Old 02-28-2010, 11:27 AM   #2236
Originally Posted by SlowerOne View Post
Smallest spur you can fit to any 12th car is a 76T (64DP). Below that you can't get the gear in the diff!!
The largest pinion depends on how far forward you can get the motor. Limited in a CRC, miles of room in a BMI DB12RR. Not sure on a 12R5.
Gearing is dictated by the motor. If you have a 17.5, then it's a 76 in order to get the ratio you need. A 13.5 will need an 80 or 84T, and 10.5 or above you can use an 88T or 96T. Look to the ratio you want to run and the tyres sizes you want to use before deciding on a range of pinions.
Your spur and pinion sizes will depend on the motor first, the tyre size second and the room in the pod third. HTH
How/why does a spur gear relate to the motor being used? If I needed a particular gear ratio for a 13.5 and change to a 17.5 and still get ratio I need for the 17.5 without changing the spur, why do I need to change the spur gear?
RoyU is offline   Reply With Quote
Old 03-02-2010, 11:10 AM   #2237
racing_jason's Avatar
Default excesive tire wear
Just a quick question
I run on a track with med traction and was wondering what would cause excesive left rear tire wear. (when i say excesive i mean i can start with a tire at 1.7 and finish with about 1.63) We have about an equal amount of high speed corners left and right. Could it be my diff being to tight to loose? pre load on side springs?
any help would be great!
Thanks Jason Hunt
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 03-02-2010, 07:59 PM   #2238
ZiG-87's Avatar
So I just took apart the diff on my r5 that I bought used, and noticed that two of the ball bearings are silver, and seem ever so slightly larger than the rest, which are black. This also seems to have the effect of making the spur gear wobble a bit side to side when everything is put together. Wtf? Has anyone seen this before?
ZiG-87 is offline   Reply With Quote
Old 03-02-2010, 08:05 PM   #2239
RacinJ's Avatar
Time to replace your diff balls and rings.
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 03-02-2010, 08:15 PM   #2240
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Thanks Jason Hunt
Gonna go over the obvious list here. Please do not take offense.
Are you seeing this wear inside of an 8 minute run?
Do you rotate your tires from left to right after every run?
I'm guessing your track runs counter clockwise?
If this is the case there will always be 4 more right turns then left. No matter what.
The extra right turns needed to complete the course will cause the left tires to wear sooner than the right. This is why it's important to rotate the tires every round.
If you see this type of wear inside of 8 mins, you may want to go over the setup as well as how you are entering the turns. If your car is sticking the front end and sliding the rear, this may cause excessive wear.
Some more info on your setup may help.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 03-03-2010, 12:58 AM   #2241
Robert_K's Avatar
Some guy's do this because of the hardness of steel and ceramic/carbid balls... I've not tested it myself. But some say the carbid balls wore out more, then the steel, and to have a long lasting diff the put in some steel balls to give it more lifetime. Personally I'm runnig ceramic balls only.
Wobly spur is a good thing. But not "to much". It must sit free between the diff plate's or else the diff will not run as smoot as it should be. The platse wil then be touching the spur gear which causes friction. But make sure you only use 1/8 balls and no balls are bigger or smaller, that's not a good thing...
Somewhere in the 1:12 scale topic these a good building manual for your 12th scale diff, try folowing that :-).
Best Regards,
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 03-03-2010, 01:01 AM   #2242
Robert_K's Avatar
+1
Make sure you rotate your tires after every run...
Also make sure your car is not "drifting" or "sliding" on the left turn corners. Oversteer wears the tires more then just running....
How long do you soak your tires, and with what additive? longer soak will make the tires wear more...
Best Regards Robert
Old 03-03-2010, 12:30 PM   #2243
Originally Posted by Robert_K View Post
+1
Best Regards Robert
Sorry guess i should posted more infor lol sorry
Front End
DBL Pink Front tires 1.65
.020 Spring
10 degree with caster shims to the back
widend the front by 1mm
10k on king pin
Batt In forward position
Center Shock
Red Spring
30wt oil
blue side springs
25wt side shock
Rear Tires are either pink or yellow depending on the night at 1.70
Soak wise i use roughly about 10min and wipe right before the run
I always rotate the tires on front and rear. And this tire wear is threw a full 8 min main or qualifier.
One theory i have is that the rear tires are to soft? could this be a possability?
Thanks Jason Hunt
Old 03-04-2010, 07:27 AM   #2244
Default let me ask again...
is anyone running a sedan or nascar style body? if so what you runnin'?
thunderdaddy is offline   Reply With Quote
Old 03-04-2010, 07:39 AM   #2245
Tech Legend
Cain's Avatar
Trader Rating: 230 (100%+)
mccallister racing from what I understand makes a body like that.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 03-04-2010, 01:21 PM   #2246
Robert_K's Avatar
Front End
.020 Spring
10k on king pin
Center Shock
Red Spring
30wt oil
blue side springs
25wt side shock
Thanks Jason Hunt
Set-up doesn't look wierd, only think I don't understand is the red spring in combination with the pretty soft tires... Why not use the blue spring with a Magenta (bit harder) tire...
Yellow is pretty soft, and wears hard, when the grip is high.
Best Regards
Robert
Old 03-04-2010, 10:22 PM   #2247
Best Regards
Robert
that is what i was kind of leaning toward to do to see if it would make some wear changes.
thanks for the idea i appriciate the help!
Jason Hunt
Old 03-05-2010, 07:10 PM   #2248
Maybell's Avatar
Default 2010 1/12 European Championships
So far so good for the A-team at Euros! 1st and 2nd on the grid in the modified class after 2 rounds!
There is coverage on RedRC. Maybe more coverage somewhere else, Im not sure.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-05-2010, 10:22 PM   #2249
Is the setup a few posts earlier for 17.5??? I have tried looking around for 17.5 setups and havent found many? Can someone send me a link to one.
Thanks!
gguertin145 is offline   Reply With Quote
Old 03-06-2010, 10:48 PM   #2250
I have just recently bought myself a 5.1 and I m seeking some advice on setting my little car up given the fact that the 1/12 class in Greece is currently non-existent. In order for you to help me out I have to give you as many facts as possible. So, our first race will take place on this ( http://www.elmegallery.gr/displayima...album=35&pos=4 ) track and we currently dont know which layout we will use. Certainly we will have to use one of the two straights which are approx 65-85 feet long, depending on which one we run. A bit bumpy when compared to the tracks you run in the UK and the US.
Traction should be considered low, as on the same day, a 1/10 touring class race will take place too. Otherwise, I would consider it extremely low as the track is not treated with any traction stuff at all.
Mod motors are allowed and my pit bag carries a 4.5, a 5.5 and a 7.5 with 1s lipo and an ESC choice between SXX TC and SXX stock.
Tyre choices are limited to CRC normal and pro-cuts.
Given these facts what equipment would you run on this track? What roll-out would you consider as a good starting point? What tyres?
Any help on this would be very much appreciated.
By the way, keep in mind that given the amateur level of all of us, anyone who manages to have a consistent car, even if it is a bit slower than the others, will definately win this race by miles.
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
