Old 08-23-2009, 06:32 AM   #1486
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Why not just use the lower pod graphite off the 10r5o. Considering the link po of the 10r5 is what we use for brushless and the 12r5.1 is using the oval car rear pods and new upper pod plate shoul be easy bolt in with current t plate conversion
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 08-23-2009, 08:55 AM   #1487
Won't work, The oval pod is a bit narrower.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 08-23-2009, 09:28 AM   #1488
Joost K.'s Avatar
Correct! The oval pod is narrower than the RC10R5/RC12R5.1 pod. And besides that, the oval pod uses a 10th scale T-bar and is has a nasty big offset to one side. It won't work, I have already looked into that. For me it is fairly easy to make parts out of carbon fiber so I don't worry about it. I will make a slightly wider lower pod plate and my problems are over...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 08-23-2009, 10:23 PM   #1489
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default The finer points in 12th scales . . .
I'd like to see if I can get a little bit of a database gathered from people. I've been paying more attention to how I mount my bodies lately and am curious to hear where others are mounting their bodies. For right now I am ignoring front to rear adjustments and focusing on height by looking at which holes in the posts different people have different bodies mounted on. I've been looking at this trying to keep anything from hitting the body, while still getting it as low as possible (the four things that seem to be the worst offenders are the battery plugs on the 4900 smc lipo, the motor solder tabs, the upper front arms, and the nub on the upper pod that the side shock attaches to. If you have any oddities used in mounting your body (ie Dan's foam donuts instead of the std body disks, or shims under the body posts to get heights that fall in between the holes). I have also noticed that the amount of reactive castor limits how low the body can mount in the front. I have to mount the body higher with 0 than I do with 5 etc. Also mention if you cut your body longer or shorter than the mold lines .
Protoform Speed 12
2mm Shims under F and R body posts
Std AE body disks with nothing else
Motor solder tabs shaved down
Battery bullets shaved low
Body cut at mold lines, centered on front wheel mold lines
2nd hole in front
3rd hole in rear
5* reactive
Racing on Carpet
Old 08-24-2009, 05:00 AM   #1490
Send a message via AIM to MIKE VALENTINE Send a message via Yahoo to MIKE VALENTINE
Originally Posted by xrayeddy View Post
I bought a Gen X used off here and it had a carbon fiber wide bumper, however, Im unsure of who made it. A foam bumper will not withstand my driving skills.
Like this:
I didn't see anyone answer this.
http://rc4less.com/Hyperdrive_Produc...4ecf2aaa4525bc
It's a hyperdrive bumper, for there 1/12 scale cars
MIKE VALENTINE is offline   Reply With Quote
Old 08-24-2009, 10:36 AM   #1491
inconceivable's Avatar
Originally Posted by andrewdoherty View Post
Here's a tip I found to get various thickness spacers for use in adjusting shock travel in the center shock. The standard spacer is 4mm. I happen to prefer a 2.5 to 3 mm spacer. So I use pieces of antenna cut to length. To do this I make a guillotine using an aluminum spacer the same thickness as my desired spacer thickness. I set the spacer vertically on my pit table and close off one end of the hole in the spacer with my droop gauge (any hard flat surface will do) Then I place the end of the antenna tube on the other end of the spacer and use an Exacto to slice down on the tube, and Viola! A 3 mm internal shock spacer. If you're really organized like me you make each .5 mm length out of a different color tube and keep several of each size on a small container. The main reason I do this to allow the shock to compress completely without creating excessive rear pod droop.
To use this smaller spacer do you need to make any other adjustments to the shock, ball cup, etc ? Thanks.
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 08-24-2009, 10:50 AM   #1492
AE-Reedy
In order to return the droop to normal you will need to shorten the ball cup also. Cut off the same amount from the ball cup that you remove from the spacer. It might be necessary to cut some of the threads off the cap to get the ball cup to screw all the way down.
This shock mod makes a big difference on less than smooth surfaces.
Sean Cochran is online now   Reply With Quote
Old 08-24-2009, 07:08 PM   #1493
RacinJ's Avatar
When are the new pod parts going to be available?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 08-25-2009, 10:45 AM   #1494
AE-Reedy
The last couple of parts are on transit to us now. They should be here next week, then it's on to the Distributors.
Old 08-25-2009, 10:49 AM   #1495
Joost K.'s Avatar
GREAT!!! Then I can order my 5.1 parts in a couple of weeks!!! YEAH!!!
Old 08-26-2009, 07:00 AM   #1496
MD
MD's Avatar
Trader Rating: 113 (100%+)
I m just getting into 12th scale. I have purchased a used 12R5. I'll be running a 27T stock motor with 4 cell nimh packs to get started. I'll be running on carpet. What basic set up would any of you recommend? Thanks for your time.
MD is offline   Reply With Quote
Old 08-26-2009, 09:22 AM   #1497
Joost K.'s Avatar
The stock set-up (built according to the manual) will work fine for you. Try that first and then along the way of upgrading the motor, speed & handling you can learn more about 12th scale and you can play with the set-ups but for a 27turn motor, the standard set-up will work...
Old 08-26-2009, 09:42 AM   #1498
MD
MD's Avatar
Joost K. - Thanks.
Old 08-26-2009, 10:10 AM   #1499
I know this as been asked previously but I tried to search the thread and the Search function appears to be fubar!
What spacers are folks using to space the front arms 1-1.5mm out from the mounts? Are you using the spacers that are normally used to adjust front ride height? Something else?
I'm trying to get my 12R5 setup for the upcoming indoor season so any insight someone could provide would be greatly appreciated.
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 08-26-2009, 10:28 AM   #1500
HB Moose's Avatar
Cheers,
Mike
Yes the ride height shims work great for that. They're even the "right" color blue.
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
*Team Associated RC12R5* Zdiddy R/C Items: For Sale/Trade 8 08-31-2008 12:03 PM
RC12R5 Setup Sheets Cubic$Racing Electric On-Road 2 06-20-2008 10:27 AM
Team Associated RC12R5 ammo Singapore R/C Racers 12 05-15-2008 08:37 AM
AE RC12R5 alana07 Singapore R/C Racers 3 03-27-2008 09:56 PM
