Old 11-30-2010, 04:46 PM   #2641
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Default sensor wire length
Anyone care to share what is the recommended sensor length for the 5.1?
(RS/LRP - ESC/motor combo)
Thanks in advance
madjack is offline   Reply With Quote
Old 11-30-2010, 05:36 PM   #2642
Trader Rating: 28 (97%+)
Sorry if this has been covered, but is there a good way to remove the pivot balls without damaging the ball or the arm? It seems like once the pivot balls are installed, they are pretty hard to remove without damaging the ball itself or the eyelet where they are installed? The ones for the side links are not a problem, but the rest of them on the car seem pretty hard to remove without messing up one or the other. Does anyone have a good trick/tool for removing the other pivot balls on the R5/5.1 without damage to any parts?
Funky is offline   Reply With Quote
Old 11-30-2010, 06:05 PM   #2643
RacinJ's Avatar
This works great. The CRC Suspension Ball Installation and Removal Tool.
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC4279
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 11-30-2010, 07:25 PM   #2644
tiko's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to tiko
+1 on the CRC Suspension Ball Installation and Removal Tool. It works well.
LionArtPrints - Custom Apparel, Hats, PitMats, RC Car Bags, and More
LionArtPrints - On Facebook
tiko is offline   Reply With Quote
Old 11-30-2010, 07:34 PM   #2645
tiko's Avatar
Thanks in advance
It all depends on where you place the ESC. But I have used 125mm and the 150mm. Hope this helps.
Old 12-01-2010, 10:05 PM   #2646
Radio Active's Avatar
I'm looking at getting one of these and have a few questions.
  • Is the 12R5.1FT the version to get, or is there another update that I'm unaware of?
  • Which tuning parts should I invest in? (part numbers if you know them)
  • Which spares do I most need to carry? (part numbers if you know them)
  • Does the side-to-side shock use grease or oil? What weight is standard? And which other weights is it a good idea to carry?
  • What is the standard weight oil in the mini-damper?
  • Any initial set-up tips for asphalt or Boral Coat would be appreciated.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 12-04-2010, 12:52 AM   #2647
Radio active,
Yes the 5.1 is current. To run in Australia you will need
Soft centre spring, green or silver
You need to shim the front lower arm ot 1.5mm each side. I use the front ride hight shims so you need one pack
Amr body
Crc purple fronts, pink rears
48p spur gear if you don't like the 64p one it comes with
Rear ride hight inserts
Kit setup is a good start with the softer spring and shims. Kit comes with 20wt for side shock and 30wt for centre shock.
Hope it helps
Tom from castle hill off road
Cya at summer nats for 12th?
Tom87 is offline   Reply With Quote
Old 12-04-2010, 03:27 AM   #2648
ShLa is offline   Reply With Quote
Old 12-04-2010, 11:32 AM   #2649
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Thanks in advance
We've been running 150mm they are perfect for our set up.
http://trackstarrc.com/trackstar/ind...mart&Itemid=64
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 12-05-2010, 06:13 PM   #2650
madjack's Avatar
Thanks in advance
Thanks for the info. and advice gang, looking forward to running it in the next week!
Old 12-05-2010, 06:43 PM   #2651
Thanks for the tip, that is just what I was looking for.
Madjack, I would reccomend the TQ racing sensor wires... and their 16 guage wires for 1/12 scale. Their sensor wire is very flexible just like the 16/13 guage wires they sell. They have a package where you can get 3 16 guage wires for the motor and 2 13 guage wires for the battery leads. Awesome stuff and won't mess with the rear pod movement on pan cars. Super fast shipping too, you won't be dissapointed. I recently picked up some to wire my 1/12 and 1/10 scale pan cars and I was really impressed. Awesome service too.
http://www.tqracing.com/rc_products.htm
Old 12-05-2010, 11:33 PM   #2652
Originally Posted by Tom87 View Post
Radio active,
Amr body
Hope it helps
Thanks Tom (also I've sent you a PM).
twitter: @dvcotton
Old 12-07-2010, 09:29 PM   #2653
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Reedy LiPo 5500mAh 3.7V 60C
This looks like a good option for an update
http://www.teamassociated.com/reedy/parts/details/629/
Each battery features Reedy’s molded hard case and industry-standard 4mm socket connectors to minimize resistance and increase power. A pair of connectors is included with each battery. The saddle pack battery also includes a 12-gauge jumper wire with pre-installed 4mm connectors
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-08-2010, 06:42 AM   #2654
We ran them at the indoor champs and they are very good!
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 12-08-2010, 01:59 PM   #2655
I didn't realize they were available yet.
But I'm sure they will be good, the previous vers 4600 was underrated.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
