Old 02-15-2010, 05:43 AM   #2191
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I always run mine all the way up. As many adjustments as there are on a 12th, I leave that one alone for the sake of simplicity and consistency. I don't need any more adjustments to try and confuse me!
Old 02-15-2010, 12:09 PM   #2192
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Same for me.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 02-15-2010, 01:14 PM   #2193
Maybell's Avatar
Originally Posted by D34no View Post
what is the best way of setting the side spring? also do you run any preload on them?
This is hard to describe in writing , so bare with me...
The procedure for checking preload is: pick up your car and look at it from the side. Compress your center spring until your pod is flat with the chassis. Barely touch one side spring to the lower pod plate. Hold it there and look across at the other spring to check preload.
Set your springs with a TINY amount of preload and then set your tweak...
This is a good place to start and I hope this helps.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-15-2010, 02:53 PM   #2194
I have just bought my self an 12R5.1. and i read that alot of you guy's are adding these alu.braces to the carbonfiber piece that hold the side springs.
What good does it do performance wise? i am just a newbie looking for answers to learn new things
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 02-15-2010, 03:39 PM   #2195
The only reason I have it on my car is because I bent a couple of the aluminum standoffs included in the kit. Its for durability, not performance. I have heard a couple guys say it affected their car this way or that, but I don't buy it.
Old 02-15-2010, 08:49 PM   #2196
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Ok. Just bought my 12R5.1 tonight, and not off to a good start. The kit was missing the O rings for the shocks! They are identical to the O rings used in past AE 1/12 scale shocks, correct? Anyone else have this happen?
Another question, anyone try side springs from other compaies? Just curious. Any info will help. Still gettin parts outta the bags. Hopefully I'll have it ready for this Saturday.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-16-2010, 01:21 AM   #2197
Robert_K's Avatar
+1 The springs need to "thouch" the links with a little preload. When the car feels difficult to drive you can ad a little pre load (1/2 turn). You also need to adjust your tweak with these springs, Make sure the don't have a big difference when your tweak is set. When the have a to big difference, therse something else wrong....
O Rings ar not the same as the L4 shock, if I'm correct.
I used CRC Side Springs on the Euro's, but they are way to hard. The car feels really bad with these. Just use the blue one's I'm almoste only using these or the Gold or Silver ones... Start with the blue's
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 02-16-2010, 04:22 AM   #2198
Trader Rating: 241 (99%+)
I have spare o-rings if you need them.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 02-16-2010, 10:14 AM   #2199
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
got a 12r5.1 on the way.
What are some of the issues to keep an eye out for on the car?
Never done 1/12 before but figure this would be a good class to get into out here and free up a vehicle for one of my girls to run.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-16-2010, 12:36 PM   #2200
EricF's Avatar
- front lower suspension arm, sometimes the pivot balls are too tight (I thought it had been corrected, but as of late it seems like it may be occuring agian)
- upper arm -make sure you thread the turnbuckles in as straight as possible (that will make camber as caster adjusments more accurate)
- shocks -dry fit the caps so that you can get a feel for how they go together. For some they are easilly cross threaded.
That's all I can think of for right now.
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-16-2010, 01:47 PM   #2201
AE-Reedy
Yes same o-ring as previous micro vcs shock. We made a new part number for this kit because you only need o-rings, not all the other rebuild parts in the previous shock.
Most people seem very happy with the kit blue springs, others will fit if you wish to experiment.
Sean Cochran is offline   Reply With Quote
Old 02-16-2010, 03:13 PM   #2202
Thanks bro!
Make sure you have O rings in the kit! LOL!
Thanks for all the info. I just got off the phone with Don at AE, the replacement O rings are goin out tomorrow! Woo Hoo!
Three words...
Old 02-16-2010, 04:41 PM   #2203
Tech Legend
Cain's Avatar
so, whats the final word on the metal chassis brace?
Old 02-16-2010, 05:54 PM   #2204
Ok I'm an IDIOT. I just found the O rings. Apparently, bag AA which contains the O rings is not in bag A where I thought it would be. It was in the bag with the CHASSIS! Needless to say the shocks are built and are rather smooth. Now I gotta call Don at AE and tell him to not ship the O rings.
Three words...
Old 02-19-2010, 07:57 AM   #2205
Tech Legend
Cain's Avatar
anyone?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
