Old 12-28-2009, 07:23 AM   #1996
bl4
bl4's Avatar
Originally Posted by defcone View Post
Just look around the model street, Kwong Wa Street. Around 90% of the rc shops are located there. If you're going by mtr, get out at D2 exit and walk to the end where Kwong Wa hospital is located. Turn left, walk past one set of lights, past the escalators which go up then you'll see an indian food shop with a bb gun shop. Walk inside that tunnel and you'll see the first batch, walk towards the end of the tunnel and keep following right you'll see another 6 or 7 shops, can't remeber.
Thks for the info
bl4 is offline   Reply With Quote
Old 12-28-2009, 07:30 AM   #1997
Trader Rating: 45 (100%+)
When walking through there I felt like a kid in a candy shop!!
Apex is offline   Reply With Quote
Old 12-28-2009, 01:28 PM   #1998
New to the 1/12 scene, was looking at getting the 12R5.1/ or Gen X (neither available right now), would i be better off waiting for those cars or getting a 12r5 (NOT 5.1) right now, ill be running brushed till i get my BL setup next month or so. And it seems i can upgrade to the 5.1 setup quite easily.
Only reason I ask is i can get a 12R5 next week instead of waiting till end of month. Thanks
scatterbrains is offline   Reply With Quote
Old 12-28-2009, 01:32 PM   #1999
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I would wait. I will cost $60-$80 to upgrade after the fact and the extra room for the BL motors is very nice, not to mention it allows you more clearance under the body with the 12r5.1.
HTH
Old 12-28-2009, 01:38 PM   #2000
Thanks, thats pretty much the consensus ive gotten thanks again
Old 12-28-2009, 03:20 PM   #2001
Trader Rating: 5 (86%+)
Default CRC Tires
Has anyone run CRC tires on their car..if so what is the difference between them and jaco tires...someone told me that you had to shim out your car or something...can someone explain...
obi wun is offline   Reply With Quote
Old 12-28-2009, 03:31 PM   #2002
The off set is different on the Jaco and CRC wheels. If you've been running Jaco wheels you will need to remove approximately 1.5 mm from either side of the axle to get the same rear wheel width. I am going to try the CRC Yellow rears and grey fronts tomorrow and will have a better idea of how they compare to a Yellow/dbl pink Jaco set up.
Old 12-28-2009, 04:24 PM   #2003
GasGod's Avatar
Wow thats a lot--
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 12-28-2009, 07:38 PM   #2004
Ffejdat's Avatar
My experience with CRC wheels on a stock old style 12R5, not the newer 10r5 pod parts or the 12r5.1 is, The CRC wheels will NOT fit the car, you can not shim the rear end properly to be centered and under legal width, the solution for me was to cut the inner shoulder on the left hub down a little. Basically the if you run NO shims on the left, and enough shims on the right to center the axle and wheels, the overall width is too wide. Other than that, they work good, I think the CRC tires don't peel as bad as jacos, but the rims are weaker, easier to punch out the center of the wheel in a crash. Just my .02 $
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 01-01-2010, 06:01 PM   #2005
SMG
So what tire/wheel combo works the best with the 12r5.1? How are the parma wheels?
SMG is offline   Reply With Quote
Old 01-01-2010, 09:40 PM   #2006
For spec classes 10.5 and slower I run jaco yellow rears and black fronts. In mod magenta's front and rear. Hope this helps.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 01-02-2010, 02:36 AM   #2007
Send a message via MSN to geubes
finished my 12r5.1 kit and I found that I need to space the wheels an extra 1mm each side to keep them even and to stop the rear left (non-diff side) wheel from rubbing against the rear pod. I am using Jaco Yellow on prism rims. Once shimmed 1mm each side the rear width is 171mm.
Also one slight issue, which im hoping will bed down on its first run tomorrow, is that kingpins dont seem to have a smooth action through the arms. I made sure all the plastic pivot balls were pushed in the correct way.
I have no lube on them at the moment.
Any ideas? or will this smoothen out after a run or two.
geubes is offline   Reply With Quote
Old 01-02-2010, 05:05 AM   #2008
You need to shine the king pins. Take the king pin and put it in a dremel about 1/4 way in. Take some car wax (any kind - happich simichrome works well) and put on a rag. Then place the king pin in the rag where the wax is and turn on the dremel to slow medium. This will start to shine the king pin. Do this for about a minute and check the king pin. You don't want to do too much to cause the diameter of the king pin to decrease causing extra play. Then turn the king pin over and shine the 1/4 part. Be careful in not scoring the king pin when inserting in dremel. Clean the king ping and it's ready to go. I'm sure other racers have other ways to do this, but this is how I've done it in the past to get a smooth front end.
Old 01-02-2010, 07:09 AM   #2009
Ffejdat's Avatar
Before polishing the kingpins, I would look at the balls, see if they have a burr or a rasied edge on them that is binding up the pins, it is very easy to damage the balls putting them in or to have some mold flashing there, the ball also needs to pivot freely both in the upper and lower arms, the kingpins are pretty smooth as is, polishing them will help a little, check the balls first.
Old 01-02-2010, 07:27 AM   #2010
Anyone know if aftermarket steel\aluminum front end balls are made for the R5?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
