Old 10-20-2010, 06:11 PM   #2506
monkee's Avatar
Trader Rating: 15 (100%+)
Savox!!
No drilling. Perfect fit!
monkee is offline   Reply With Quote
Old 10-20-2010, 06:15 PM   #2507
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That will work, looks good.
May want to put the battery in the front position though.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-20-2010, 07:29 PM   #2508
monkee's Avatar
Is that done by just moving those battery stops to the back?
I'm guessing that weight distribution is the reason?
Going to use a Novak system with 1cell lipo
Old 10-20-2010, 07:46 PM   #2509
monkee's Avatar
I don't see any 1cell lipo on hobbyking for 12scale. Am I missing them or do I have to go with stuff like reedy packs?
Really don't want to spend 50-60 bucks on a 1cell lipo
Old 10-21-2010, 02:26 AM   #2510
Robert_K's Avatar
Originally Posted by monkee View Post
Savox!!
Is that horn centered? When I put my Savox Servo with the Servo's Post's my Servo Saver is way of center.... I have to tape my Savox Servo....
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 10-21-2010, 02:53 AM   #2511
Robert
Here s your answer Robert
the answer is no !!
good luck at EPs this weekend , shame i cannot be there
sidecarphil1 is offline   Reply With Quote
Old 10-21-2010, 10:22 AM   #2512
monkee's Avatar
Is there a problem with it not being centered?
Everything appears fine...
but this is my first car like this
Old 10-21-2010, 11:12 AM   #2513
Robert_K's Avatar
thanks Phil!
Hope all goes well at the European Pancar Series. Sadly my head is at a whole different point right now.....
When the servo is not centerd, the steeringlinks are not an equal lengt, as a result the car will not have the same feeling both left and right, and will also not have the same amount of steering. I think it's it should be centred. I tape my servo's in with double sided tape (TOP or MuchMore)
Robert
Old 10-21-2010, 11:19 PM   #2514
mauromj's Avatar
Trader Rating: 20 (100%+)
Has anyone drilled a new left servo mount hole and been successful in countersinking in? I know where I need my hole and it will be easy to drill, I just want it countersunk nicely. How should I do it?
Team Schumacher USA
Team Speedpassion
Team Core-Rc
mauromj is offline   Reply With Quote
Old 10-22-2010, 01:11 AM   #2515
boscoj's Avatar
Default oh whoa . .. at least you got some toe
nice to see 12vers after such time
camber + toe = a turning in ho
boscoj is offline   Reply With Quote
Old 10-22-2010, 04:42 AM   #2516
Hi guys,
Loving my R5.1 but hating the shocks on that thing!!
The center shock is such a ball ache trying to getting air free and then after a few runs air it needs a rebuild. Now I have started from fresh with new rebuild kits and used green slime on the seals. I have made sure that the o-ring is in and level before putting the end on.
Now is there anyway that this can be stopped?
Has anyone tried any other center shocks on the car, I have heard the hotbodies shock is meant to be really good?
Cheers
Chris
chris_blakey is offline   Reply With Quote
Old 10-22-2010, 04:46 AM   #2517
Hi Chriss!
1st hot bodies shock is very nice but it take air inside too
and for me is a little flustrate to rebuild it ... but one done, it stay for some
runs
2nd I back to ae shock and I don't get "air problem", before put 2nd end,
I always try fit o-ring by nut driver or something, I push it inside,
some oil go away, and then I put end on body, for me no problem.
But I always rebuild shock before ride, especially when I drive 1 time per month ....
Wish you good luck!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-22-2010, 06:23 AM   #2518
Trader Rating: 49 (98%+)
Send a message via AIM to micrors4guy
I just did a buddys car this week. Just takes a little londer to get it to counter sink.
micrors4guy is offline   Reply With Quote
Old 10-22-2010, 06:28 AM   #2519
There is a small tool that you can find in the drill section of a hardware store, it is call a countersink bit. Chuck that into your drill press, set the plunge and there you go.
AreCee is offline   Reply With Quote
Old 10-22-2010, 06:34 AM   #2520
Originally Posted by chris_blakey View Post
Hi guys,
Cheers
Chris
I'm using the Hot Bodies shock in my 12R5.1 because I had a hard time with the AE shock cap cross threading and popping off in a race causing the chassis to drag on the ground. After adding up the cost of all the AE parts I figured why not try the HB shock even though it cost twice as much.
The HB shock builds just like any Touring Car shock and uses a bladder to provide an air chamber rather than mixing the air in the fluid to make an emulsion shock like AE.
On the other hand, my center shock in my WGT 10R5 works perfectly and has no problems. I think the original shock that came with my 12R was machined incorrectly which was why the caps kept popping off.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
