BMI DB10R!!!
#1052
Is there a difference between the Jaco and BSR Spec tires at the track?
The BSR are using larger diameter rims but how different (if any) is the foam?
#1053
#1054
The stock setup works well at my local track on outdoor asphalt with pretty good grip for 4 cell.
#1055
Centre Shock
which make springs should I buy for the centre shock?
looked on BMI website but only shows the kit one
what are you using?
what are you using?
#1057
Jason
do you know or have information how the PF Mulsanne works on the DB10R in compare to the Sophia? We have very open body rules here so I was running the Group-C from my pictures above until now. For indoors I also want one of these, just think which one to choose.
#1058
BMI Parts Lists
is there a complete parts listing for both the DB12RR & BD10RR?
link please
link please
#1059
48DP Pinion & Spur
if I use the above which pinion/spur combo which should I use to replace 31/100 64DP currently on the car to get the same rollout?
#1060
23/75 is a little less rollout but very close to 31/100
#1061
RTR today
TVR Tuscan Bodyshell
Orion Vortex Race ESC
Orion SHO 42's
Noaram 10.5BL motor on 59.5mmpr
Jaco & BSR Spec Tyres
7k in Dampers
Silver Centre Spring with 40wt & 2 hole (have some others to try)
Kit Front Springs
MRT PTX transponder
Orion SHO 42's
7k in Dampers
Kit Front Springs
MRT PTX transponder
#1062
hey guys whats the difference between the the r and the rr i want to get one but i havnt gotten any replies to buy the rr because they dont have it on the site so im just about to buy the r and get the rr conversion later
#1063
Bodyshell
which bodyshell suits the car for
1. low to medium grip?
2. medium to high?
2. medium to high?
#1064
It looks like the preferred body overall in WGT is the Sophia. I ran the DB9 and the IIC and with the exception of having to raise it hugely to make it legal I really liked it. The Corvette is pretty good too but it has a bit more push to it then the other bodies.
#1065
Here are a few pictures of my DB10R with the lipo tray I machined. The tray weights 28 grams and the car RTR weights 965 grams. I used the pre-existing mounting holes for the nimh retainer on the chassis to fasten the tray. I am going to mill most of the retainers off in order to decrease weight. Let me know what you think.
