Old 02-10-2008, 12:34 AM   #16
The most ideal layout imo, is the JRXS-R. The motor is centered, battery centered. Doesn't matter how heavy the batt or motor gets, L/R will always be optimized.
redbones is offline   Reply With Quote
Old 02-10-2008, 12:56 AM   #17
JevUK's Avatar
Originally Posted by AdrianM View Post
You guys are thinking too much about mass centralization across the the chassis. Keep in mind its just as important along the length of the chassis. All the cars gear needs to fit in the smallest square (not rectangle) possible at the center of the chassis.
If you raced stock on a big track it would be more benificial to have the weight down the center line. If you raced mod on a track with lots of straights into hairpins you would be better off with it accross the middle.
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 02-10-2008, 02:42 AM   #18
protc3's Avatar
R.I.P. FK04 and TRF 414. The best chassis layouts that should never have gone away. Ideal for all tracks.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Any idea what kind of motor is this nazgul Electric On-Road 28 04-08-2013 04:02 AM
17mm Truggy mounted tires and Traxxas style 17mm adapters Cain R/C Items: Wanted to Buy 3 06-07-2008 09:33 PM
Buggy chassis damper, idea from subaru... WheelNut Electric Off-Road 11 02-07-2007 10:17 AM
motor guard idea Iceracer Electric On-Road 2 11-06-2006 09:29 AM
speed+metal=Rosstertail of sparks good idea or bad idea? TC3Racer87 Electric On-Road 6 11-13-2004 08:25 PM
SEO by vBSEO 3.5.0
