Old 11-19-2009, 10:46 AM   #1861
Maybell's Avatar
Ive been getting some pm's lately asking for the parts list for converting a 12R5 to a 5.1...here it is...please excuse me if it has been posted already...
4688 upper pod plate
8511 lower pod plate
8536 motor mount
8537 left bulkhead
4687 motor mount standoff
4608 diff hub brushless
4609 thrust cone brushless
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-19-2009, 11:33 PM   #1862
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
hey guys are u running the 150mm cleanlly to the esc, assuming esc is placed on standard left side of car...want to order the tq wire, figuring the 150 is the way to go? thanks
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 11-20-2009, 05:03 AM   #1863
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I am running a 125 and it is perfect length. I 150 is the safe bet, but when I use it I have floppy left overs.I have an RS with the sensor port on the left edge of the chassis
Old 11-20-2009, 05:19 AM   #1864
GWH74's Avatar
Freshly build 12r5.1
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 11-20-2009, 09:39 AM   #1865
i have the sxx stockspec coming, better yet when avail, pretty much same location so a 125 will work for me?
Old 11-20-2009, 01:53 PM   #1866
I'm pretty sure you want a 125 with that esc if you're going to mount it with the sensor port on the left side of the chassis and the wires on the inside.
Old 11-20-2009, 04:46 PM   #1867
swimbikerun's Avatar
Trader Rating: 100 (100%+)
What's that on your diff? Doesn't look like the standard kit issue.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 11-20-2009, 04:55 PM   #1868
GWH74's Avatar
88 tooth 64p with Kimbrough diff covers.
Keeps the dust and grit out when running on outdoor tracks.
Old 11-20-2009, 05:00 PM   #1869
Maybell's Avatar
Those are aftermarket dust covers...If you dont use too much diff lube, you wont need them.
They may keep some dust out, but I would rather not add the rotating weight...
Old 11-20-2009, 05:28 PM   #1870
Thanks for the response. Does anyone make 1-piece front ride height shims like the CRC or Roche ones? I assume those will not fit the 12R5/5.1?
Old 11-20-2009, 06:50 PM   #1871
Maybell's Avatar
Please dont take this the wrong way, but could I ask why?
Since the screws that bolt the front end to the car are threading into a aluminum bulkhead, it is so easy and quick to make ride height changes. This is one of the things I love about this car. No more wrist cramps like the old front end!
Old 11-20-2009, 06:56 PM   #1872
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
http://www.fibre-lyte.co.uk/ makes carbon fiber versions for the old 12l4 and the 12r5/5.1.
CarlosG. is offline   Reply With Quote
Old 11-21-2009, 05:29 AM   #1873
I just like the way with the Tamiyas' you can just loosen the screws and slide the shims under the suspension mounts to adjust the roll center. For the RC12R5 I'm not the most graceful when underscrewing the front bulkhead to add or take away ride height spacers. It would be nice to just loosen the screws and slide a one piece shim in.
Old 11-21-2009, 12:32 PM   #1874
Maybell's Avatar
Good point! I getcha now...
Old 11-21-2009, 03:16 PM   #1875
Maybell's Avatar
Great looking car! ...and very nice wiring job!
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
