BMI DB10R!!!
#796
Johnny C???
Johnny C, what do the second holes for the dampner tubes do? I have 2 sets of holes, just behind the pod mount for the shock.
Another ?, on your last setup how much if any of the tires are you doping? And with what if used? Are cutting the widthe of the rear tire down ?
#797
The last setup, I was running 1/3-1/2 front and full rear, with Jack. With the stock width tire. Our club racing gets about 12 full heats and we have really really good consistant traction.
#798
More Steering
Jason,
Thanks for the help with the traction roll problems. The smaller tire diameter and gluing the outside edges solved the problem except for an occasional bicycle through one corner.
I only need 1 more thing to get the car perfect. More Steering!!!
Which change do you think would offer more steering 5 degree front blocks or moving the battery forward?
Right now the car has 10 degree blocks (1 front and 1 rear shim) battery centered.
#799
I would make 3 changes. Move the battery forward one notch, 5deg block, both shims back.
#800
More Steering
Of these three changes you recommended which one would offer the most benefit.
I don't like to make this many changes at one time without knowing which one solves the problem.
#803
any idea when that battery plate will ship??
Ritchie
Ritchie
#805
my order on invoice number 354765, I ordered a DBB1102
DB10RR Rear Pod Conversion Kit. it didn't come with the battery plate.
#807
You should have bought Gregs, its a bottom sucker . Good luck finding one though.
#810
Jason Schreffler is looking good at the snowbirds right now with his DB10R. This is his 2nd time running the car and is still getting things figured out and is top 3 so far for practice. Should be great once he gets situated and gets the final adjutments made. Jason and Larry are also on A main pace with the new DB12RR also. Its nice to finally have the car in the hands of a team driver at a big race.
