Old 08-26-2009, 10:32 AM   #1501
Joost K.'s Avatar
You can either use the ride-height shims or the #31286 FT Ballstud Washer, aluminum. These are a bit smaller in diameter, also FT blue and in two thicknesses...
I also use these shims to prevent bumpsteer by raising the ball-studs on the steering arms...
http://67.199.85.166/main/productdet...ory=4014.12r5x
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 08-26-2009, 12:06 PM   #1502
PartTime's Avatar
I like the stock ride hight shims. Very hard to see when installed.
DK
PartTime is offline   Reply With Quote
Old 08-26-2009, 12:49 PM   #1503
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
What effect does shiming the arms out at the mounts have on the car? Thats not something I have experimented with in the past.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | McFactory | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 08-26-2009, 03:47 PM   #1504
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
It feels to me like it calms the front end down. Something similar to adding shims to the axle. I am using some gold colored shims from an x ray sedan I had in my pit box.
Silver ball studs (they have longer necks than the black studs) also work perfect to remove the bump steer.
Old 08-26-2009, 04:41 PM   #1505
Joost K.'s Avatar
So true! But when I was placing that post I was referring to my Pro10 and there I have a lot of difference in diameter in the front tires between training and racing. I start with new tires for training and when they are near the right size I put them aside for races, saves some bucks & unnesserary truing IMO.
So on my Pro10 I use these shims because I can change them if the ride height changes and thus the alignment of the upper arms and turnbuckles. With 12th scale there is less difference in front tire diameter and therefore you can change the ball studs if you like... I still prefer using shims because I don't use the AE ball studs but Titanium versions from Square...
Old 08-26-2009, 07:47 PM   #1506
Originally Posted by Hyper_Mike View Post
I know this as been asked previously but I tried to search the thread and the Search function appears to be fubar!
What spacers are folks using to space the front arms 1-1.5mm out from the mounts? Are you using the spacers that are normally used to adjust front ride height? Something else?
I'm trying to get my 12R5 setup for the upcoming indoor season so any insight someone could provide would be greatly appreciated.
Cheers,
Mike
For setups, look here in addition of the rc10
Hope that's help!
Arn0 is offline   Reply With Quote
Old 08-27-2009, 11:29 AM   #1507
Thanks everyone for the input on shimming the front arms
I'm looking forward to getting back on the carpet and trying out 1s Lipo with this car!
By the way, I know this is the 12R5 forum but does anyone know whether the shimming-the-front-arms thing work well with the 10R5 too? Just curious 'cause the 10R5 is my "weapon" of choice for WGT!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 08-27-2009, 12:25 PM   #1508
HB Moose's Avatar
Cheers,
Mike
The 10R5 has the same front end components so shim away.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 08-27-2009, 12:31 PM   #1509
PartTime's Avatar
Cheers,
Mike
The 10R doesnt need to be shimmed. Throw in-line blocks on the front and call it a day. Thats how Im running mine right now. Only have 1 race but had plenty of on power steering.
DK
Old 08-27-2009, 07:05 PM   #1510
notch johnson's Avatar
Hey guys- Just wanted to drop a line and say THANK YOU to the customer service department over at TEAM ASSOCIATED they definately have their act together over there!!!! Thanks again guys!
www.topnotchseries.com TNT NITRO SERIES ROUND 3 @ DIALED IN RACEWAY 11-19-16
RACE LINE DESIGNS! Track Building Specialist! PM ME
Follow me on twitter @notchzilla or @topnotchseries
notch johnson is offline   Reply With Quote
Old 08-28-2009, 04:53 AM   #1511
mangoman's Avatar
Actually i contacted AE by email and received a reply the next day once i had woken up, was pretty happy about that
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-31-2009, 05:21 AM   #1512
PartTime's Avatar
Hey guys, need a little help. I have read all the online tuning guides I could find and they all say backwards of what is happening with my car.
I learned about bump steer the hard way fri. The car was almost undrivable! I had to go in for some testing on sunday to get the bump steer worked out. Ended up playing with the front end of the car. I dropped the 5deg reactive caster to zero to see if it would smooth things out. Well, it did smooth out the car going into the corner like I wanted but it added soo much steering every where else that I had to goto a softer rear tire and softer side spring and its still got too much steering. I thought it was supposta take steering out ?
Any ideas ?
If I cant find an answer then I will go back to the setup I posted on rc10.com but was hoping to make the car a little better. It can hang with the fast guys but would like to get it a little easyer to drive. Always looking for an edge !
DK
Old 08-31-2009, 06:08 AM   #1513
DK, When i come up there on wed and thursday. I will look at what ya got and we can get it easy to drive, But you will lose some speed from what i have found. But sometimes this is the way to go.
Mike
Any ideas ?
DK
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 08-31-2009, 07:37 AM   #1514
PartTime's Avatar
Mike
Ok. I will put the last known good setup on it and we can go from there instead of trying to tune the mess I have now.
DK
Old 09-01-2009, 01:34 PM   #1515
revracr909's Avatar
Trader Rating: 21 (92%+)
how is this the rc12r5.1?
ive ran electric and nitro off road over the past ten years and
was looking into getting a 12th scale pan, im going to be running
the gtb ss and 17.5 at first. Also what are good servos any
airtronics what fits the best?
Thanks for the help
Team Associated B44_T4
LRP_REEDY_JCONCEPTS_TEAM EPIC
www.jimmybabcock.com_www.wcrcr.com
revracr909 is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
