Old 10-02-2009, 09:54 AM   #1636
inconceivable's Avatar
Anyone here running the LRP SXX Comp ? If so, what settings and rollout have you found best for lipo / 13.5 on carpet (OCRC) ?
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 10-02-2009, 01:05 PM   #1637
PartTime's Avatar
speedo:2,6,2,3
trinity 13.5
roll out:3.05
novak 13.5
roll out:3.15
DK
PartTime is offline   Reply With Quote
Old 10-02-2009, 02:53 PM   #1638
Originally Posted by Apex View Post
When you say full caster you mean 6.15 degree block setting with all shims to the rear, right? Also, how did you have the battery positioned? I've always liked the magenta all around on link cars. Just seems to make the car corner nice.
Yes, Sorry. 10* blocks and 6.15* in shims.
Battery foward.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 10-02-2009, 02:57 PM   #1639
Originally Posted by mangoman View Post
Hi walter, thanks for posting those setup details.
I was wondering how you went with runtime, were you getting close to using capacity, and was that with a receiver pack?
Thanks,
Martin
No problems with run time for the next race I will run a 4.0
No I ran the novak booster in the 1/12th car
Old 10-02-2009, 05:02 PM   #1640
Hello Walter.
I noticed that you qualified ninth overall and 2 laps off the pace of TQ. Were you down on horespower or was the car just not very good. I always remember you being much quicker with brushed motors.
Travis
march to my own is offline   Reply With Quote
Old 10-03-2009, 06:31 AM   #1641
Scottmisfits's Avatar
Hey guys, I have a Futaba 9650 servo in my 12r5. I just got my ESC wired up and went to attach the servo saver, and I can't get it on. What servo saver have you guys been using? Kimbrough medium?
Nevermind. The stock one is for Airtronics. I just need to get the Futaba one.
Scottmisfits is offline   Reply With Quote
Old 10-03-2009, 07:00 AM   #1642
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Kimbrough 201. Use the lowest holes.
Old 10-04-2009, 05:47 AM   #1643
Ran the new car at The Gate in Cleveland yesterday. The car was very good right out of the box. Really didn't make any changes I hadn't raced since the champs. The one thing I did notice with the lipos is if you hit something it takes a lot longer to come up to speed. It also seemed like in the last two minutes the car flattened out, but the lap times didn't show it. Ran old tires from last year Parma purple and grey and like I said the car worked very well. I got a good baseline for laptimes so next time will start making changes. I also ran Jack and the car showed no signs of losing traction. This was all done with a 17.5 motor. If anybody gets to Cleveland be sure to check out the new and improved Gate it is awsome!
chuck
mackin is offline   Reply With Quote
Old 10-04-2009, 07:37 AM   #1644
speed-e's Avatar
Trader Rating: 28 (100%+)
That sounds like a question for Sean Cochran.
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 10-04-2009, 04:50 PM   #1645
After a 15 year hiatus from 1/12th scale, I've got a couple runs under my belt now with the 12r5. Here's what I've found so far. I started out with Sean's last LiPo setup and began making changes from there. The center shock (gold spring)and the side shock I have 40wt Losi in them and the car seems much more driveable now. Gold side springs seemed too much but the blues with some tension on them are pretty solid with this combination. Anyone else running this much dampening in their cars?
I've had some trouble with the yellow rear tires as well. They have great bite but after trying a set of greys the car felt more neutral and stable. The yellows want to roll the rubber off the rims after a few runs too. Is there something that I might be doing wrong or over looking? These are JACO's tires.
Thanks,
Curtis
Fantom Racing | On-Point Racing | Parma/PSE | www.4chobbysupply.com
cmenard is offline   Reply With Quote
Old 10-05-2009, 11:57 AM   #1646
Originally Posted by PartTime View Post
speedo:2,6,2,3
trinity 13.5
roll out:3.05
novak 13.5
roll out:3.15
DK
Thanks ..... what about the SPX. Would you run a similar rollout ? I'm assuming I'd run 2,6,1,1 with that ESC.
Old 10-05-2009, 02:19 PM   #1647
PartTime's Avatar
The SPX has more timing then the SXX. Would probly have to drop the roll out a touch.
DK
Old 10-05-2009, 08:13 PM   #1648
Trader Rating: 30 (100%+)
I put the new POD on my 12r5 this past weekend for the first time at the ROAR Nationals. I must say the car was dialed with it. All the room for the motor was awesome. It seems like the new top plate moves the center shock mount forward a bit. Sean would have to say for sure though.
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 10-05-2009, 08:16 PM   #1649
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Congrats on your Win Jamie!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-07-2009, 07:21 AM   #1650
Originally Posted by Sean Cochran View Post
Yes I re-drill the chassis for the JR servo. No I do not flip it over, I move it as far forward in the car as possible. It is also possible to shoe goo the servo but that obviously is a little messy to clean up when you have to remove it.
Sean,
Do you leave room for the ackerman adjusters or do you just move it all the way forward?
Mr Granone is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
