Old 01-21-2011, 02:57 PM   #2716
idbdoug's Avatar
Trader Rating: 33 (100%+)
On the 12r5.1 you normally run the front brace. I noticed on some of the team drivers setup sheets, they remove the front brace. Does anybody know why they would remove the front brace?
idbdoug
idbdoug is offline   Reply With Quote
Old 01-21-2011, 03:00 PM   #2717
idbdoug
Because they put sim under allu part and 0/5/10 deg block? to made longer
upper arm?
Or they need more flex in front end.
Why, don't ask, I have small experience.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-21-2011, 03:55 PM   #2718
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I found that if you remove the front brace, and change nothing else you will have more front grip mid-corner.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-22-2011, 05:40 PM   #2719
BoneCrusher's Avatar
Weird thing...
Got an older set of Jaco Purple front foams (they use regular bearings NOT flanged ones) and they work great still but a layer of foam is 'delaminating' from another layer. It is just under 42 mm.
Is that normal?
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 01-22-2011, 05:46 PM   #2720
sounds like the old 2-stage foams to me
Serzoni is offline   Reply With Quote
Old 01-22-2011, 05:48 PM   #2721
rc pete's Avatar
Originally Posted by BoneCrusher View Post
Weird thing...
Is that normal?
Ivan
Ivan, the older rims are smaller, so you end up with a higher profile tire. Back in the day with the smaller rims, we'd run the tires a couple of mm smaller too. For the foam coming apart: Speedsew to the rescue.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-25-2011, 03:54 PM   #2722
wingman2's Avatar
Took a load of pictures at a National race meeting a couple of weeks ago, and I noticed after looking through the pics, that this R5.1 has a re-worked cross brace that helps to hold the LiPo in place.
Does anyone know if this is a factory part or was it a one-off by the owner of the car?
I also noticed that a few R5.1 drivers were also re-drilling the original cross braces so the tweak screws moved towards the centre of the car, touching down on the bottom pod plate, rather than the top of the side links.
Anyone else seen this??
Cheers.
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 01-25-2011, 04:16 PM   #2723
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Cheers.
Did you notice the blue alloy ball studs on the ends of the cross brace? Looks like there's been some experimenting with damper tubes.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 01-25-2011, 04:30 PM   #2724
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Cheers.
I think it is actually the v-dezign cross brace
http://wwwmedib.kaleva.fi/plus/img/m...uto_pieau4.jpg
which is why the side springs can moved inward more like CRC Gen XL
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 01-25-2011, 10:02 PM   #2725
Radio Active's Avatar
I have some front foam donuts I wanted to mount, but the CRC rims I was going to use dissolved like aspirin when I put them in acetone, and some of the other rims I have around don't fit the bearings as well as I would like (Jaco), are too wide on the axle for my liking (HB, Ozcharge), or too flimsy in construction (TRC/Trinity). So, what does everyone else use? Are associated making quality acetone resistant rims for the car?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 01-26-2011, 03:22 AM   #2726
Hi i want to know where can buy a new r5.1 via internet in good price please advise.
drover is offline   Reply With Quote
Old 01-26-2011, 04:23 AM   #2727
And why would you use acetone to mount donuts???
You normally true the foam off till the rim is about clean.
(optional step: use a very small amount of ammoniac to degrease the rim!)
After this, contact glue ( I use bison kit) on both donut and rim.
Leave it all to dry for about 20 minutes.
Then use synthetic paint thinner on the glue and slide both parts over eachother.
Let it sit and you're ready to true them after a day.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 01-26-2011, 08:01 AM   #2728
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
STORMER HOBBIES $199
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-26-2011, 08:16 AM   #2729
avs
avs's Avatar
i seem to remember using lacquer thinner but the tire glue was not CA. i guess acetone is needed to remove CA glue?
i think CRC does offer their wheels new, maybe starting with a new set and using contact glues, you can avoid needing acetone to clean the wheels when new foam is needed.
for preglued wheels, like already noted, maybe a mechanical rather than chemical method would be better. i have accidently hit the rim truing very small fronts and the CRC glue seemed like it was pretty thin and smooth. just a little sanding on a tire lathe might be the easiest path with used wheels of choice?
Tony Shimko
avs is offline   Reply With Quote
Old 01-26-2011, 02:56 PM   #2730
Well, I use acetone because I have used acetone to take tyres and glue off rims for the last 10 years. 90% of the rims I have come across are acetone resistant for exactly this reason. The Jaco rims for instance. Usually it is only cheap low quality rims that aren't acetone resistant, I'm surprised the CRC rims aren't.
Using acetone has a number of advantages: you don't have to spend ages truing down the tyre and using up your truer bit, instead you put the tyre and rim in a can with acetone in it and come back half an hour to an hour later and the tyre slides right off along with the glue. The rim ends up much cleaner this way.
I mount donuts using a tyre horn and shoe glue with a little acetone, this is relatively easy, the tyre slides over the wheel well with the aid of the acetone, the tyre mounts well with a little practice, and you don't have to wait a day for the glue to be dry enough to true the tyre, an hour is long enough.
Anyway, I still need to buy rims, because I have donuts to mount and no rims to mount them on, and I would prefer not to buy CRC rims because I'd have to buy new stuff and change a technique that has worked well for me for a decade. So, does anybody have any other suggestions?
twitter: @dvcotton
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
