Old 06-15-2010, 07:57 AM   #2341
darrenoakley's Avatar
Default Nosram stock spec
Does anyone have any settings for Nosram stock spec matrix ESC when using rc12r5 with 10.5 motor indoors, also rollout ideas would be great help as new to 12th
Thanks in advance and sorry if it has already been covered chaps
darrenoakley is offline   Reply With Quote
Old 06-15-2010, 08:50 AM   #2342
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I ran a X12-13.5 timing oooo
SXXSS with 0-7-8-0
roll 50, indoor carpet 100ft straight.
I would think around 40-45 roll should be close for the 10.5
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-15-2010, 01:15 PM   #2343
Thumbs up
Thanks for that mate hopefully stop me popping a motor.
so with the old stock spec would I want profile 7or8 advancing the timing or not ?
Also what about brakes Drag brake and brake strength all off completely ? I know it locks up real easy if you touch the brakes but can you get away with any.
Cheers in advance
Old 06-15-2010, 08:32 PM   #2344
Cheers in advance
oops, I guess it's the Pearl that correlates to the new LRP SS
We don't have Nosram in the USA, sorry for the mis-info.
Old 06-16-2010, 12:37 AM   #2345
No worrys , if it helps it is the same as the LRP spx competition speedo.
Xray x11
Xray T3 011
Old 06-18-2010, 11:54 PM   #2346
eg
Default 12R5.1 Side Shock
Hey can someone give me the dimensions of the side shock...I want to use it on another car? Thanks in advance.
eg is offline   Reply With Quote
Old 06-25-2010, 03:07 AM   #2347
Hi!
Ask me again at monday ...
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-25-2010, 05:13 AM   #2348
Default Side shock dimensions
From mounting point to mounting point its 53mm fully compressed and 60mm fully extended.
Bumpy is offline   Reply With Quote
Old 06-29-2010, 04:54 AM   #2349
Hi!
It is nice to read that AE goes well
http://events.redrc.net/2010/06/worl...tle-from-pole/
Michal Abramowicz
Old 07-23-2010, 10:47 PM   #2350
Alex C's Avatar
Trader Rating: 50 (100%+)
It has been pretty quite in here ........
Alex Cortez
Thank You to all My Sponsors
Ko Propo USA / RC America - Xray - Hudy / Max Power Engines / VP PowerMaster Fuel / Team Espo - "Lay it down Prop"!!!!
Alex C is offline   Reply With Quote
Old 07-24-2010, 12:05 PM   #2351
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
New to 12th scale and will be running 17.5 with a sphere comp on 1s.
the track i will be running on is 60x30. I know nothing about roll out and all that on road lingo as this is my 1st onroad car besides a mini-z.
Can anyone point me into a decent starting point for gearing?
this is the track i will be running on. CRC carpet. Not worn in yet. Im open to setu help also. My car will be in tuesday and im ready to go give it a try. I will be getting the 5.1.
http://www.youtube.com/watch?v=IDhGm-fuzrs
this is one of the mini-z classes running on it.
micrors4guy is offline   Reply With Quote
Old 07-24-2010, 01:28 PM   #2352
Trader Rating: 49 (100%+)
was so just about to ask the same question.. we'll both be at the same new track, same car, same set-up. both onroad noobs
cleblanc is offline   Reply With Quote
Old 07-24-2010, 04:09 PM   #2353
Setup Sheets.
http://www.petitrc.com/reglages/asso...tedRC12R5.html
I would recommend building it stock exactly, with the exception of front width, add 2mm between the Front bulkhead and lower arm.
An extra set of #4617 bulkhead shims will be handy, also a set of #8425 kingpin shims.
As for rollout, try gearchart.com. makes it easy to set and print rollout sheets.
As for gearing, I run a track a little larger than that (100x50 ish)
My setup was with Tekin RS in Stock Spec mode
roll 85, endbell 24 deg, full cranked.
70 to 80 roll may work better for your track, but motors vary.
Cleblanc, any relation to Louis Leblanc ?
Old 07-25-2010, 11:10 AM   #2354
No relation that I know of, but u never know. Haha
Originally Posted by RedBullFiXX View Post
Setup Sheets.
Old 07-25-2010, 02:11 PM   #2355
C Verano's Avatar
Default Airtronics servo
Is there an Airtronics servo that fits in the car witout modification? Thanks.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
