Old 12-26-2009, 07:50 PM   #1981
Trader Rating: 23 (100%+)
Originally Posted by spurcheck View Post
I need some suggestions on spare parts to get for the 5.1 car. I just changed over to this car and my local racetrack does not have a hobby shop onsite. I know it would be best to just purchase a second car, but if any of you guys could list the most probable spares to get and prioritize would be appreciated.
Side links! I see guys at our track break them all the time. Lower frt arms and maybe a set of castor blocks in case you strip the screws. Other than that, it's just routine maintenance items like frt springs, shock rebuild kits, diff balls and maybe an extra spur gear. Of the graphite parts, the likely one to break first would be a top or bottom pod plate but I don't see that very often.
SteveL is offline   Reply With Quote
Old 12-26-2009, 08:01 PM   #1982
oops dbl post.
Old 12-27-2009, 06:59 PM   #1983
spurcheck's Avatar
Originally Posted by AreCee View Post
Depends on how hard and how often you hit the walls and other cars
Obviously you should have spare bearings (front, rear and diff), shock rebuild kit, front springs (0.20"), the front end plastic parts and that is about it. You should have at least one extra spur gear and spare diff balls (they always seem to disappear when rebuilding the diff.
Thanks for the response AreCee. I am good on gears, diff balls, bearings and front springs. I will order the shock rebuild parts and front end plastics.
The Punter or The Punt-ee,,,,,,,,,,,,,,,,,,,who you be??
No Apologies Racing, don't believe me, try me!!!!!
spurcheck is offline   Reply With Quote
Old 12-27-2009, 07:03 PM   #1984
SMG
I just purchased a 12r5.1. Can someone please tell me what would be a good servo and what size of servo to get? thanks
SMG is offline   Reply With Quote
Old 12-27-2009, 07:06 PM   #1985
spurcheck's Avatar
Thanks for the response SteveL. Yeah, I figured side links may be a high priority and now you have confirmed it. I will get the shock rebuild kit, lower front arms, castor blocks, springs, upper and lower rear pod graphite pieces as you have suggested. I am good on the diff balls and spur gears.
Old 12-27-2009, 07:10 PM   #1986
spurcheck's Avatar
I will be installing a Futaba S9602. Do not know the Futaba size specs, but you can probably find them on Futaba's site. Another possibility is the Futaba S9650.
Old 12-27-2009, 07:24 PM   #1987
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I run a 9650 in everything pan car. I've had two of them in 12 scales for about 2 years and haven't ever had a problem with them running about 48 weeks out of the year.
Old 12-27-2009, 07:25 PM   #1988
Breaking side links? Wow.
Old 12-27-2009, 07:53 PM   #1989
We have a number of new racers that tend to hit the wall at the end of the straight and the links break right at the end where they snap over the pivot ball. It does take a pretty big hit for this though.
Old 12-27-2009, 09:11 PM   #1990
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
how tight are the links on the balls to do that?
Trying my hand at electric in off season...TLR Sct 2.0---Trinity D4 10.5---HobbyWing 120 amp Black Edition---Trinity the "Brick"--Panther tires--Savox
TommyBlazin is offline   Reply With Quote
Old 12-27-2009, 09:47 PM   #1991
Default rc12r5 converted to rc12r5.1
what parts are needed to convert a rc12r5 to a rc12r5.1??
BITTY123 is offline   Reply With Quote
Old 12-27-2009, 11:38 PM   #1992
I've seen it posted numerous times on here but you'll have to extensively search trough a lot of pages
Here you go :
4688 upper pod plate
8511 lower pod plate
8536 motor mount
8537 left bulkhead
4687 motor mount standoff
4608 diff hub brushless
4609 thrust cone brushless
Cheers,
Erik
stical is offline   Reply With Quote
Old 12-27-2009, 11:42 PM   #1993
Trader Rating: 37 (100%+)
Futaba 9650 or Airtronics 94145
4TH Annual Fall Cla$$ic: Mike's Hobby Shop November 12-14, 2010 www.easttexasrc.com www.mikeshobbyshop.com 17.5 Rubber Sedan, 13.5 Rubber Sedan, 17.5 1/12TH, 13.5 1/12TH, WORLD GT, stock sedan and SLASH
EXPRESS MOTORSPORTS : SCHUMACHER MI3 : ASSOCIATED 12R5 : ASSOCIATED 10R5 : TAMIYA TT 01 : LOSI XXXT-CR : LOSI BK : TRAXXAS SLASH : LOSI SLIDER : CUSTOM WORKS OUTLAW
steve crane is offline   Reply With Quote
Old 12-28-2009, 01:07 AM   #1994
bl4
bl4's Avatar
Hi where can I get a good deal in Hong Kong for 12R5.1? Thks!
bl4 is offline   Reply With Quote
Old 12-28-2009, 02:05 AM   #1995
defcone's Avatar
Trader Rating: 15 (100%+)
Just look around the model street, Kwong Wa Street. Around 90% of the rc shops are located there. If you're going by mtr, get out at D2 exit and walk to the end where Kwong Wa hospital is located. Turn left, walk past one set of lights, past the escalators which go up then you'll see an indian food shop with a bb gun shop. Walk inside that tunnel and you'll see the first batch, walk towards the end of the tunnel and keep following right you'll see another 6 or 7 shops, can't remeber.
defcone is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
