Old 12-06-2009, 10:45 AM   #1921
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
I have had a little issue with the shock end fitting, other then that the car on the track doesn't lie, it's a performer, for me thats the bottom line.
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - AE TC5 VTA -- Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 12-06-2009, 08:00 PM   #1922
Just picked one of these kits up, anyone have good a 17.5 set-up?
Sanwa M12S---Awesomatix A800 ---Motiv---Defy---Orca
kobiwan is offline   Reply With Quote
Old 12-06-2009, 09:46 PM   #1923
Trader Rating: 27 (100%+)
im having a problem getting my 12r5 balanced left to right Im using digital scales and I have to put so much lr preload into it to get the front even and then it makes the car drive off the rear tire with more weight. I dont know if I should preload the front springs differently to make it even or do something different.
Jason Hack
madhammer is offline   Reply With Quote
Old 12-07-2009, 01:20 AM   #1924
evirobs's Avatar
I am also having the same problem with my 12R5. Using digital scale under each individual tire, my right rear is off by 40 grams when running brushless. I am thinking of shifting the ESC etc to counter-balance the weight. Is it recommended to balance the rear pod weight when using BL or just balance the chassis left-right weight without considering the rear pod?
Another thing, any recommendation in term of front-to-rear weight bias (40/60 or 30/70 or...)? What are you guys seeing when using 1s Lipo with BL?
evirobs is offline   Reply With Quote
Old 12-07-2009, 05:18 AM   #1925
GWH74's Avatar
If you have the standard r5 then you will have issues with balancing the rear pod with a brushless motor. The motor is about 3mm to the left of the idea position.
You can fit the 10r5 top and bottom carbon pod pieces. This will center the motor more and allow you to balance the pod. Or even upgrade to a 5.1 pod.
Moving the ESC or using the side springs to correct this plays havoc with the tweak
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 12-07-2009, 12:07 PM   #1926
xtrememadness's Avatar
Send a message via AIM to xtrememadness
has anyone noticed the reedy 1s pack is heavier on the non terminal side. im having trouble balancing the car as it wants more weight on left side. im using irs balance buttons maybe there is a better way what is everyones method of balancing the 12r5.1 thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-07-2009, 01:30 PM   #1927
Chaz955i's Avatar
John,
You can try teamassociated.com. If memory is correct you would choose racing -> setups which would bring you to a screen where you can then choose car type and factory driver. I haven't checked them all to see if there is a 17.5 specific set-up but you should be able to get a decent starting point. I think Mike Blackstock posts help in their forums so that may be a good resource as well. The way you were driving your TC yesterday I have no doubt you will have the 12R dialed in no time.
Later,
Chuck
Chaz955i is offline   Reply With Quote
Old 12-08-2009, 05:18 PM   #1928
wingman2's Avatar
Just wanted to say that after contacting Associated regarding the part fitting problems with my new 5.1, they are sending out replacement parts to try and see if that cures it. After looking into the main problem at the front end, it looks like the holes for the balls in the lower arm are too small. This is clamping the ball and making it tight. This in turn is making the ball clamp onto the kingpin, again, making that action very tight. Hopefully the replacement parts will arrive and will all fit just fine! Anyway, credit where credit's due, the guy at AE was helpful so we'll see how it pans out.
wingman2 is offline   Reply With Quote
Old 12-08-2009, 07:08 PM   #1929
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Sometimes popping the balls in and out of the arm 3+ times will loosen them too.
Old 12-09-2009, 08:30 AM   #1930
Trader Rating: 45 (100%+)
Yep, you have to make sure the red o-ring is seated below the rim of shock body. If not, it will be tough putting the shock end on. It might take a few tries getting it seated right cause if you put in just a little too much oil it won't seat in below the rim of the shock body.
If anyone knows of a better way to do this please share!!
Apex is offline   Reply With Quote
Old 12-09-2009, 09:04 AM   #1931
mkdut's Avatar
Trader Rating: 19 (100%+)
The best way I have found to get the o ring to seat is to "burp" the o ring. Put the o ring in, noticing that it is not seated properly, and then take the end of a small wrench and pull back on the o ring between the shock shaft and the o ring. This should release the excess oil and allow the o ring to seat. Put the cap on and away you go. Works every time.
mkdut is offline   Reply With Quote
Old 12-09-2009, 09:14 AM   #1932
+1 to this. This is how i do it and do not have any problems at all. My setups from Cleveland should be posted soon to the AE site. I am finding with 1s that everything i ran in the past is not as good. Seems like the car is too hard to drive and has way too much steering. Therefore i am trying new stuff all the time and i am getting close to the feel that i want. Just need a few more adjustments and i think we will be there.
Right now i have found that spacing out my front end at the arm mounts 3mm per side is making a huge difference on the track, But when doing this be prepared to go softer then you would normally run on the front spring. I did this at Cleveland and it made the car have more corner speed , But i think my front end was too stiff and caused the car to hike entering the corners.
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 12-09-2009, 07:15 PM   #1933
Blackstock you have a PM
Old 12-09-2009, 07:26 PM   #1934
Originally Posted by Chaz955i View Post
John,
Later,
Chuck
Chuck, Thanks for the info and the compliment as well. Yeah, my TC felt pretty good.
Old 12-10-2009, 12:15 PM   #1935
Hey, Mike what tires were you using? and the spring sizes, front and centre?
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
