Old 09-29-2010, 03:34 AM   #2431
Robert
SEXI CAR!!!
What body you are going to use? AMR-12?
Btw, try move wires to shock, made them center, not on left side.
But maybe it is OK.
Hm, btw, you put nice looking tape on speedo, don't you scary about temp and overheat speedo?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-29-2010, 04:29 AM   #2432
Robert_K's Avatar
Originally Posted by M.Abramowicz View Post
Robert
SEXI CAR!!!
But maybe it is OK.
Thanks Michal!
I'll be using different bodies:
Protoform AMR
Black Art Bomb "R" (BA004)
Black Art Audi R10 (BA003)
Not sure about the speedo, Think it will be okay with 3,7V. But still have to test is...
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 09-29-2010, 07:23 AM   #2433
The tape on the speedo case will not hurt it. The Tekin gets almost all of its cooling from the solder posts (their version of a heat sink) so you do not want to cover those with shrink wrap.
AreCee is offline   Reply With Quote
Old 09-29-2010, 11:14 AM   #2434
rc_square24's Avatar
How do you mount an Airtronics//Sanwa 94819 servo onto the R5.1? the holes don't match is there a mount i can get for it? I dont want to use glue.
The holes on the chassis are wider apart.
rc_square24 is offline   Reply With Quote
Old 09-29-2010, 11:17 AM   #2435
andrew-01's Avatar
Trader Rating: 22 (100%+)
I have mine butted up all the way against the passenger side servo mounts. The 'driver side' clamps down to the outside of the servo tabs. Its on there and solidly mounted with washers to distribute the load. It also helped center the servo saver in between both suspension blocks and arms.
ANDRXW.com
andrew-01 is offline   Reply With Quote
Old 09-29-2010, 06:03 PM   #2436
darnold's Avatar
Originally Posted by andrewdoherty View Post
Lets get off this super wide page...
I built a little on the new chassis tonight. The first thing that hit me was how perfect the countersinks are. I hate when the screws stick out from the chassis bottom or get swallowed up by over zealous (read weakened) countersinks. The on-point chassis countersinks sit the screws just a fraction below the chassis surface.
Rear pod and links lined up perfect along with all the other screw holes.
Awesome Andre, I'm waiting to pick mine up on Saturday. My plan is to run my car a 3-4 runs as is and then switch the chassis over. Do you know if On-Point makes a center brace for the front suspension since the holes are 2mm further out? I'm wondering if we can just use a CRC front brace now that I think about it?
Either way I'm looking forward to testing this baby out.
Team Top Racing USA,Team Pro One Tires, Team Speed Passion USA
darnold is offline   Reply With Quote
Old 09-29-2010, 07:58 PM   #2437
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have been running 2 mm shims between the upper arm mounts and the front bulkheads lately ala Naoto's 2008 worlds car. It gives a little less camber gain, softens the spring rate a touch, and seemed to calm the front end down some for me. So the increase in lower arm width actually allows me to use the stock brace, where as before I wasn't able to. As for the CRC brace I couldn't tell you. I only have the wide CF brace, not the red pins. To be honest, it wouldn't be too difficult to drill a couple 2 mm holes in a scrap piece of CF to fab a brace, if you're into that kinda thing. Good to hear from you!
I have a couple ideas for the R5 I am going to try this weekend and the next week. They might be a little goofy, but I run on such low low bite carpet that it seems desperate measures are needed. If any of it "pans" out I will post.
Old 09-29-2010, 08:14 PM   #2438
motomike122's Avatar
Originally Posted by Robert_K View Post
So, I've been working on this car for a few day's now, but I'm starting to like it. The Sensor Cable en TQ-Booster still need to be switched for a "better" solution, but I can start now .
I tried something new with the carbon:
Regards
Robert
WOW!!! It is a thing of beauty... What did you use on the chassis to make it blue? Just paint or a special kind? Thanks, Mike
motomike122 is offline   Reply With Quote
Old 09-30-2010, 12:31 AM   #2439
Robert_K's Avatar
FasKolor Faskyblue
Regards Robert
Old 09-30-2010, 01:18 AM   #2440
darrenoakley's Avatar
Default Widening front end with lower arm spacers
Just a bit confused as to why so many set ups show adding shims to the front bulk heads and what would be the benefit in doing this. My new 12r5.1 had them when I got it but cant really tell the difference from my 12r5 that doesn't.
If someone could explain, this would really help as I dont like changing bits unless I understand what they are doing.
Cheers Darren
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 09-30-2010, 01:58 AM   #2441
Heh
Nice blue job, but Robert how long you do it?
If it made me faster, I will do it at all my pancars
JOKE!!!
Damn, I wait for tc6 but I will do it in red or porn pink :P
m,
Michal Abramowicz
Old 09-30-2010, 02:02 AM   #2442
Cheers Darren
About front end, adding shims -> changing ride height.
If you cut tires to ~42mm for front (I love this diameter), then check RH and
add some washers to set 3.2-3.5 at front.
About rear end in 12R5 and 12R5.1, there is shorter wheel clamp for right tire (diff side) so rear pod is at 12R5.1 better balanced with BL engine.
About 5 and 5.1, it is big difference, my car 5.1 set by caliper with factory settings, balanced L/R drive stright when accelerate, 5 from my friend a little push but I don't remember which side. You know, little left or right but
not stright. And 5.1 do it stright
Regards!
m.
Michal Abramowicz
Old 09-30-2010, 01:20 PM   #2443
@rc_square 24 - IME, it's the diff rings. I've had this happen on two cars, and just by changing the diff rings for IRS replacement items, the problem went away. The diff rings that came with the car are not flat, and so you get the tight/smooth action you describe. I use the IRS lightweight ones now, they are very flat and smooth! HTH
SlowerOne is offline   Reply With Quote
Old 09-30-2010, 06:44 PM   #2444
darnold's Avatar
Good to hear from you also, how have things been going? Thanks for the info on the chassis plate.
Old 09-30-2010, 07:32 PM   #2445
FasKolor Faskyblue
Regards Robert
Thank you...Mike
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
