Old 10-18-2010, 01:56 PM   #2491
Originally Posted by andrew-01 View Post
Do you guys find most of you are underweight(Roar 730grams)?
I weighed mine all up this weekend and am sitting at 704grams. I made sure to tare and 0 out the scale, but after a few tries I kept getting the same results.
Where would or where do most of you add weight? The car was dialed and on rails, so I'll have to mess around with weight placement to keep the same feel I hope.
I use 2mm thick lead strip and add it under the LiPo in the slots where the round cells used to go. This works out at about 12g per strip to fill a slot. My car is about 705g, so I use two strips in the middle slots. To account for tyre wear and any variation in tyre sizes, I add a 7g weight in the gap between the aerial mount and the front of the LiPo. All up, the car varies from 735 to 740g.
Putting the weights under the LiPo keeps the weight low and in the middle of the car, and the rest of the chassis clear. Attach the lead strips to the LiPo using thin double-sided carpet tape and it's good to go! HTH
SlowerOne is offline   Reply With Quote
Old 10-18-2010, 06:10 PM   #2492
Originally Posted by idbdoug View Post
I think Robert B. was looking for one of these braces. Bring one to the track next time we race.
idbdoug
Already bought one! Looks and fits perfect!!
racer robert is offline   Reply With Quote
Old 10-18-2010, 06:30 PM   #2493
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i would be all in for one of the braces if they came in blue.
micrors4guy is offline   Reply With Quote
Old 10-20-2010, 12:07 AM   #2494
monkee's Avatar
Trader Rating: 15 (100%+)
how did you guys get your ball studs into the servo horn/saver?
the pre holes in the servo saver are way too small for the studs and im hesitant to drill them out
monkee is offline   Reply With Quote
Old 10-20-2010, 12:11 AM   #2495
andrew-01's Avatar
Trader Rating: 22 (100%+)
I drilled mine out a little at a time till the holes were the right size. I'm sure you could use a body reamer too.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 10-20-2010, 10:26 AM   #2496
Dog Bone's Avatar
I drilled mine out as well - I haven't had any problems yet.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 10-20-2010, 12:22 PM   #2497
monkee's Avatar
Did you guys have to drill a new hole in the chassis to fit your servo? It's either too small or to big
Edit.
Well searching tells me there are only two direct fit options.
So stupid
Old 10-20-2010, 01:44 PM   #2498
The Futaba 9650 fits perfectly. I think Airtronics and KO have servos that fit too. JR you have to drill.
AreCee is offline   Reply With Quote
Old 10-20-2010, 01:50 PM   #2499
monkee's Avatar
http://www3.towerhobbies.com/cgi-bin...P?I=LXDTB4&P=8
this is perfect fit?
Old 10-20-2010, 01:58 PM   #2500
Yep, just cut off those flat ears and get a 25 spline servo saver.
Old 10-20-2010, 02:07 PM   #2501
Farmer_John's Avatar
Or just use one set of the ears...
RCHOTPIT.COM...now alive...
Farmer_John is offline   Reply With Quote
Old 10-20-2010, 02:09 PM   #2502
monkee's Avatar
is one set and some servo tape enough to keep the servo from moving?
Old 10-20-2010, 03:01 PM   #2503
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No, but you can always add shoe goo around the servo after you set it in place.
It will harden in 12 hours or so, and be very solid.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-20-2010, 03:02 PM   #2504
monkee's Avatar
Lol I don't want to say that's ghetto but..... That's ghetto!!
Old 10-20-2010, 03:03 PM   #2505
Fairly common way of mounting servos on F1 cars actually.
It can be done clean with patience.
Ghetto, is having your car wander from side to side because your servo is not mounted solid
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
