Old 04-07-2008, 08:24 AM   #226
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
only some factory guys have em, and supposedly, their doing very well. I dont think the build would be anything interesting, as most 1/12ths go together the same.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 04-07-2008, 08:35 AM   #227
I'm mostly interested in seeing how the new shocks go together.
BCall is offline   Reply With Quote
Old 04-07-2008, 05:17 PM   #228
adamge's Avatar
espresso, I've never been in your situation, but to me it sounds like a 1/10th pan car (the new generation just coming out) would be ideal.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 04-11-2008, 03:08 PM   #229
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The manual is now online.
http://www.rc10.com/shusting/Catalog...2_electric.htm
Kraig is offline   Reply With Quote
Old 04-19-2008, 08:07 AM   #230
Hi,
car is built completely and now some pictures and things I noticed during the building process.
Kit Contents:
All CFK parts ready to go:
Like in all of my cars I sand the sides of the chassis and the front in a quite low angle. In the front it is to avoid that the chassis chips when hitting a curb or something. On the sides it is to minimize the chances of bottoming out during cornering.
New Dampers:
After you understood how to build them it is quite easy and they work perfectly. Kit setup seems a bit soft and I went during practice up to a 35wt pil in the side damper. 35wt may be too much and I'll try something softer next time.
Rear Suspension:
In the car:
Center Pivot Suspension:
Complete:
The rear suspension is super free as already mentioned and works perfectly. Just a tip for spare parts. Get some links...
Front suspension:
Complete:
The new suspension is a dream regarding design, adjustability and fit. The steering knuckles require zero work to be smooth and free. The alloy parts are also a perfect fit. Only in the lower wishbone where the pivot ball sits I had to work the ball in a bit so it moves freely. Rest is perfect from the beginning...
Nearly finished:
Car is finished now and I was able to practice a bit at the local track. The car is super dialed right from the start and with minor tweaks it will be a weapon. With the L4 the track record I set right before the German Nationals and the Euros was 8.8xx. With the new car with 5 packs on it I managed to drive a 8.531. Quite impressive improvement... Even more impressive as the new car is easier to drive (especially through chicanes) and way more agile.
I'll see whether I can post some new pictures within the next days...
Cheers
Chris
speedy-932 is offline   Reply With Quote
Old 04-19-2008, 12:39 PM   #231
wow, thanks for the awesome pics!! that damper shock is cool, so it is a shock, with no spring, and a new ball stud area.
Old 04-19-2008, 09:07 PM   #232
Eddie M's Avatar
Very nice car. I like the fact that you can now change the front track width.
Eddie M is offline   Reply With Quote
Old 04-20-2008, 01:23 AM   #233
Hi,
@Ferrarimk13:
Yes, the shock with no center spring is used for the side dampening and does it's job absolutely perfectly.
You will notice that I built the shocks not like in the instruction mentioned as I did not read it carefully enough... Fixed that later during the building process...
@Eddie M:
In fact you could to this also with the old axles. You just had to use shims on the axle instead of at the lower wishbone. Interesting is that with the new axles you can achieve a nearly 2mm narrower front track width then with the old axles.
It will be interesting to see whether it works to use some inboard toe-out.
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
Old 04-20-2008, 07:15 AM   #234
Ffejdat's Avatar
Speedy-Chris How does it look for motor room, can you fit big gearing for today's brushless motors, and how is the rear axle hieght, is it lower than the old car, can you run small tires if you want to? Thanks!
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 04-20-2008, 07:31 AM   #235
Hi,
the motor just fits right in. You don't have to remove any parts to get the motor in or out. Soldering is a bit tricky but I'll try sometimes to dremel away some of the CFK to get a better cable management. But for now it works without a problem. No binding or tweaking.
The axle height... To be honest I don't know. I'll try it for you if I have some more time.
Same goes for the pinion/spur combination. Just by trying now I can tell you that the biggest pinion I can fit with a 96T spur gear is a 30T pinion. With 45mm tires that will get you in the 44mm rollout range. I can try a 88T later for you but I don't have any bigger pinions than 32. I think you should be able to get in the high 50's to low 60's with no problem. For anything else I can't give you a guarantee...
Cheers
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 04-20-2008, 08:10 PM   #236
I ran 96/39 with a Lrp 10.5 at our regionals a few weeks ago. That was maxed out. There are some pics on the ae site.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 04-21-2008, 03:16 AM   #237
when is the car going to be released, and where can i buy it from
judge10tpt is offline   Reply With Quote
Old 04-21-2008, 10:44 AM   #238
Hi,
@Walter: The problem is the way I routed my motor wires. That way I can't put the motor more forward. But thanks for letting us know what's possible.
@Ffejdat: I looked into your question about the small tires. As you can see in the picture I mounted tires that are completely trued down. So that is 38mm. With those tires I get around 2.7mm of ride height at the rear of the pod. As you can't run them that low you'll be fine until you reach the point where the foam is already hard because of the glue.
Cheers
Chris
Associated RC12R5-cimg3160.jpg   Associated RC12R5-cimg3161.jpg   Associated RC12R5-cimg3162.jpg
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
Old 04-21-2008, 03:46 PM   #239
Ffejdat's Avatar
Thanks Chris, that is good to see, that was one of the negatives of the 12l4, ran out of axle adjustment before tire... Do you have a set of fronts rime to check the same thing? Always been a diehard Assoc fan, but have gotten away from them lately, might be time to come back...
Old 04-22-2008, 05:42 PM   #240
hey speedy, i noticed the damper shock has some oil on the cap, is it not tight, or was that just some that spilled over? nothing comes out right?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
