Old 11-14-2009, 03:40 PM   #1831
Maybell's Avatar
Originally Posted by Goingfast View Post
Yes I got you ...you added 2mm total to wider the front end to decease the steering and to stabilizing the rear....
I posted the entire setup...look at post #1818 and #1825..
Sorry, I should have just posted the whole setup in 1 post.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-14-2009, 05:27 PM   #1832
Goingfast's Avatar
Trader Rating: 29 (100%+)
Thanks sean
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 11-14-2009, 09:52 PM   #1833
oldandnew's Avatar
Hey guys I see the 12R5.1 comes with an airtronics servo saver. But LHS says that airtronics doesn't make a 12th scale stearing servo and the one supplied doesn't fit futaba is this true. And the futaba servo has ears on the bottom and front. Should you cut off the bottoms ones and use the supplied bulk head mounts? Sorry if I am using the wrong name.
oldandnew is offline   Reply With Quote
Old 11-14-2009, 10:46 PM   #1834
I guess your LHS doesn't like Airtronics but the 94761Z should work. The Futaba 9650 does work and they are both the same price $60. Futaba splines are 25 and Airtronics are 23. BTW Associated makes a servo saver from 23, 24 and 25 spline servos.
Yes you need to cut off the surface mount tabs from either servo.
AreCee is offline   Reply With Quote
Old 11-15-2009, 08:39 AM   #1835
xtrememadness's Avatar
Send a message via AIM to xtrememadness
the airtronics servo saver also fits ko propo 949. 23 splines
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-15-2009, 09:49 AM   #1836
And JR.
Old 11-15-2009, 09:52 AM   #1837
TommyBlazin's Avatar
difference is the airtronics is a hair stronger, and the futaba is a hair faster...and they both fit..
Trying my hand at electric in off season...TLR Sct 2.0---Trinity D4 10.5---HobbyWing 120 amp Black Edition---Trinity the "Brick"--Panther tires--Savox
TommyBlazin is offline   Reply With Quote
Old 11-15-2009, 10:53 AM   #1838
oldandnew's Avatar
Thanks for the info and fast response. Much appreciated. I picked up the futaba but they are out of the servo savers. And now I feel more confident cutting off the surface mounts. Thank you.
Old 11-15-2009, 02:41 PM   #1839
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
Hey fella's, stupid question, what size is the driver that you use for the top of the pivot balls, I'm using the hex key that came with the kit but I want to get a driver replacement.
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - AE TC5 VTA -- Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 11-15-2009, 03:00 PM   #1840
3mm if I remember correctly. I'll check when I get home.
Old 11-15-2009, 03:40 PM   #1841
Trader Rating: 45 (100%+)
I just checked and AreCee is right it's 3mm.
Apex is offline   Reply With Quote
Old 11-15-2009, 05:06 PM   #1842
Yah, I just got home and checked.
Also get a good 2mm since most of the screws use that size. (5/64" is the same as 2mm).
Old 11-15-2009, 05:48 PM   #1843
Thanks fella's I have a Hudy 2mm, I'm going to grab 3mm.
Old 11-15-2009, 05:51 PM   #1844
oldandnew's Avatar
Sorry for the stupid Questions but I am pritty new to the hobbie and brand new to 12th scale. But do some of the 12 scale bodys fit the 12R5.1 better then some of the others. I see the LHS has a couple of different ones but none of them are AE. Thanks
Old 11-15-2009, 06:42 PM   #1845
Since AE really doesn't make a body I doubt that you will find one. There are lots of choices from Parma, Protoform, Black Art, CRC and others. Protoforms new AMR body fits nicely and is a bit wider on top to accomodate the extra wires of brushless systems but is very thin.
Some of the bodies are good for mod and others for stock. There are versions of Audi GTPs and generics. Open or closed cockpits, your choice.
Go to Parma's, Protoform's or CRC's site to learn more.
BTW some of the racing bodies are very thin to save weight, those will tear easily as you learn to stay off the pipes.
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 01:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 11:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 09:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 10:56 PM
SEO by vBSEO 3.5.0
