Old 11-20-2010, 07:25 PM   #2611
Default Tire truing
Hey Guys
Does anybody know where to get those grit boards that I've seen Hebert & Chicky use after truing tires to smooth down the edges?
AE 12R5.1 TC5 B4 B44 RC8B RC8BE
TEKIN OS LRP EPIC NOVAK
SPEKTRUM
FUTABA
PROLINE
Tomasb is offline   Reply With Quote
Old 11-20-2010, 11:42 PM   #2612
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
www.teamcrc.com
the search function there works well
Old 11-21-2010, 02:26 AM   #2613
scribbler's Avatar
What are the most popular locations to add weight?
scribbler is offline   Reply With Quote
Old 11-21-2010, 09:10 AM   #2614
Originally Posted by Murray View Post
If anyone is looking for a "Lipo" Chassis for your R5 I found one and it's pretty cool! It is a solid chassis with some cut outs in the front similar to the stock chassis where the transponder mounts. It has servo holes drilled for JR, KO & Futaba. Also the front end is a hair wider to smooth out the car a bit.
If you want one or info just shoot an email to info@onpointracing.com
I ran my car for the first time last night with the new On Point chassis. All I can say is this thing is sweet! My car was incredible and even more consistent than before. My 12R5.1 was already really good and this just made it better. If you're serious about racing a 12R5 I'd definitely add this to the list of must haves.
They're also available at Stormer too.
Curtis
Fantom Racing | On-Point Racing | Parma/PSE | www.4chobbysupply.com
cmenard is offline   Reply With Quote
Old 11-21-2010, 12:57 PM   #2615
scribbler's Avatar
To be more specific, I was going to add the Hudy weight under the battery to add rigidity to the chassis. If addition weight was nessesary, I was going to add it around the center line on the bottom of the rear pod.
Do the hudy weight fit snuggly into the battery slots? Has anyone added weight to the rear pod? I'm curious as to what this will do for the handling.
Old 11-21-2010, 01:46 PM   #2616
Buckaroo's Avatar
Put the weight where you need it to balance the chassis front to rear, left to right, and avoid additional tweak.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-21-2010, 07:50 PM   #2617
GP40X's Avatar
I'ver tried searching this thread and no luck. What is the best way and how much diff lube do you use on the front kingpins?
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 11-21-2010, 08:03 PM   #2618
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I smear a small drop on the lower portion of the king pin that slides up and down in the lower arm pivot ball. A coating is typically all that is needed.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-21-2010, 08:10 PM   #2619
scribbler's Avatar
As far as I know, you don't add any diff lube to the front kingpins. You really don't need any lube on them. Some people use graphite dust, light oils, but it really not neccessary. Just make sure the kingpins move freely, and aren't binding.
Old 11-21-2010, 08:16 PM   #2620
andrew-01's Avatar
Trader Rating: 22 (100%+)
x2. This is exactly what I do as well.
People add the lube to help dampen the front end. It helps in smoothing things out and aiding in better consistency up front. To each there own as I know fast guys who kingpin dampening, and others who don't.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 11-21-2010, 08:23 PM   #2621
I would recommended you not worry about the kingpin lube yet. It is a little messy, and unless you're committed to attending to it every other run or so, you will not gain any consistency. For you Bill, I would suggest staying on top of your tire sizes, ride height, camber and diff. If you really want though come by my room and I'll show you how/where the lube goes.
AWD
Old 11-21-2010, 08:28 PM   #2622
dc661's Avatar
Trader Rating: 103 (100%+)
hey guys I have a 12r5 ran twice for sale for $100 shipped if anyone's interested.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 11-21-2010, 08:55 PM   #2623
Thanks Chris!! Glad you like the chassis!!
On-Point Racing info@onpointracing.com
On-Point Racing is offline   Reply With Quote
Old 11-21-2010, 09:00 PM   #2624
GP40X's Avatar
AWD
Sounds good Andrew. I got lucky and scored a large lot of 12R5 parts on ebay which helps as I broke a few things at the fall classic (cracked the rear axle and the left front steering knuckle). I will be there on 12/5 for the next club race and hopefully will get a bunch of practice in Thanksgiving day weekend.
Bill
Team Qik
Xray T3 2012 USVTA
Old 11-22-2010, 10:09 AM   #2625
radio_car_racer's Avatar
Anybody tried lowering the 5 pivot balls by 0.6mm?
Something there doing in Europe on the for V-Dezign CR4 which helps improve the handling. The CR 4 uses the AE pivot balls etc
radio_car_racer is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
