Old 11-22-2010, 03:42 PM   #2626
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by radio_car_racer View Post
Anybody tried lowering the 5 pivot balls by 0.6mm?
Something there doing in Europe on the for V-Dezign CR4 which helps improve the handling. The CR 4 uses the AE pivot balls etc
Lowering the pivot balls? How?
Originally Posted by andrewdoherty View Post
If you really want though come by my room and I'll show you how/where the lube goes.
Uhm...WHAT!?!
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-22-2010, 07:06 PM   #2627
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Servo Question
Am going to run a 5.1 and looking for a servo
1) BLS651 comes with plastic gears
2) KO 951 too bigger footprint
Is there anything in the sanwa range which could be a good option?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 11-22-2010, 07:22 PM   #2628
corallyman's Avatar
Trader Rating: 97 (100%+)
I think the shoulder of the ball is lower, so your link would be lower or closer to the graphite plate.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-22-2010, 09:26 PM   #2629
AE-Reedy
Steve
If they get any lower then I don't see how there will be any room left for movement.
Sean Cochran is offline   Reply With Quote
Old 11-22-2010, 09:35 PM   #2630
corallyman's Avatar
Sean,
The AE one's are the low ones, I think that question originated from a different thread. Some people will switch out the higher balls, like the Serpent balls from a Serpent link car, to the lower AE balls for a different feel.
Steve
Old 11-22-2010, 10:42 PM   #2631
It's the same straight question - has anyone tried to lower the rear link balls on the R5 - and not from any other thread. The V-Dezign cars use AE pivot balls turned down by 0.5mm. Please do not guess what is going on if you are not sure, as it just confuses everyone!!
Sean, they do still work, and there is enough room for the articulation on the V-Dezign chassis. They do this to improve rear traction. We used to do teh same with T-bar cars with the same effect - lower the balls by 0.5mm and rear grip was very good. However...
We did this with cars running the L4 front suspension and guess what - the V-Dezign cars are running the L4 front suspension!! One person I know has run it with the R5 front suspension and said the car is not as good. I suspect the answer is that the R5 front suspension has a geometry that doesn't work the same as the L4 (perhaps Sean could confirm?) so using the lowered rear pivot balls won't have the same effect as it does with the L4 front suspension.
But that doesn't mean I won't try it...
SlowerOne is offline   Reply With Quote
Old 11-23-2010, 07:27 AM   #2632
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Q: Lowering the pivot balls only on the chassis side or on the pod as well?
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-23-2010, 09:42 AM   #2633
dominick i.'s Avatar
Trader Rating: 124 (98%+)
what front width does everyone run with the onpoint chassis?
dominick i. is offline   Reply With Quote
Old 11-23-2010, 10:05 AM   #2634
I'm running a 1mm shim between the lower arm and bulkhead and a 2mm shim between the upper arm mount and bulkhead. This will let you use the factory front brace as well.
Curtis
Fantom Racing | On-Point Racing | Parma/PSE | www.4chobbysupply.com
cmenard is offline   Reply With Quote
Old 11-23-2010, 12:04 PM   #2635
All of them. They must all be at the same height otherwise the action will not be smooth and linear.
Old 11-24-2010, 04:09 AM   #2636
radio_car_racer's Avatar
Don't forget to reduce the height of the centre pivot mount by the same amount so it's feet and the pivot ball all touch the chassis as one
you may also need to dremel the underside of the pivot mount to prevent it touching the chassis for side to side roll
radio_car_racer is offline   Reply With Quote
Old 11-28-2010, 11:25 PM   #2637
scribbler's Avatar
Seems labour intensive to make these changes to the pivot balls. Any estimates on time it take to make these changes.
scribbler is offline   Reply With Quote
Old 11-28-2010, 11:34 PM   #2638
rc_square24's Avatar
Originally Posted by Me_MrTyson View Post
Servo Question
Airtronics 94819
rc_square24 is offline   Reply With Quote
Old 11-29-2010, 02:34 AM   #2639
Put S9650, plastic gear but it is futaba and works
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-29-2010, 05:26 AM   #2640
approx 30 to 45 mins for me
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
