Old 11-06-2009, 07:37 AM   #1771
Lebatek's Avatar
Send a message via AIM to Lebatek
Originally Posted by evirobs View Post
hi guys, when using 1s lipo, do you place the lipo in the forward or backward position and how do you tape it to the chassis to prevent movement?
Any pics of yr car would be appreciated.
Envirobs, battery position is a tuning option. Since switching to 1S, I have seemed to prefer the forward position at most tracks for a more balanced feel, but I intend to test more. Just like with the NiMH cells, we use filament strapping tape and simply tape them in for each run. Use the supplied battery braces for the bulk of the support front-to-rear, and on the Reedy batteries, there are also little nubs that align with the slots in the chassis for added support. I have not taken any photos of the LiPo 12R5.1 yet.
Good luck!
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 11-06-2009, 09:08 AM   #1772
Originally Posted by RoyU View Post
What other shocks can be use for the side and center shocks? I stripped the shock rod eyelet while screwing onto shock body, kinda like the Serpent RCC shocks.
The HPI Cyclone 12 shock is nice and pricey. It does work well but you need to trim the shaft to get the right amount of droop.
The AE side shock is just fine the way it is.
AreCee is offline   Reply With Quote
Old 11-06-2009, 11:14 AM   #1773
AE-Reedy
Originally Posted by TeamBear View Post
Hey all, just bought my first pan car,a 12R5.1 and would have finished building it except that it has some parts missing, has anyone had any experience with dealing with Associated about getting replacement parts, cheers.
Just call or e-mail AE customer support and they will help you no problem.
Sean Cochran is offline   Reply With Quote
Old 11-06-2009, 04:29 PM   #1774
xtrememadness's Avatar
Send a message via AIM to xtrememadness
associated has one of the best customer service they always take care of my problem!!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-06-2009, 05:00 PM   #1775
Trader Rating: 14 (100%+)
thanks xtreme and sean,I will e-mail AE today and ask them if I can e-mail there 'missing items' sheet and receipt to them,cheers.
Understeer Radio Control Car Club
**MRJ Racing 02/2010 - 02/2017**
TeamBear is offline   Reply With Quote
Old 11-06-2009, 05:12 PM   #1776
does anybody have a good setup for 1cell lipo,4turn b/l on a non additive large track??
tamiya_008 is offline   Reply With Quote
Old 11-07-2009, 06:49 AM   #1777
oldandnew's Avatar
Had a ? I see the manual for the 12r5.1 tells you to file the edges of the chassis. Do you only have to file the edges that the batt. will set in? I think I remember hearing abouit sealing the edges of the carbon fiber parts with CA should this be done to all edges or only the outside ones? any help would be appreciated. Thanks new to this.
oldandnew is offline   Reply With Quote
Old 11-07-2009, 08:35 AM   #1778
File the battery slots so the sharp edge don't cut into the battery's shrink wrap shorting it out against the CF chassis.
CA ALL edges and even the countersink holes. That helps to prevent delamination.
Old 11-07-2009, 09:12 AM   #1779
If you are using a LiPo file the edges so the pack can rest flat on the chassis with the locator bumps in the slots.
If using a 4 cell pack file the edges so the pack cells rest even with the bottom of the chassis.
I normally file at a 45 degree angle. Don't get carried away......check often. Don't want the cells to drag on the carpet/asphalt if using a 4 cell.
Ed M.
bentgear is offline   Reply With Quote
Old 11-07-2009, 10:16 AM   #1780
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Ed M.
If your lipo has a flat bottom I recommend NOT filing the battery slots. Use lexan pieces keyed to the slots to secure the lipo. The square edge in the CF will prevent the lexan strips on the battery from popping/sliding out.
Old 11-07-2009, 12:13 PM   #1781
oldandnew's Avatar
Thanks for the heads up guys. Much appreciated.
Old 11-07-2009, 12:35 PM   #1782
LOW ET's Avatar
Trader Rating: 95 (100%+)
i know what you're talking about but do you have any pictures so we can see how you've done it. i've seen it done a couple different ways.
LOW ET is offline   Reply With Quote
Old 11-07-2009, 12:48 PM   #1783
GWH74's Avatar
Here are some pictures of these plastic strips on a battery. These will ensure that the battery does not move around and always goes in the same spot.
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 11-07-2009, 12:52 PM   #1784
LOW ET's Avatar
this may not pertain to the 12r5 but what are the guys doing to solve this problem with the new style chassis' with out battery slots?
Old 11-07-2009, 02:06 PM   #1785
RC MARKET's Avatar
fixed in battery slot.
RC MARKET is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
