Old 02-10-2011, 02:45 PM   #2761
Originally Posted by Radio Active View Post
Like I say, I didn't have any problems in 40 degree heat, it was just something I was told.
Complete set-up: ok, sure, it changes a little (tyres and caster mainly) depending upon the exact conditions, because this is an open outdoor track on rough tarmac. But here is my standard set-up for this track after 3 meetings with the car: Motor: 6.5 turn, mild timing; Gearing 65/30; Tyres: (generally 46-44 mm) Exceed Hard Front, Exceed Medium Rear/CRC Pink (have also used CRC purple fronts with the pink rears, but that's a little twitchy); Caster: 1.8 degrees, Camber: 2.5 degrees right wheel, 1 degree left wheel (otherwise the tyres cone so much my trim is badly off at the end of the race there are 3 high speed left handers on the circuit, and not much in the way of turning right); upper-arm mounts: 10 degrees; Side-spring: silver; side shock: 30 wt; centre shock 30 wt blue spring, top mounting position; ~ 1.5mm droop; body: Protoform Aston-Martin Lola; front and rear track is standard; battery forward; slight toe-out; ride-height: 3.5 mm; front springs 0.020; diff: fairly tight.
Edit: I assume you want the complete set-up to help diagnose the hair-pin problem, which I appreciate. I'm most interested in the fundamentals of oil vs. springs though; give a man a fish etc.
Daniel,
If you are referring to Maitland track, the 3.5mm ride height would be a major problem. I would run 5mm for sure.
I didnt run my 12th there, but my TC was all over the shop on the massive bumps.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-10-2011, 03:20 PM   #2762
Radio Active's Avatar
Originally Posted by Besercoe View Post
Daniel,
Hmm, good point. I was running 5mm with the old car, and the suspension is fairly well loaded up at that point, so there is more potential to bottom.
@RedBullFiXX: Thanks for the advice.
I'm still more interested in the difference between changing springs and changing oil though. I like to understand what every change I can make on the car will do, even if I never use it as a result. I can go away and research it from a Physics point of view, but that's easier with a reference point as to how the changes feel on track.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 02-12-2011, 10:53 PM   #2763
Ok, so after 10 years of reliable service my Airtronics 94145 died last night (terminal glitching, no it's not the plugs, yes I tried changing all the other electronics) and I'm looking to get a replacement quickly.
My back up servo is a rubbish Hitec that has to be servo taped to the car to be aligned properly.
Airtronics says that the direct replacement is the 94819. However, it is 4mm narrower than the older unit I've been using, and which fits the mounting holes perfectly. So, is anyone else using a 94819? And if so are there any fit issues?
Other servo recommendations are welcome, but I've got 3 spare servo savers for an Airtronics and nothing for anything else...
twitter: @dvcotton
Old 02-13-2011, 07:47 AM   #2764
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I'm a Futaba fan, and servo savers are fairly inexpensive
Either of these will fit perfectly in the R5 with or without servo mounts.
http://www3.towerhobbies.com/cgi-bin...4&I=LXDTB4&P=K
http://www3.towerhobbies.com/cgi-bin...4&I=LXWYV2&P=K
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-13-2011, 02:43 PM   #2765
Thanks. The S9650 looks like a good option. I think I'll go with that.
twitter: @dvcotton
Old 02-13-2011, 03:57 PM   #2766
Trader Rating: 19 (100%+)
There is also the Savox SH1250MG option as well
Michael
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 02-14-2011, 02:19 PM   #2767
Blue Screw's Avatar
Send a message via AIM to Blue Screw
def 9650.. plus the price is good.. and then theres the top of the line ko.. which is alot
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 02-15-2011, 08:29 AM   #2768
CFR
CFR's Avatar
Convert 12R5 to 10R5
what do I need to convert from a 5 to a 10?
1. 4 bolt hubs
2. foams for front and rear
3. bodyshell & posts
what else would be needed?
CFR is offline   Reply With Quote
Old 02-15-2011, 09:58 AM   #2769
AE-Reedy
1. 4 bolt hubs
2. foams for from and rear
Chassis, bumper, front end plate, cross brace, hardware.
These are just the quick items I can think of.
Sean Cochran is offline   Reply With Quote
Old 02-27-2011, 08:52 PM   #2770
CHRIS CHAVEZ's Avatar
My KoPropo 949 servo does not lay flat on the chassis. There appears to be about a 1.5mm gap between the chassis and servo. Do any of you guys have this problem? I really dont want to Shoo Goo my $110 servo to the chassis. So have any of you guys come up with any other solutions that doesn't require gluing?
Thanks, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 02-28-2011, 06:42 AM   #2771
kyle3333's Avatar
I'm sure some of this has been covered somewhere in this thread. But I am an off-road guy looking to sharpen my skills, so I bought a 12R5.1. I have ZERO experience with on-road.
-What turn motor should I be looking at?
-What is a good, metal geared servo that will bolt right in?
-Does this kit come with a servo saver?
-Is there a particular tire compound that works at most tracks?
-What size battery?
-What kind of tape do you recommend and where do you get it?
I really appreciate the help, thank you.
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 02-28-2011, 06:57 AM   #2772
-What size battery?
Lots of helpful links consolidated here
12th Scale Racing is Alive and Well in So Cal
12th scale is pretty much all 1s lipo now
Futaba 9650 is one of the most popular and reliable servos
Check local track for popular classes, tire compound choice and sauce type used, etc.
You will want to use a good thick RC grade tape to secure the lipo
And you will need access to a tire truer especially if you plan to run indoors.
TQ Racing stocks a lot of 12th scale stuff
http://www.tqrcracing.com/
Old 02-28-2011, 12:56 PM   #2773
kyle3333's Avatar
Great, thanks for all of the info. What servo saver works the best with the Futaba S9650 when it is bolted to the chassis?
Old 02-28-2011, 01:08 PM   #2774
Kimbrough
http://www.tqrcracing.com/shop/produ...futaba&pg_no=1
Old 02-28-2011, 01:14 PM   #2775
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
also one of THESE,i went through 3 savers in 15min since then the one i use know is cracked and haven't had a problem yet
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
