Old 02-12-2008, 09:23 PM   #1
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default discharge /charge rate for battery
hi what would be a safe discharge/charge rate for 2000mah nicd??
Proudly supported by......
Premier Model Supplies Pty Ltd
aussies1129 is offline   Reply With Quote
Old 02-12-2008, 10:36 PM   #2
I was just trying to figure that out myself, only for NiMH...
I can't tell you anything exact about NiCD, but from what Ive read for NiMH people generally seem to say 1C (1/1000 of your pack rating...IE 4600 charge at 4.6A) for regular charges, and around C/10 for breaking in/conditioning...
Thats NiMH though, cant tell you for NiCD...
I CAN tell you that the search feature on this forum, and google gave me a LOT of material to read over and really shed some light on the situation.
I recommend starting there
Red coupe is offline   Reply With Quote
Old 02-12-2008, 11:32 PM   #3
94eg!'s Avatar
Trader Rating: 17 (100%+)
NiCD can be charged at 4C which should result in a 15 minute charge time. For a 2000mah pack, that means setting it for about 8amps. If that scares you, go for 2C which would be 4 amps. As for discharging them, give it what you got.
If the pack is old, you may want to take it easy on it at first to check it's condition. Charge/discharge at a lower rate or at least in a safe area with eye protection.
94eg! is offline   Reply With Quote
Charge rate question? jimmie48fromRI R/C Tech Site Forum 1 04-13-2007 02:13 PM
ICE charge rate tc3blue Electric On-Road 7 04-20-2005 01:15 PM
What is correct charge rate for 2400 Battery? dragoneuh Electric On-Road 1 08-26-2004 04:23 AM
charge rate measurements The_Gaz Electric On-Road 1 06-10-2004 12:32 AM
SEO by vBSEO 3.5.0
