BMI DB10R!!!
#841
I ran schreffs setup except with a stick lipo and 17.5 and couldnt get the car to make 5 minutes without screwing itself into the carpet at about 3 minutes into a race. It seemed to have a little entry push then mid corner do a 180 and couldnt figure out what was causing it.any suggestions?
#842
Sounds like you may want to go to the standard flex plate without the set screw. Lipo down the center will require a little different setup. We did try it and found the saddle pack is a much better handling setup. I would try to add all of your lead weight to the rear of the car. Try less camber(maybe 1.5 degrees) and maybe go to the 5 degree blocks with 4 degree of static caster.
#844
Has anybody found a good matching foam bumper for the car?
And BTW here's my car, going to try it out tomorrow
#846
Had my first practice with the car and wow - that was a blast! After driving 1/12 modified the DB10R with 10.5 motor in it seemed sooo stable and easy to drive right out of the box. I really enjoy the car, thanks to Jason and his team!
#847
Hi guys, I ran my DB10 today at our winter series meeting and I just wanted to post my thoughts on it. I ran the car at the beginning of the day where there was little grip and it was fantastic. Just straight out of the box, really REALLy nice! It was a little over geared at the time though and the next heat was about to start so I pulled it in for the time being. I managed to give it another run towards the end of the day, once we had some grip. It was still good but the front springs were too soft and the car was on the edge of traction rolling most of the time. Still, it was really awesome going around and the car did get alot of people talking about this car, and this class of racing. I normally race 1/12th circuit cars and used to race Pro10's many years ago so have some experience with pan cars but I have to say that for a car out of the box, on it's first time out on a big carpet track, well, it was awesome! Not sure what tyres I had on (they were out of my VERY old Pro10 wheel/tyre box) and it had a 9x2 in running a 4.8v pack and a Corvette b'shell. Cheers guys, Chris.
#849
#850
To solve that, Stormer Hobbies, just today, gave the 10"RR" a different part number so folks know they are getting the car they are seeking. Nobody wants to take a chance and get the wrong car. If you want the original or you want the RR, you want the specific car and you don't want the other. This should help.
This link shows both, and how they are accurately listed.
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
#852
Here's a pic of the track I ran the car on (we run clockwise). I need to borrow my friends tyre truer as the rears are quite big so have to run around 6mm ride height. Really enjoyed running the car around this track as the final three corners going onto the main straight could be taken as one long sweeping corner in you got the line correct and then carry MEGA speed down the main straight. A lot of people came over to my pit area after seeing the car going around and thought is was some sort of new TC with LiPo's and supa dupa brushless system. They were pretty shocked to see it was a pan car, with a brushed (albeit very quick) motor and only a 4 cell pack! We run in a couple of weeks at the last round of our series so I'll tell you my thoughts about the car once finished up there. Cheers, Chris.
#853
We have just started running carpet here in my area and we are all new to it. I have a DB10R and on the front tires I sauce them half way on the inside and have noticed that the area of the tire that did not get any sauce has glaced over after a few runs is this normal?
#855
