Old 02-12-2010, 04:42 AM   #2176
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
Just out of curiosity has anyone tried the new SpeedZone split-pack with the 12R t-bar conversion?
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 COMING.... -- Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 02-13-2010, 02:24 PM   #2177
Default lower a-arms and pivot balls
i just recieved the new ae lower a-arms and bought new pivot balls to start from scratch. after assembly the balls were tight, tight, tight to the arms. nothing loose what so ever. top arms are fine. simply put, my front end doest work. what on gods green earth is going on here. im no new-b to rc cars but this really blows. am i pissed, yes sorry. how can i stop this front end from moving i applied epoxy to it?
thunderdaddy is offline   Reply With Quote
Old 02-13-2010, 02:29 PM   #2178
its like the pivot balls have been epoxied to the arms, sorry. no movement what so ever.
Old 02-13-2010, 06:16 PM   #2179
Have you got a ball removal/install tool? If so, pop them out and in a couple of times.
Ed M.
bentgear is offline   Reply With Quote
Old 02-13-2010, 07:52 PM   #2180
Originally Posted by SMG View Post
New price on Chassis Braces. $15.00 Shipped (lower 48 states).
paypal accepted... PM me for account info if interested.
Thanks Steve
SMG Machining
SMG YGPM
sdunnmcp is offline   Reply With Quote
Old 02-13-2010, 08:57 PM   #2181
Originally Posted by sdunnmcp View Post
SMG YGPM
Holy Moly you need more braces?!!!!! I sent you 2 already, How many 12R5's do you own?!!!
Old 02-13-2010, 11:14 PM   #2182
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Slide a 1/8" kingpin into the ball and use a pair of pliers to "squish" the lower arm around the ball and kingpin. Do it from several sides. Also see if there is some material in between the arm and the ball. Sometimes snapping them in without a pivot ball snapper inner shears off just enough plastic to give the result you mentioned.
Old 02-14-2010, 04:58 AM   #2183
i finally got them to loosen up. just dont ask how many times i popped the pivot ball in and out.
Old 02-14-2010, 04:59 AM   #2184
Default transponder...
what brand transponder are the holes (3) in the chassis drilled for? thanks in advance.
Old 02-14-2010, 05:18 AM   #2185
Joost K.'s Avatar
AMBit / MyLaps transponder. The old and the new version fit... This is by far the most used transponder in the world and therefore many companies use these mounting holes...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 02-14-2010, 05:35 AM   #2186
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by ZiG-87 View Post
Guys, quick question - What's the best way to hold a 4 cell battery in place? The instructions don't seem to actually mention how to secure the battery....
Originally Posted by pakk View Post
battery strapping tape
Originally Posted by AreCee View Post
Pick up a roll of tape at the track or LHS and don't use the cheap office supply stuff, most of those are OK but the RC specific tape works better.
Originally Posted by Capt'N_Slow View Post
ZiG, Goto the local Canadian Tire. Look in there packing tape section you will be looking for a roll of !!! Strapping Tape !!!.
It's about 2cm (1/2 inch) wide and you will see fibre strands all the way across it. Do not get the clear stuff as that is packing tape.
Try these!
http://www.officemax.com/office-supp...oduct-ARS25451
This is what I've been using. Works great.
http://www.officemax.com/office-supp...oduct-ARS19439
One trick I do is to store the roll of tape in a zip loc bag too keep it clean.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 02-14-2010, 08:30 AM   #2187
None but I want to make some other parts....
Steve Dunn
Old 02-14-2010, 08:41 PM   #2188
Steve Dunn
? Why did you want braces if you don't own a 12R?
Old 02-14-2010, 08:43 PM   #2189
ZiG-87's Avatar
Originally Posted by SpraydbySprague View Post
Try these!
Ah, I went and paid $16 for a roll at the LHS before I saw those other replies.
Oh well, it's a big roll and should last a long time. When I need more I'll grab some from the hardware store.
ZiG-87 is offline   Reply With Quote
Old 02-15-2010, 01:31 AM   #2190
what is the best way of setting the side spring? also do you run any preload on them?
D34no is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
