Old 04-22-2010, 09:50 AM   #2311
Robert_K's Avatar
Originally Posted by thunderdaddy View Post
how do you adjust the droop for the rear pod. i also understand you can adjust it for the front end. how is this done. the manual sure could be more intuitive for us newbies. thanks in advance.
The droop of the rear end can be adjust by the small plastic tube that's inserted in the rear center shock. But also bij the ball cup you screw on the damper tube (bottom side) making this longer will give more droop. It is supposed to be done bij the small tube in the shock, but that's a hell of a job.
When testing with different droop I noticed that about 1,5mm droop is best voor the R5.1 :-)
Out front it's done with the shims at the top of the sups-shaft. But I don't like front droop. It's hard to get it the same at both side's and when it's "off" it will make your car drive really bad. You could also cut down a litte bit of the front spring, but then again, it's hard to get it the same... I don't use it.
Best Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 04-22-2010, 10:40 AM   #2312
sideways88's Avatar
Trader Rating: 34 (100%+)
download the 12r5 and and 10r5 manuals from the rc10 website and save them. do some comparison as to what you have going on. itll be easy to figure out which pats are incorrect. also, same them for reference. youll need the right side hub and cone as well. ive done this complete conversion beacause i scored my 12r5 very cheap on ebay brand new. i payed like a buck twenty five for it. it made the conversion very easy to swallow. good luck.
Already got it taken care of. the guy i got it from gave me the new part and took the old one. so its all good. but thanks.
car is fully built and ready to go now.
sideways88 is offline   Reply With Quote
Old 04-27-2010, 11:15 PM   #2313
Default Servo for 12r5.1
I know this has probably been answered but I was unable to find it on this forum...but can you guys give me a list of servos that will fit the 12r5.1? I want to be able to use the blue mounts that come in the kit if possible. Any help would be great!
JDavis is offline   Reply With Quote
Old 04-27-2010, 11:18 PM   #2314
sideways88's Avatar
any mini servo would work.
i use a airtronics 94819 http://www.hobbypeople.net/gallery/474519.asp
Old 04-28-2010, 01:39 AM   #2315
RC MARKET's Avatar
KOPROPO
PDS-951 ICS
RC MARKET is offline   Reply With Quote
Old 04-28-2010, 09:20 AM   #2316
Trader Rating: 26 (100%+)
Default Servo Mounts
I am trying to mount a JRZ3650 servo into my 12R5.1 and it does not seem to fit. Do modifications need to be made to mount this servo in the car? What servos are a direct fit?
svines1972 is offline   Reply With Quote
Old 04-28-2010, 09:26 AM   #2317
EricF's Avatar
the Futaba servos are a direct fit. Yes you will need to make new holes for the JR servo.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 04-28-2010, 05:43 PM   #2318
some of the futaba mini servos come with a set of horizontal mounts for what i guess is airplane use. just cut them off and smooth down the remainder with sand paper or a file
benben10 is offline   Reply With Quote
Old 04-29-2010, 02:20 PM   #2319
markhat250's Avatar
Trader Rating: 65 (100%+)
I'm new to on-road. Just wondering the difference between the 12R5.1 and the 12R5. I was thinking of going used 12R5 unless the .1 is a huge jump in whatever. Was hoping for some advice. Thanks.
markhat250 is offline   Reply With Quote
Old 04-29-2010, 04:01 PM   #2320
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I actually prefer the 12r5 when combined with the wider original style rear pod plates. I feel the older box style pod is less fragile than the 12r5.1 style. I have bent two cars worth of pod parts on my R5.1. Could just be coincidence though.
Old 04-29-2010, 06:24 PM   #2321
markhat250's Avatar
So it's just a skinnier car? That's it?
Old 04-29-2010, 06:50 PM   #2322
scribbler's Avatar
I used a Tamiya titanium screw kit on my 12R5, and I can't remember what the part number was. I remember it being all the correct screws I wanted. Can any body help me out with this. I want to get another of the same screw kits.
PLease help !!
scribbler is offline   Reply With Quote
Old 04-29-2010, 07:41 PM   #2323
Tubaboy's Avatar
The rear pod is shifted to center the motor more on the car. It's also a bit more open making it easier to take the motor in and out of the pod.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 04-30-2010, 01:19 AM   #2324
Any gearing advice for a lrp x12 8.5. The instruction says 40mm roll out on 4.8v. But I will be running it on lipo 3.7v. Is there like a general rule between the 2 types?
Cheers Tom
Tom87 is offline   Reply With Quote
Old 04-30-2010, 03:03 PM   #2325
markhat250's Avatar
I need a few suggestions on gear for a 12R5.1
I was mainly wanting info on what to run
1S Battery: ProTek 1S 4700 from Amain ok?
Servo: seems like mini Hitec has been brought up. Which one?
ESC: I was planning on the Mamba Pro 1S since I already own other MMP's.
Motor: I was going to go LRP X12 13.5
any help would be great.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
