2812
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Jaco/Parma wheels have the best offset for the R5.
168mm to 172mm no problem.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-20-2011, 08:39 PM   #2813
mikeygar's Avatar
Trader Rating: 14 (100%+)
Hey guys,
Am running on indoor asphalt and my 5.1 will only hook up late in the evening. I suffer from low speed, on power oversteer. Early in the afternoon, these settings don't seem to agree with my car but with the same settings, car becomes very easy to drive and planted later on. Help please
Currently my settings are:
F:
.018 front springs
1mm spacer bet bulkheads and lower arm
carbon brace installed
caster is 10 on upper arm, 3.25 on lower mounts
toe out 0.5
4mm ride height
Jaco 2x pink / 43mm
R:
Center Shock:
Black AE spring, 30 AE oil
mounted on 2nd hole from bottom
1.5-2.0 mm droop
Side shock:
Muchmore 300 oil (around 50-60 AE equivalent)
AE black springs
3.5mm ride height
Jaco Pink / 44mm
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 04-20-2011, 09:02 PM   #2814
Originally Posted by mikeygar View Post
Hey guys,
F:
.018 front springs
toe out 0.5
4mm ride height
Jaco 2x pink / 43mm
R:
Center Shock:
1.5-2.0 mm droop
Side shock:
AE black springs
3.5mm ride height
Jaco Pink / 44mm
Have you tried Yellow, or Gray on the rear.
Sometimes a different family of foam on the rear is all it takes.
Could be the Pink rears only work once the track has a good groove layed down.
Old 04-20-2011, 09:54 PM   #2815
We run on indoor asphalt too. And find the speedmind foam works better.... But too bad they don't have the new larger rims..... BTW: We use 32 or 30 speedmind depend on track condition.....
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 04-20-2011, 10:43 PM   #2816
Check back with your speed mind agent, the 2mm larger rear tires have just been released. Fronts are still pending.
The new Speedmind rim is also much stiffer, especially on the outer edge, and perhaps flexier on the inside. I have not really driven on them yet.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-21-2011, 02:00 AM   #2817
Thanks. I'm aware that the Jaco/Parma wheels fit well, but seeing as how nobody makes donuts any more (or they are at least near impossible to find in Australia) that means I'm stuck with Jaco/Parma tyres. When everyone else has a full range of tyres from other manufacturers to choose from, that's a disadvantage.
twitter: @dvcotton
Old 04-21-2011, 06:45 AM   #2818
Another option I forgot about are the TRC Prime wheels.
They have the most offset of any wheel I've seen, an additional 1mm over Jaco/Parma
Aside from different wheel offsets what type of solution were you looking for ?
Old 04-21-2011, 09:53 AM   #2819
mikeygar's Avatar
Thanks for the tips guys - I also have Jaco Yellows, white and grays. Will try them all. Will also checkout the speedmind foams - might have some luck with those.
On a side note - what compound/shore does Yokomo use for their tires? Seems to look like that the Yoks are a bit more consistent than my car...
Old 04-21-2011, 07:31 PM   #2820
I was hoping for something that allowed me to use the same wheels and tyres everybody else is using.
One option I can see would be to produce different ride-height adjusters. The piece that contacts the pod is 2 mm wide, taking a mm out of that on each side gets me the minimum 2 mm I need to be able to use the CRC rims comfortably these are by far the most common tyre/rim where I am. However, I'm worried about the strength of a piece of plastic only 1 mm wide in that position. If someone made aluminium ones that could work. Perhaps better still would be some optional hub parts that narrowed the car about 4 mm. I could take a mm or two off the left hand hub with a lather easily enough but I can't see an easy way to balance it on the right.
In the so crazy it just might work category is this: mirror reverse the pod by flipping the pod plates upside down. This means the metal pod parts would be on opposite sides of the car and the ride-height spacers pushed in from the inside instead of the outside. An aluminium tube would then have to be placed over the axle to keep the spacers and bearings from falling out (shim as required). Because of the offset spacing of the ride-height spacers this could be worth a couple of mm. It would also require the motor to run backwards though.
My preferred option would be if someone made some narrower hubs obviously.
twitter: @dvcotton
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
