Not so fast, Gavin at Speedzone is working on a saddle 1s lipo. I've trial fit the dimensions of the pack on my 120 and it will fit so there is a viable lipo comming for the t-bar owners, just dont know when it'll be avalible.
I'll have a date for all on Friday so don't get rid of your s120 t-bar cars just yet!
Speedzone Cells & Brushless Motors - It's all About Performance!
Speedzone R/C - Radio Control Car Products and Accessories
Would love to see pics of it as well. Please keep us up to date.
Thanks.
Also has anyone thought of converting the current car to a link car? The key is the position of the lipo cell in relation to the rear axel. This would define how much space you would have to fit the swivel link to the existing hole.
Current Cars:
-Associated FT B44 & FT B4
-Xray T2 008 US Foam Edition & Serpent S120
Vintage Cars:
-Losi Jrx2 & Tamiya Avante
is serpent going to put a setup book together for the s120. I don't know what is what on the springs both shocks slide bar forward , back. help. I am a nitro guy but want to have some fun this winter. also I have printed out the setup sheets but i am lost.
I dont know of anything thats availible other than the setup sheets you have. This site will provide you with some solid starting info. http://richardchang.com/hobby.php?topic=112setup
The section that deals with damper tubes applies to the lower shock.
Originally Posted by fire929
Also are there any positives to a t-bar chassis. s120 etc? over the 12r5.1?
Each has their +'s and -", imo its more of a feel thing. I've tried some link cars and just never could get comfortable with them, I started with t-bars and those just feel right for me.
Ripped off by RC Tech member: BlueStreak362 6/08
Thank you
Electric
Hpi Formula Ten
Team Associated 12R5.1
Maxamps Batteries
SMC Lipo
[quote=chris moore;6549381]I dont know of anything thats availible other than the setup sheets you have. This site will provide you with some solid starting info. http://richardchang.com/hobby.php?topic=112setup
Ouch! The Serpent metal is very hard but that can make for a brittle piece. I have not broken any parts yet except for two of the hardened optional diff rings. Those will shatter like glass they are so brittle!!!
Until you get a replacement slider, you can just put longer 3mm set screws through the aluminum slider and use those to set the T bar tweak. I sometimes do not use my blades. As for the shock shaft, not much you can do there except get another.
Tweeking with just the slider and no blades works great. It does give the feel of a stiffer T-bar but no ill handling effect. Try it
Ladies and Gentlemen................Mr. Marcos Moten
Serpent America
Primary Weapon>>>>Serpent S733 / Murnan RBM3
Serpent S120
C'MON SON
I've been using the Parma Speed 8 HD indoors on carpet, 17.5. Car handles very well.
*** The Gate II - Where Talent Goes To Die ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Good judgment comes from experience, and a lot of that comes from bad judgment.
- Will Rogers
Alright i got a couple of Nub questions for everyone.
My servo is no perfectly straight with the center line of the car, no matter how I try to mount it. (its a JR servo)
Does it matter which side the servo lays, on the right or the left side
I plan to run it here locally in Socal at west coast rc does anyone have set-up for that track to share
Kamikaze Development Driver
Kamikazetoysandhobbies.com
If you are using a JR 3550/3650, it should fit perfectly with the servo output shaft dead middle of the chassis. The kit comes with four servo mounts. You have to use a combination of the four to mount different sized servos. I use the JR 3550/3650 and the output shaft is right on the center line of the chassis. To get it centered, you do have to mount the servo biased towards the right side of the car.
