Old 11-11-2009, 05:52 PM   #1816
GWH74's Avatar
Someone should speak to a company like Hyperdrive to make a brace similar to the Yokomo one.
I have a set of their r5 conversion bulkhead and they are very nice. The brace should workout cheaper then buying from HK
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 11-12-2009, 01:58 PM   #1817
AE-Reedy
Default New Factory Team Blue screw kits
Now available from AE Factory Team blue aluminum screw kits for the 12R5/5.1.
AE#8557
Kits contain screws that will work with either a R5 or R5.1 kit.
The kit is complete and contains even the hard to get sizes on the car.
It does not include the 4-40 wheel screws as they already come aluminum in the car kit.
Press release should go out tomorow with full details.
Sean Cochran is offline   Reply With Quote
Old 11-12-2009, 02:06 PM   #1818
Maybell's Avatar
Default 12R5.1 Front End
For those who are new to the 12R5 for carpet racing...
I have done a ton of testing lately and I want to share what I have learned about the front end setup. I have always liked 10 deg reactive caster on other cars in the past. The R5 has some wicked steering. I have tried every combo while learning about the car. I like a 5 degree angle with the lower arm spaced out 1mm on each side. No spacers to make the upper arm longer. My car is dialed with this setup. Smooth at high speed and entering the corner without pushing, then lots of middle-exit steering.
Everything else on the front end is stock. .20 springs with stock kingpin shims...3.25 upper arm spacing..be sure to make your rear width 171-172mm..
If you havent already, it is worth a try.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-12-2009, 02:14 PM   #1819
corallyman's Avatar
Trader Rating: 99 (100%+)
Maybell's car did look very good last night, the best I have seen it. Fast and smooth.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-12-2009, 05:28 PM   #1820
xtrememadness's Avatar
Send a message via AIM to xtrememadness
thanx sean im gonna try it but is this for 1c lipo or nimh
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-12-2009, 05:34 PM   #1821
corallyman's Avatar
1 Cell lipo
Old 11-12-2009, 06:59 PM   #1822
Originally Posted by corallyman View Post
1 Cell lipo
thanx corallyman
Old 11-12-2009, 08:04 PM   #1823
jkirkwood's Avatar
Originally Posted by DHMOTORSPORTS View Post
Hey guys not to change the subject here. But the 1s lipos with the deans connector. Where are you guys stuffing the connector on the car? I've been moving around for 2 days and am still not happy with the placement. Thanks
Originally Posted by jkirkwood View Post
For me under the shock. If you tape the wire down on top of the battery it won't be in the way of the shock. But I'm still not really happy with that. I have an idea for the next car I'm building up this week. I'll post a pic if it works. Kinda using a idea from someone else.
Sorry for the delay in this pick. I just got around snapping a couple. I ran this layout twice and it's working great for me. The chassis balances out perfectly also.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 11-13-2009, 12:30 AM   #1824
Robert_K's Avatar
I'm using the same set-up for all the track's here. It does really feel good.
How do you shim you upperarms? I'm Using 3.25 degrees.
Thanks,
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 11-14-2009, 10:12 AM   #1825
Maybell's Avatar
Thanks,
Best Regards
Robert
I am using the kit 3.25 setting also.
My rear end setup:
rear width 171mm
.8mm pod droop
25wt side shock oil
30wt center shock with gold spring, second hole from bottum of mount
blue side springs
Jaco tires: pink, double pink on a Paragon track....yellow, lilac on a Jack track. 1.72 inch rear tire, 1.62 front.
3.5mm ride hight front and rear.
Old 11-14-2009, 11:36 AM   #1826
Goingfast's Avatar
Trader Rating: 29 (100%+)
Good job....
I'm thinking about getting one myself...
what tires are you using and body?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 11-14-2009, 11:41 AM   #1827
Maybell's Avatar
Originally Posted by Goingfast View Post
Good job....
Hi Franko,
I am running the CRC Black Art body and Jaco tires.
Pink, double pink on a Paragon track and yellow, lilac on a Jack track.
Old 11-14-2009, 12:57 PM   #1828
Goingfast's Avatar
Hi Franko,
Thanks Sean
btw are you using the box stock setup ?
Old 11-14-2009, 01:39 PM   #1829
Maybell's Avatar
Thanks Sean
Franko,
Look at the posts above. I just posted my setup.
Old 11-14-2009, 02:36 PM   #1830
Goingfast's Avatar
Franko,
Yes I got you ...you added 2mm total to wider the front end to decease the steering and to stabilizing the rear....
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
