Old 01-02-2010, 08:19 AM   #2011
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
yeh I had a little binding issue with mine as well, just like the guys say, shine the king pins, and try putting the ball in and out a couple of times rotating them to different spots. I used comm drops in mine, free as a bird now Hope this helps
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 01-02-2010, 08:32 AM   #2012
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by geubes View Post
finished my 12r5.1 kit and I found that I need to space the wheels an extra 1mm each side to keep them even and to stop the rear left (non-diff side) wheel from rubbing against the rear pod. I am using Jaco Yellow on prism rims. Once shimmed 1mm each side the rear width is 171mm.
Also one slight issue, which im hoping will bed down on its first run tomorrow, is that kingpins dont seem to have a smooth action through the arms. I made sure all the plastic pivot balls were pushed in the correct way.
I have no lube on them at the moment.
Any ideas? or will this smoothen out after a run or two.
The rear tires rubbing on the pod can easily be cured with a tire truer, by cleaning up the excess glue/foam that extends beyond the inner edge of the rim on the Jaco wheels.
Old 01-02-2010, 11:39 AM   #2013
Send a message via MSN to geubes
Thanks.
Shining the king-pin has helped a lot, but you are right that the balls aren't freely rotating.. 1 is but the rest stick or are stiff.
Ill try popping them in and out a few times to make sure there is no mould marks, and ill try adding some com drops or other lube.
geubes is offline   Reply With Quote
Old 01-07-2010, 09:45 PM   #2014
I just started using 1s lipo in my 12R5.1, should I change the front, center and side springs? What color? Change shock oils? Weight?
RoyU is offline   Reply With Quote
Old 01-07-2010, 10:06 PM   #2015
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Sean's set up on the AE site is a great starting point.
Old 01-09-2010, 05:05 AM   #2016
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Hey guys, tomorrow i will race at a carpet track. Any one have starting point in setup?
I am using the 12R5 and regular cell batteries.
Riketsu is offline   Reply With Quote
Old 01-09-2010, 05:30 AM   #2017
rack's Avatar
Trader Rating: 64 (100%+)
I can not find the setup on ae does any one have a link.
rack is offline   Reply With Quote
Old 01-09-2010, 05:46 AM   #2018
Check this page out for setups. Its where I got mine from
btw im not able to post links yet, until i met a post limit, so you will have to follow these instructions.
go to petitrc.com
browse the left until you see setup sheets and manuals, click that. Then find 12r5
Loads there for different grip, surface.
Old 01-09-2010, 05:56 AM   #2019
http://www.petitrc.com/reglages/asso...tedRC12R5.html
Arn0 is offline   Reply With Quote
Old 01-09-2010, 06:52 AM   #2020
rack's Avatar
thank you for the links
Old 01-09-2010, 09:23 AM   #2021
all of my setups are on the website. The best setup i have found is the one under this years indoor champs. This also works very good in 13.5 and 10.5. It has not been tested in 17.5. setup is 2009 us indoorchamps.
here is the link to the setups . then search drivers look for me or set it for the car.
http://67.199.85.166/racing/setups.php
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 01-10-2010, 12:21 AM   #2022
Mike
Hi Mike!
Your new setups are from 12R5.1?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-10-2010, 12:36 AM   #2023
TommyBlazin's Avatar
for the front end kingpin for the shock, is there a aftermarket company making them that are silky smooth, so you dont have to polish, i already found the balls from, ksg, the oval guys have the precision game down tight!!! thanx
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 01-11-2010, 06:58 AM   #2024
speedsterblade's Avatar
thinkin of a 1/12th scale.. found a decent deal on 5r I spend some time trying to figure out the differences from 5 to 5.1... can 5.1 parts be obtained to update the 5?
Thanks.
______________________________
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 01-11-2010, 07:08 AM   #2025
EricF's Avatar
Thanks.
Yes they can, there was a list somewhere in this thread but I don't recall where... I think the part #'s are 4687, 4688 and ther are 2 others.
left and right pod plates, pod brace and graphite upper pod plate. Note: if the car does not have the 10r pod plate conversion you will also need the wider lower graphite pod plate.
I think that's all...
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
