Old 10-28-2010, 05:48 AM   #2551
Originally Posted by terrible View Post
What other servo's other than the futaba are an exact fit?
Also what type of ESC are you guys using? I'd use a brushed setup but I'm having a hard time finding a decent motor. If I go brushless it seems like the choices for a 3.7v controller are limited.
As far as I know only the Futaba.
A good brushed motor is the CheckPoint Money 19T.
For brushless you could use almost any with a receiver pack or booster. I even used an old Novak GTB with their booster while waiting for my Tekin RS to come in. If you want one that doesn't need a Rx pack or booster then you are correct the choice is very limited.
However, the newer LRP is being hyped up that it has a "dual BEC" to run 1S but I have yet to see one. At my local track it is Tekin RS, GTB 4cell and Advanced Electronics that are the most popular (all using the very small 2S LiFe 220mah pack).
AreCee is offline   Reply With Quote
Old 10-28-2010, 07:56 AM   #2552
mangoman's Avatar
Guys at my track are definitely using the new LRP, without a receiver pack and 1s lipo.
I believe most are doing this solely because they dont want to have to run a receiver pack.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-28-2010, 07:09 PM   #2553
speed-e's Avatar
Trader Rating: 28 (100%+)
Originally Posted by andrewdoherty View Post
The SMC's run fine brand new, but everyone I have had for the last year+ has puffed.
I've had the same experience with two SMC 1S packs, while a Reedy and Thunder Power pack still run strong.
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 10-28-2010, 08:10 PM   #2554
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
With the LRP SXXSS, and no booster or receiver pack, the servo is faster than my Tekin RS with a receiver lifepo pack or TQ booster.
I find that very interesting ?
The RS servo setup is still plenty fast, but it took a while to get used to the increased servo speed with the LRP.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-31-2010, 12:24 AM   #2555
scribbler's Avatar
with the upgrade of the Lipo aftermarket chassis you can use the Jr servo. Hitec servoes will work, but they aren't the same quality as the Futaba or Jr servoes, and they aren't the "perfect" fit. Hitec's micro servo is slower, heavier, and I believe less torque.
I fianlly got all the parts in for my 12R5/5.1 and I'm looking forward to getting back on the track.
scribbler is offline   Reply With Quote
Old 10-31-2010, 07:14 AM   #2556
So you're saying that the LRP puts out more than 6.6 volts to the Rx.
Old 10-31-2010, 10:56 AM   #2557
scribbler's Avatar
I'm a little confused about what LRP has done with their line up. What is the preffered ESC for boosted 17.5 on one cell?
LRP SXX Stockspec or LRP SXX V2?? What is the difference?
Thanks in advance
Old 10-31-2010, 04:54 PM   #2558
monkee's Avatar
Trader Rating: 15 (100%+)
What pinion would be recommended?
using stock spur with a novak havok 13.5 brushless.
monkee is offline   Reply With Quote
Old 10-31-2010, 06:01 PM   #2559
Thanks in advance
LRP SXX Stockspec is best for Stock Spec motors, i.e. 10.5 to 21.5
LRP SXX V2 is intended for mod, low wind motors.
http://www.lrp.cc/forum/viewforum.ph...c6b48ae938e3e1
AreCee
I haven't measured the voltage, just going by feel, I have the same equipment in both R5's aside from speedos.
The Lrp is definitely quicker with the servo.
Old 11-01-2010, 08:42 AM   #2560
monkee's Avatar
Old 11-01-2010, 02:48 PM   #2561
gashuffer's Avatar
Trader Rating: 48 (100%+)
Whats wierd is the LRP SXX V2 is 30 dollars cheaper than the SS
gashuffer is offline   Reply With Quote
Old 11-01-2010, 09:50 PM   #2562
The rated current for V1's are 764amp compare to v2 which are 400amp. If you open it up you can see 1 role of fet is missing! This is the reason it is cheaper. I am not sure if it is for a price reason or something. The V2 sure do not feel as 'punchy' as the V1. Not very noticable if you run high T motors. But for modified class the different is very big.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 11-02-2010, 03:54 AM   #2563
darrenoakley's Avatar
Based on a spur of 96t and rear tyres 45mm I was running a rollout of about 55mmpr on our track that is quite small so that would be a 37 t pinion. But this much depends on your tyre size and track size. I would start at that then work up on motor temps.
What size is your spur / tyres/ track size ?
Hope it helps mate. I was in the same boat as you a while ago, just remember your rollout will change as your foam get smaller.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 11-04-2010, 04:56 AM   #2564
radio_car_racer's Avatar
RC12 5/5.1R
what's the part number for the full front end kit?
radio_car_racer is offline   Reply With Quote
Old 11-04-2010, 05:57 AM   #2565
mkdut's Avatar
Trader Rating: 19 (100%+)
Originally Posted by radio_car_racer View Post
RC12 5/5.1R
ASC4686
http://www.horizonhobby.com/Products...ProdID=ASC4686
mkdut is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
