SERPENT 120
#737
Are any of you running this car on asphalt? Anything I should know or spare parts I should stock? What is the difference between my S120 and the BMI 1/12 scale? Any pluses or minuses? Just curious because CRC and BMI are mostly what I will be facing this season on our asphalt track. I actually might be the ONLY S120 out there hehe
#738
Spares: Kingpins! The "new" style (uses an allen wrench to screw them into the steering block instead of the supplied wrench) seem to be pretty fragile. They will bend right where the threads end (before the smooth part of the kingpin). You may need to cut about 1mm worth of threads off the kingpin so they won't bind the pillow ball in the upper arm. If you can't find stock kingpins, the CRC ProStrut kingpins could probably be used, since they are a little larger diameter (1/8 inch vs. 3 mm), but once you do that, you would have to use new steering blocks to switch back (the hole would be too big). You would also need to swap out the lower arm pivot balls (same reason 1/8 vs. 3mm). A bonus is that they are stronger than the stock kingpins, and they are a little shorter, so you don't need to cut them.
Pick up the complete front end nylon parts (as opposed to buying them separately - it's cheaper that way).
T-bars, and if you crash a lot, a spare pod. A spare pair of front axles, and front wheel nuts. Front body posts. Spare 3mm screws in the correct sizes.
#740
I bought a used s120 and was trying to put the front wheels when i noticed that the kingpin rubs on the rim can someone tell me whats going on? and where can i buy some kingpin here in the states since i broke one trying to take it off thanks.
#741
Stormer is out of stock, Ashford is out of stock, and Serpent America is out of stock. I heard that they are making changes to the kingpins to a) increase strength and b) make the threaded portion shorter, so that you don't have to cut or grind them down.
You should be able to use CRC ProStrut kingpins (they are 1/8 inch diameter, so once you use them, you can't go back to the originals, since they will stretch the plastic hole bigger). Also, you will need to use Associated L4 or CRC pivot balls in the lower arm.
#742
Thanks for the info joe.
#743
Maybe the kingpin isn't threaded into the steering block far enough? There shouldn't be any threads visible.
Without dremeling the king pin 2mm. torqueing it down would cause a bind with the top pivotball, steering arm will distort, bind the suspension..
#746
S120
Hi guys,
can I get a setup for a very low grip asphalt highspeed track?
#747
I just picked up the S120 front end kit and will be running it on my BMI. At first glance this looks like a very nice kit with a lot less tweaking needed to get it to move smoothly...unlike the old standard front end. I was a bit put off by the fact that it comes with no instructions. Fortunately I was able to find the car instruction kit on-line...though it would be nice to see front end only instructions that also discuss what the different settings can do. Anyway on to my question...
The instructions I found on-line show the pivot balls being inserted from the top of the arm. But when I look closely at the arm it looks to me that the hole for the pivot ball is wider on the bottom of the arm rather then the top so it looks like the ball should be inserted from the bottom up. Am I correct in this?
