BMI DB10R!!!
#751
That was all taken into consideration. What we did was offset the hub so that with Jaco wheels, The rear axle will be centered and at 200mm exactly with 2mm of shims per side. We also went ahead and made new 2mm axle shims for this. You can now run the rear as narrow as 196mm if you like or go to the 205mm limit. All this and still have the beauty of the BL motors practically falling in and out of the pod.
#752
#754
JASON
Just got a DB10R for Christmas, are there any setups on your site or any where else for the DB10R I saw 2 and a blank sheet for the DB12R on your site but did not see any for the DB10R? (I race asphalt)
#755
Guys,
What/where are we getting arbors for these 1/10 pan wheels? I need an arbor for my Integy (same as Hudy, Ofna, 3Racing, etc arbors) truer but can't see anything on Stormers or elsewhere. Don't want to drag my old A/C MaxMod that we used "in the day" out as that would mean two tire truers to bring each race day.
Thanks,
Scottrik
Thanks,
Scottrik
www.corally.com
part number 15103
-=light=-
#757
Tire Arbour
I have a older 12V Hudy truer with a 1/12th adapter, the screw on end is tappered and locates the wheel perfectually centered when tightened, I thought it was only for the 1/12th wheel but it will work for the 1/10 JACO wheels too, just rememeber to remove the floating center locator sleeve on the arbour.
#758
#759
what brand and rating is the yellow center spring?
#760
JASON
What kind of center shock spring (weight and manufacturer) is this that came with my DB10R kit?
#762
I bought it used, so i don't know if its a kit spring or not, thanks. but i can say, whatever setup is on it, it is freaking dailed, although i did try laying the servo down and FOR ME, i like it better that way, (carpet)
#764
Well looks like we are going to have a WGT class starting out here. So it looks like after the Birds I'll be picking up a DB10R. Will the kit be available with the wide pod after the Birds? Is there going to be a version with a shortened chassis to maintain the wheelbase like the 12RR? I gotta start looking into some cool bodies for it too...so much to do...so little time
#765
