Old 05-09-2008, 08:22 AM   #256
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
is the front suspension as hard as the older front end?
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 05-09-2008, 10:22 AM   #257
The new parts are made from the new softer plastic but they don't seem to twist or anything.
The only parts that I needed to work on were the balls in the lower arms and the steeting blocks. Nothing out of the ordinary. I just squeezed the arm and ran a drill bit thru the blocks. No biggie and it only took a few minutes.
The pivot balls are a fine line between tight and loose. I'd rather have them tight and sand a little off than have them loose and sloppy. Rumor is they're going to make them a little better in the next batch.
Fred_B is offline   Reply With Quote
Old 05-09-2008, 10:47 AM   #258
Ok Let me make sure i understand this. I can understand working the inside of the holes of the pivot balls to make sure the kingpin slides through it for suspension travel and making the spring do the work with no bind. But is the lower arm that different then the old one in that all the bottom pivot ball does is rotate fore and aft to locate caster angle.... after the kingpin is installed in the upper pivot those balls do not move only the kingpin slides through them for up down suspension travel. Why do those pivot balls need to be smooth on the outside? Thier fixed and do not move after the kingpin is installed right? Dont flame me if i dont know what Im talking about cause I am just basing what Im saying on my 12L4 and what those pivot balls do. Thanks Guys
Bubonic-X is offline   Reply With Quote
Old 05-09-2008, 10:51 AM   #259
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm not sure the R5 has reactive castor like the L4 did, but it would seem as though when the suspension compresses, the lower pivot would need to be free to allow the kingpin to provide the change in castor smoothly. The same concept would apply to the minor amount of camber gain the kingpin experiences when the suspension compresses.
Old 05-09-2008, 11:29 AM   #260
The balls need to be free because of the reactive caster and camber gain just like the old L4 front end.
A quick spin in the dremel and/or a good squeese with a pair of pliars and you're good to go.
Old 05-09-2008, 11:41 AM   #261
AE-Reedy
There has been an adjustment made to the lower arms. Just call AE customer support and they will send you a replacement set.
Sean Cochran is offline   Reply With Quote
Old 05-09-2008, 02:13 PM   #262
Thats good to hear Sean. For me guys I am the most anal car builder out there. Most people would be happy with their front end in 1/4 the time I spend on it. It probably dosnt mean much but if there is any play or bind at all in the front end I will scrap parts and start over. Thats why I take so long to get it free. If I go to fast and do to much there is to much slop for me.
IndyPhil26 is offline   Reply With Quote
Old 05-09-2008, 02:47 PM   #263
A quick spin in the dremel and/or a good squeese with a pair of pliars and you're good to go.[/QUOTE]
And this wasnt the case with the lower A arms in the new 12R5 kit. Im sure they got it figured out now.
Old 05-09-2008, 04:41 PM   #264
I am just finishing up the build. This is my first 1/12 scale car. Question about battery install. Is there a battery holder? Do we tape them in?
daveden is offline   Reply With Quote
Old 05-09-2008, 05:05 PM   #265
Tape
Old 05-10-2008, 07:43 AM   #266
yeah, the R5 uses tape, but i wouldve liked an o ring option as well, its a lot neater looking
Old 05-11-2008, 08:25 PM   #267
baf1's Avatar
Default well
ive seen one of these cars run, 8.0 out of 10.???
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 05-12-2008, 08:35 PM   #268
Lebatek's Avatar
Send a message via AIM to Lebatek
Finally got around to building mine after getting it about a month ago. All I can say is this thing is SWEET! I had NONE of the build issues described here and I am an anal builder too. Great job Bob!
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 05-13-2008, 08:24 AM   #269
any pictures?
Old 05-16-2008, 10:45 PM   #270
I need a steering servo for my R5. The servo from my 12LC is a tad too wide and the servo horn does not center down the center line of chassis. Any suggestions, preferably Futaba servos
RoyU is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
